*CLI> [May 23 17:50:24] DEBUG[8545]: chan_sip.c:7603 find_call: = Looking for Call ID: [email protected] (Checking From) --From tag 2003203917 --To-tag
[May 23 17:50:24] DEBUG[8545]: acl.c:725 ast_ouraddrfor: For destination '10.10.10.12', our source address is '10.10.10.2'.
[May 23 17:50:24] DEBUG[8545]: chan_sip.c:3384 ast_sip_ouraddrfor: Setting SIP_TRANSPORT_UDP with address 10.10.10.2:5060
[May 23 17:50:24] DEBUG[8545]: chan_sip.c:7360 sip_alloc: Allocating new SIP dialog for [email protected] - INVITE (No RTP)
[May 23 17:50:24] DEBUG[8545]: chan_sip.c:23874 handle_incoming: **** Received INVITE (5) - Command in SIP INVITE
[May 23 17:50:24] DEBUG[8545]: sip/reqresp_parser.c:1584 parse_sip_options: Begin: parsing SIP "Supported: 100rel, replaces, from-change"
[May 23 17:50:24] DEBUG[8545]: sip/reqresp_parser.c:1600 parse_sip_options: Found SIP option: -100rel-
[May 23 17:50:24] DEBUG[8545]: sip/reqresp_parser.c:1608 parse_sip_options: Matched SIP option: 100rel
[May 23 17:50:24] DEBUG[8545]: sip/reqresp_parser.c:1600 parse_sip_options: Found SIP option: -replaces-
[May 23 17:50:24] DEBUG[8545]: sip/reqresp_parser.c:1608 parse_sip_options: Matched SIP option: replaces
[May 23 17:50:24] DEBUG[8545]: sip/reqresp_parser.c:1600 parse_sip_options: Found SIP option: -from-change-
[May 23 17:50:24] DEBUG[8545]: sip/reqresp_parser.c:1608 parse_sip_options: Matched SIP option: from-change
[May 23 17:50:24] DEBUG[8545]: netsock2.c:125 ast_sockaddr_split_hostport: Splitting '10.10.10.12:5060' gives...
[May 23 17:50:24] DEBUG[8545]: netsock2.c:155 ast_sockaddr_split_hostport: ...host '10.10.10.12' and port '5060'.
[May 23 17:50:24] DEBUG[8545]: chan_sip.c:3230 __sip_xmit: Trying to put 'SIP/2.0 401' onto UDP socket destined for 10.10.10.12:5060
[May 23 17:50:24] DEBUG[8545]: chan_sip.c:7603 find_call: = Looking for Call ID: [email protected] (Checking From) --From tag 2003203917 --To-tag as48e9101c
[May 23 17:50:24] DEBUG[8545]: chan_sip.c:23874 handle_incoming: **** Received ACK (6) - Command in SIP ACK
[May 23 17:50:24] DEBUG[8545]: chan_sip.c:3922 __sip_ack: Stopping retransmission on '[email protected]' of Response 8: Match Found
[May 23 17:50:24] DEBUG[8545]: netsock2.c:125 ast_sockaddr_split_hostport: Splitting '10.10.10.2' gives...
[May 23 17:50:24] DEBUG[8545]: netsock2.c:155 ast_sockaddr_split_hostport: ...host '10.10.10.2' and port '(null)'.
[May 23 17:50:24] DEBUG[8545]: rtp_engine.c:344 ast_rtp_instance_new: Using engine 'asterisk' for RTP instance '0x76d100'
[May 23 17:50:24] DEBUG[8545]: res_rtp_asterisk.c:472 ast_rtp_new: Allocated port 16614 for RTP instance '0x76d100'
[May 23 17:50:24] DEBUG[8545]: rtp_engine.c:353 ast_rtp_instance_new: RTP instance '0x76d100' is setup and ready to go
[May 23 17:50:24] DEBUG[8545]: res_rtp_asterisk.c:2370 ast_rtp_prop_set: Setup RTCP on RTP instance '0x76d100'
== Using SIP RTP CoS mark 5
[May 23 17:50:24] DEBUG[8545]: chan_sip.c:4825 do_setnat: Setting NAT on RTP to On
[May 23 17:50:24] DEBUG[8545]: chan_sip.c:8398 process_sdp: Processing session-level SDP v=0... UNSUPPORTED.
[May 23 17:50:24] DEBUG[8545]: chan_sip.c:8398 process_sdp: Processing session-level SDP o=- 1752266231 0 IN IP4 10.10.10.12... UNSUPPORTED.
[May 23 17:50:24] DEBUG[8545]: chan_sip.c:8398 process_sdp: Processing session-level SDP s=SIPPER for phoner... UNSUPPORTED.
[May 23 17:50:24] DEBUG[8545]: netsock2.c:125 ast_sockaddr_split_hostport: Splitting '10.10.10.12' gives...
[May 23 17:50:24] DEBUG[8545]: netsock2.c:155 ast_sockaddr_split_hostport: ...host '10.10.10.12' and port '(null)'.
[May 23 17:50:24] DEBUG[8545]: chan_sip.c:8398 process_sdp: Processing session-level SDP c=IN IP4 10.10.10.12... OK.
[May 23 17:50:24] DEBUG[8545]: chan_sip.c:8398 process_sdp: Processing session-level SDP t=0 0... UNSUPPORTED.
[May 23 17:50:24] DEBUG[8545]: rtp_engine.c:535 ast_rtp_codecs_payloads_set_m_type: Setting payload 8 based on m type on 0x7dbfaac8
[May 23 17:50:24] DEBUG[8545]: rtp_engine.c:535 ast_rtp_codecs_payloads_set_m_type: Setting payload 0 based on m type on 0x7dbfaac8
[May 23 17:50:24] DEBUG[8545]: rtp_engine.c:535 ast_rtp_codecs_payloads_set_m_type: Setting payload 3 based on m type on 0x7dbfaac8
[May 23 17:50:24] DEBUG[8545]: rtp_engine.c:535 ast_rtp_codecs_payloads_set_m_type: Setting payload 97 based on m type on 0x7dbfaac8
[May 23 17:50:24] DEBUG[8545]: rtp_engine.c:535 ast_rtp_codecs_payloads_set_m_type: Setting payload 9 based on m type on 0x7dbfaac8
[May 23 17:50:24] DEBUG[8545]: rtp_engine.c:535 ast_rtp_codecs_payloads_set_m_type: Setting payload 111 based on m type on 0x7dbfaac8
[May 23 17:50:24] DEBUG[8545]: rtp_engine.c:535 ast_rtp_codecs_payloads_set_m_type: Setting payload 112 based on m type on 0x7dbfaac8
[May 23 17:50:24] DEBUG[8545]: rtp_engine.c:535 ast_rtp_codecs_payloads_set_m_type: Setting payload 101 based on m type on 0x7dbfaac8
[May 23 17:50:24] DEBUG[8545]: chan_sip.c:8585 process_sdp: Processing media-level (audio) SDP a=rtpmap:8 PCMA/8000... OK.
[May 23 17:50:24] DEBUG[8545]: chan_sip.c:8585 process_sdp: Processing media-level (audio) SDP a=rtpmap:0 PCMU/8000... OK.
[May 23 17:50:24] DEBUG[8545]: chan_sip.c:8585 process_sdp: Processing media-level (audio) SDP a=rtpmap:2 G726-32/8000... OK.
[May 23 17:50:24] DEBUG[8545]: chan_sip.c:8585 process_sdp: Processing media-level (audio) SDP a=rtpmap:3 GSM/8000... OK.
[May 23 17:50:24] DEBUG[8545]: chan_sip.c:8585 process_sdp: Processing media-level (audio) SDP a=rtpmap:97 iLBC/8000... OK.
[May 23 17:50:24] DEBUG[8545]: chan_sip.c:8585 process_sdp: Processing media-level (audio) SDP a=rtpmap:9 G722/8000... OK.
[May 23 17:50:24] DEBUG[8545]: chan_sip.c:8585 process_sdp: Processing media-level (audio) SDP a=rtpmap:111 speex/16000... OK.
[May 23 17:50:24] DEBUG[8545]: chan_sip.c:8585 process_sdp: Processing media-level (audio) SDP a=rtpmap:112 G726-16/8000... OK.
[May 23 17:50:24] DEBUG[8545]: chan_sip.c:8585 process_sdp: Processing media-level (audio) SDP a=rtpmap:113 G726-24/8000... OK.
[May 23 17:50:24] DEBUG[8545]: chan_sip.c:8585 process_sdp: Processing media-level (audio) SDP a=rtpmap:114 G726-40/8000... OK.
[May 23 17:50:24] DEBUG[8545]: chan_sip.c:8585 process_sdp: Processing media-level (audio) SDP a=rtpmap:101 telephone-event/8000... OK.
[May 23 17:50:24] DEBUG[8545]: chan_sip.c:8585 process_sdp: Processing media-level (audio) SDP a=fmtp:101 0-16... UNSUPPORTED.
[May 23 17:50:24] DEBUG[8545]: chan_sip.c:8585 process_sdp: Processing media-level (audio) SDP a=sendrecv... OK.
[May 23 17:50:24] DEBUG[8545]: rtp_engine.c:638 ast_rtp_codecs_payload_formats: Incorporating payload 0 on 0x7dbfaac8
[May 23 17:50:24] DEBUG[8545]: rtp_engine.c:638 ast_rtp_codecs_payload_formats: Incorporating payload 2 on 0x7dbfaac8
[May 23 17:50:24] DEBUG[8545]: rtp_engine.c:638 ast_rtp_codecs_payload_formats: Incorporating payload 3 on 0x7dbfaac8
[May 23 17:50:24] DEBUG[8545]: rtp_engine.c:638 ast_rtp_codecs_payload_formats: Incorporating payload 8 on 0x7dbfaac8
[May 23 17:50:24] DEBUG[8545]: rtp_engine.c:638 ast_rtp_codecs_payload_formats: Incorporating payload 9 on 0x7dbfaac8
[May 23 17:50:24] DEBUG[8545]: rtp_engine.c:638 ast_rtp_codecs_payload_formats: Incorporating payload 97 on 0x7dbfaac8
[May 23 17:50:24] DEBUG[8545]: rtp_engine.c:638 ast_rtp_codecs_payload_formats: Incorporating payload 101 on 0x7dbfaac8
[May 23 17:50:24] DEBUG[8545]: rtp_engine.c:638 ast_rtp_codecs_payload_formats: Incorporating payload 111 on 0x7dbfaac8
[May 23 17:50:24] DEBUG[8545]: rtp_engine.c:638 ast_rtp_codecs_payload_formats: Incorporating payload 112 on 0x7dbfaac8
[May 23 17:50:24] DEBUG[8545]: res_rtp_asterisk.c:2391 ast_rtp_remote_address_set: Setting RTCP address on RTP instance '0x76d100'
[May 23 17:50:24] DEBUG[8545]: rtp_engine.c:516 ast_rtp_codecs_payloads_copy: Copying payload 0 from 0x7dbfaac8 to 0x76d2b0
[May 23 17:50:24] DEBUG[8545]: rtp_engine.c:516 ast_rtp_codecs_payloads_copy: Copying payload 2 from 0x7dbfaac8 to 0x76d2b0
[May 23 17:50:24] DEBUG[8545]: rtp_engine.c:516 ast_rtp_codecs_payloads_copy: Copying payload 3 from 0x7dbfaac8 to 0x76d2b0
[May 23 17:50:24] DEBUG[8545]: rtp_engine.c:516 ast_rtp_codecs_payloads_copy: Copying payload 8 from 0x7dbfaac8 to 0x76d2b0
[May 23 17:50:24] DEBUG[8545]: rtp_engine.c:516 ast_rtp_codecs_payloads_copy: Copying payload 9 from 0x7dbfaac8 to 0x76d2b0
[May 23 17:50:24] DEBUG[8545]: rtp_engine.c:516 ast_rtp_codecs_payloads_copy: Copying payload 97 from 0x7dbfaac8 to 0x76d2b0
[May 23 17:50:24] DEBUG[8545]: rtp_engine.c:516 ast_rtp_codecs_payloads_copy: Copying payload 101 from 0x7dbfaac8 to 0x76d2b0
[May 23 17:50:24] DEBUG[8545]: rtp_engine.c:516 ast_rtp_codecs_payloads_copy: Copying payload 111 from 0x7dbfaac8 to 0x76d2b0
[May 23 17:50:24] DEBUG[8545]: rtp_engine.c:516 ast_rtp_codecs_payloads_copy: Copying payload 112 from 0x7dbfaac8 to 0x76d2b0
[May 23 17:50:24] DEBUG[8545]: chan_sip.c:8817 process_sdp: We're settling with these formats: 0xe (gsm|ulaw|alaw)
[May 23 17:50:24] DEBUG[8545]: chan_sip.c:21543 handle_request_invite: Checking SIP call limits for device 12
[May 23 17:50:24] DEBUG[8545]: chan_sip.c:5596 update_call_counter: Updating call counter for incoming call
[May 23 17:50:24] DEBUG[8545]: frame.c:1242 ast_codec_choose: Could not find preferred codec - Going for the best codec
[May 23 17:50:24] DEBUG[8545]: chan_sip.c:6699 sip_new: *** Our native formats are 0x4 (ulaw)
[May 23 17:50:24] DEBUG[8545]: chan_sip.c:6700 sip_new: *** Joint capabilities are 0xe (gsm|ulaw|alaw)
[May 23 17:50:24] DEBUG[8545]: chan_sip.c:6701 sip_new: *** Our capabilities are 0x80000008000e (gsm|ulaw|alaw|h263|testlaw)
[May 23 17:50:24] DEBUG[8545]: chan_sip.c:6702 sip_new: *** AST_CODEC_CHOOSE formats are 0x4 (ulaw)
[May 23 17:50:24] DEBUG[8545]: chan_sip.c:6732 sip_new: This channel will not be able to handle video.
[May 23 17:50:24] DEBUG[8545]: chan_sip.c:13497 build_route: build_route: Contact hop: <sip:[email protected]:5060>
[May 23 17:50:24] DEBUG[8545]: chan_sip.c:21835 handle_request_invite: SIP/12-00000000: New call is still down.... Trying...
[May 23 17:50:24] DEBUG[8545]: chan_sip.c:3230 __sip_xmit: Trying to put 'SIP/2.0 100' onto UDP socket destined for 10.10.10.12:5060
[May 23 17:50:24] DEBUG[8553]: pbx.c:4066 pbx_extension_helper: Launching 'NoCDR'
-- Executing [11@telefone:1] NoCDR("SIP/12-00000000", "") in new stack
[May 23 17:50:24] DEBUG[8553]: pbx.c:3095 ast_str_retrieve_variable: Result of 'EXTEN' is '11'
[May 23 17:50:24] DEBUG[8553]: pbx.c:4066 pbx_extension_helper: Launching 'Dial'
-- Executing [11@telefone:2] Dial("SIP/12-00000000", "SIP/11,15,Ttr") in new stack
[May 23 17:50:24] DEBUG[8553]: chan_sip.c:25301 sip_request_call: Asked to create a SIP channel with formats: 0x4 (ulaw)
[May 23 17:50:24] DEBUG[8553]: chan_sip.c:7360 sip_alloc: Allocating new SIP dialog for 7248679c66e8d94e11ec273874b3f087@[c0a8:202:780b:867f::]:0 - INVITE (No RTP)
[May 23 17:50:24] DEBUG[8553]: chan_sip.c:25409 sip_request_call: Cant create SIP call - target device not registered
[May 23 17:50:24] DEBUG[8553]: chan_sip.c:5744 sip_destroy: Destroying SIP dialog 7248679c66e8d94e11ec273874b3f087@[c0a8:202:780b:867f::]:0
== Everyone is busy/congested at this time (1:0/0/1)
[May 23 17:50:24] DEBUG[8553]: app_dial.c:2725 dial_exec_full: Exiting with DIALSTATUS=CHANUNAVAIL.
[May 23 17:50:24] DEBUG[8553]: pbx.c:4066 pbx_extension_helper: Launching 'VoiceMail'
-- Executing [11@telefone:3] VoiceMail("SIP/12-00000000", "9999,u") in new stack
[May 23 17:50:24] DEBUG[8553]: chan_sip.c:6170 sip_answer: SIP answering channel: SIP/12-00000000
[May 23 17:50:24] DEBUG[8553]: res_rtp_asterisk.c:725 ast_rtp_update_source: Setting the marker bit due to a source update
[May 23 17:50:24] DEBUG[8553]: chan_sip.c:11131 transmit_response_with_sdp: Setting framing from config on incoming call
[May 23 17:50:24] DEBUG[8553]: chan_sip.c:10777 add_sdp: ** Our capability: 0xe (gsm|ulaw|alaw) Video flag: True Text flag: True
[May 23 17:50:24] DEBUG[8553]: chan_sip.c:10778 add_sdp: ** Our prefcodec: 0x0 (nothing)
[May 23 17:50:24] DEBUG[8553]: chan_sip.c:10887 add_sdp: -- Done with adding codecs to SDP
[May 23 17:50:24] DEBUG[8553]: chan_sip.c:11026 add_sdp: Done building SDP. Settling with this capability: 0xe (gsm|ulaw|alaw)
[May 23 17:50:24] DEBUG[8553]: chan_sip.c:3230 __sip_xmit: Trying to put 'SIP/2.0 200' onto UDP socket destined for 10.10.10.12:5060
[May 23 17:50:24] DEBUG[8545]: chan_sip.c:7603 find_call: = Looking for Call ID: [email protected] (Checking From) --From tag 2003203917 --To-tag as0a185136
[May 23 17:50:24] DEBUG[8545]: chan_sip.c:3922 __sip_ack: Stopping retransmission on '[email protected]' of Response 9: Match Found
[May 23 17:50:24] DEBUG[8553]: res_rtp_asterisk.c:1673 ast_rtcp_read: Got RTCP report of 28 bytes
[May 23 17:50:24] DEBUG[8553]: chan_sip.c:7069 sip_rtp_read: Oooh, format changed to gsm
[May 23 17:50:24] DEBUG[8553]: channel.c:5048 set_format: Set channel SIP/12-00000000 to read format ulaw
[May 23 17:50:24] DEBUG[8553]: channel.c:5048 set_format: Set channel SIP/12-00000000 to write format ulaw
[May 23 17:50:24] DEBUG[8553]: app_voicemail.c:5541 leave_voicemail: Before find_user
[May 23 17:50:24] DEBUG[8553]: app_voicemail.c:5653 leave_voicemail: /opt/var/spool/asterisk/voicemail/default/9999/unavail doesn't exist, doing what we can
[May 23 17:50:24] DEBUG[8553]: channel.c:5048 set_format: Set channel SIP/12-00000000 to write format gsm
[May 23 17:50:24] DEBUG[8553]: res_rtp_asterisk.c:1239 ast_rtp_write: Ooh, format changed from unknown to gsm
[May 23 17:50:24] DEBUG[8553]: res_rtp_asterisk.c:1270 ast_rtp_write: Created smoother: format: gsm ms: 20 len: 33
[May 23 17:50:24] DEBUG[8553]: channel.c:3427 ast_settimeout: Scheduling timer at (50 requested / 50 actual) timer ticks per second
Segmentation fault
@asus:/tmp/home/root#
