Shell Skript ausführen mit System() ohne Funktion
bosv
2 Aug 2014
Hallo Zusammen,
ich möchten ein Shell Skript im Dialplan ausführen (unter Eingabe von [noparse]88)[/noparse] soweit funktioniert das auch laut CLI bis auf das,
das Skript nicht startet.
Hier mal ein paar Auszüge:
Skript:
#!/bin/sh
echo "1"> /sys/class/gpio/gpio4/value
sleep 3
echo "0"> /sys/class/gpio/gpio4/value
exit 0
Skript Rechte:
pi@raspberrypi ~/bin $ ls -ld dooropen.sh
-rwxr-xr-x 1 asterisk asterisk 108 Aug  2 13:50 dooropen.sh
features.conf
[applicationmap]
door => 88,callee,Macro,sven
extensions.conf
[internal]
exten => _XXXX,1,Dial(SIP/${EXTEN}) ; alle Teilnehmer mit einer 4 - stelligen N$
same => n,set(DYNAMIC_FEATURES=door)
[phones]
include => internal
[macro-sven]
exten => s,1,System(/home/pi/bin/dooropen.sh)
Asterisk Rechte:
pi@raspberrypi ~ $ ls -ld /etc/asterisk
drwxr-xr-x 3 asterisk asterisk 4096 Jul 18 21:41 /etc/asterisk
pi@raspberrypi ~ $
CLI wenn 88 gewählt wird:
pi@raspberrypi ~ $ sudo asterisk -vvvr
Asterisk 1.8.13.1~dfsg1-3+deb7u3, Copyright (C) 1999 - 2012 Digium, Inc. and others.
Created by Mark Spencer <[email protected]>
Asterisk comes with ABSOLUTELY NO WARRANTY; type 'core show warranty' for details.
This is free software, with components licensed under the GNU General Public
License version 2 and other licenses; you are welcome to redistribute it under
certain conditions. Type 'core show license' for details.
  == Parsing '/etc/asterisk/asterisk.conf':   == Found
  == Parsing '/etc/asterisk/extconfig.conf':   == Found
Connected to Asterisk 1.8.13.1~dfsg1-3+deb7u3 currently running on raspberrypi (pid = 1919)
Verbosity is at least 9
  == Using SIP RTP CoS mark 5
    -- Executing [1000@phones:1] Dial("SIP/2000-00000082", "SIP/1000") in new stack
    -- Called SIP/1000
    -- SIP/1000-00000083 is ringing
    -- SIP/1000-00000083 answered SIP/2000-00000082
[Aug  2 14:35:38] DTMF[25502]: channel.c:4084 __ast_read: DTMF begin '8' received on SIP/2000-00000082
[Aug  2 14:35:38] DTMF[25502]: channel.c:4094 __ast_read: DTMF begin passthrough '8' on SIP/2000-00000082
[Aug  2 14:35:38] DTMF[25502]: channel.c:3999 __ast_read: DTMF end '8' received on SIP/2000-00000082, duration 100 ms
[Aug  2 14:35:38] DTMF[25502]: channel.c:4039 __ast_read: DTMF end accepted with begin '8' on SIP/2000-00000082
[Aug  2 14:35:38] DTMF[25502]: channel.c:4068 __ast_read: DTMF end passthrough '8' on SIP/2000-00000082
[Aug  2 14:35:39] DTMF[25502]: channel.c:4084 __ast_read: DTMF begin '8' received on SIP/2000-00000082
[Aug  2 14:35:39] DTMF[25502]: channel.c:4094 __ast_read: DTMF begin passthrough '8' on SIP/2000-00000082
[Aug  2 14:35:39] DTMF[25502]: channel.c:3999 __ast_read: DTMF end '8' received on SIP/2000-00000082, duration 100 ms
[Aug  2 14:35:39] DTMF[25502]: channel.c:4039 __ast_read: DTMF end accepted with begin '8' on SIP/2000-00000082
[Aug  2 14:35:39] DTMF[25502]: channel.c:4068 __ast_read: DTMF end passthrough '8' on SIP/2000-00000082
    --  Feature Found: door exten: door
    -- Executing [s@macro-sven:1] System("SIP/1000-00000083", "/home/pi/bin/dooropen.sh") in new stack
raspberrypi*CLI>
Disconnected from Asterisk server
Executing last minute cleanups
pi@raspberrypi ~ $
Das Skript soll eine LED an einem Raspberry PI schalten -> bei direktem Aufruf des Skript wird dieses auch ausgeführt aber über Asterisk
Asterisk nicht.
Hat jemand noch eine Idee ???
Ich bin solangsam am Ende mit meinen Try & Errors . Bin auch Neueinsteiger unter LINUX Debian Wheezy.
Vielen Dank im voraus.
Sven
Asterisk nicht.
Wie ist auf deinem Pi, die Ausgabe von:
cat /etc/group | grep -i gpio
Abend
Wenn das Skript funktioniert (nicht in asterisk), dann liegt eventuell das gute alte Rechteproblem vor:
Darf asterisk asterisk auf/in /sys/class/gpio/gpio4/value schreiben?
Hallo sf39789,
folgendes wird ausgegeben:
pi@raspberrypi ~ $ cat /etc/group | grep -i gpio
gpio:x:1003:pi
Wie kann ich diese Rechte vergeben - damit Asterisk in der Gruppe GPIO Mitglied wird ? Wie gesagt ich sammle erst Linux Erfahrungen.
asterisk ist klein geschrieben bei $ ls -ld /etc/asterisk
o.k. danke ich probiere es aus und melde mich wieder.
[Beitrag 2:]
vielen Dank für die schnellen Auskünfte.
hier das Resultat der Befehle doch testen kann ich erst morgen.
pi@raspberrypi ~ $ sudo usermod -G gpio -a asterisk
gpio : x : 1003 : pi,asterisk
[Beitrag 3:]
das Resultat nachdem Asterisk in der Gruppe GPIO Mitglied ist - ist das gleiche.
Die LED am Ausgang wird nicht geschaltet.
Was kann das noch sein ?:mad:
Hm, vielleicht hat asterisk das noch nicht mitbekommen.
Also, hast du asterisk beendet und neugestartet?
Du kannst dich auch als root zum asterisk User machen und das testen:
su - asterisk
whoami
asterisk # Jetzt kannst du auch mit dem Kommando [b]id[/b] prüfen ob gpio auch als Gruppenmitglied gelistet wird.
id
dooropen.sh
sh dooropen.sh
sh -x dooropen.sh
exit
whoami
root
Vielleicht, oder sehr wahrscheinlich, brauchst du auch die volle Pfadangabe zu dooropen.sh.
/der/lange/weg/zu/dooropen.sh
sh /der/lange/weg/zu/dooropen.sh
sh -x /der/lange/weg/zu/dooropen.sh
Poste auch ruhig mal die Ergebnisse hier.
...das wird. ;)
was verstehst Du unter dem langen weg ?
das Skript liegt unter folgender Ordner Struktur:
/home/pi/bin/skript.sh
/home ist root root
/pi/ ist pi pi
/bin/ ist auch pi pi
skript.sh ist asterisk asterisk
muss ich die übergeordneten Ordnern jetzt auch die Gruppe asterisk zuweisen damit Asterisk auf das Skipt zugreifen kann ?
Bzw. wie vergebe ich Asterisk die Rechte das es Dateien in anderen Verzeichnissen ausführen darf ?
Asterisk liegt in /etc/asterisk.
Deine Befehle muss ich später testen wenn ich zuhause bin.
...den absoluten Pfad: /home/pi/bin/skript.sh
Nein. Einfacher wäre asterisk auch pi als Gruppe zuzuweisen.
Es reicht wenn für die Verzeichnisse die Rechte für o (others) auf rx gesetzt ist.
Dann könnte da aber jeder rein und das Skript ausführen.
chmod o=rx Verzeichnisname
Es würde aber vieles vereinfachen wenn asterisk.asterisk auch ein Homeverzeichnis hätte: /home/asterisk
Und dann da drin sein bin Verzeichnis: /home/asterisk/bin
Wenn dann noch eine .profile in /home/asterisk liegt, die den $PATH um ~/bin erweitert: export PATH=~/bin:$PATH
Dann musst du nicht das Homeverzeichnis von pi für Alle öffnen.
ich will mich ja nicht einmischen, aber ich hatte das gleiche Problem mit Linux, denn auch ich bin kein Linux-Experte. Deshalb hatte ich wiringPI auf dem RPI installiert und an anderer Stelle in einem C-Programm beim jedem Start des RPI für den entsprechenden PIN ein Setup gemacht:
wiringPiSetup();
pinMode(DOORPIN, OUTPUT);
digitalWrite(DOORPIN, LOW);
Und bei Bedarf mit *9 das Tor mit dieser Skript-Datei "opendoor" geöffnet/geschlossen bzw. beim Test die LED zum Leuchten gebracht:
#!/bin/bash
gpio write 3 1
sleep 1
gpio write 3 0
und dafür in der extensions.conf folgenden Eintrag verwendet, wobei ich nicht geprüft habe ob alle Einträge hier wirklich notwendig sind:
[opendoor]
exten => *9,1,Answer()
exten => *9,n,Wait(1)
exten => *9,n,System(sh /home/pi/bin/opendoor)
exten => *9,n,Hangup()
Ist zwar keine Beantwortung der Frage warum das Skript nicht so ohne weiteres ausgeführt wird, was für mich aber ein funktionierener "work around" war.
Manne
Rechte
Als welcher User läuft denn dein asterisk?
root? asterisk? pi?
Und wenn er als asterisk läuft, wie sind die Verzeichnisrechte bei /home/pi und /home/pi/bin ?
Nicht, das der TE deinem Beispiel folgt, und es geht dann trotzdem nicht.
hier nochmal die Rechte der Verzeichnisse.
pi@raspberrypi ~ $ ls -ld /home
drwxr-xr-x 3 root root 4096 Sep 25  2013 /home
pi@raspberrypi ~ $ ls -ld /home/pi
drwxr-xr-x 12 pi pi 4096 Jul 30 11:35 /home/pi
pi@raspberrypi ~ $ ls -ld /home/pi/bin
drwxr-xr-x 2 pi pi 4096 Aug  3 12:37 /home/pi/bin
pi@raspberrypi ~ $ ls -ld /home/pi/bin/dooropen.sh
-rwxr-xr-x 1 asterisk asterisk 108 Aug  2 13:50 /home/pi/bin/dooropen.sh
pi@raspberrypi ~ $
[Beitrag 2:]
pi@raspberrypi ~ $ su - asterisk
Passwort:
hier will er ein Passwort ich hatte aber noch keins vergeben - gibts hier ein default Passwort ?
Wahrscheinlich nicht (kein Passwort).
Du solltest aber schon der Obermotz/Administrator root sein. ;)
Der braucht nämlich für sowas auch kein Passwort.
Die Rechte für others (alle Anderen) sehen OK aus.
Kann/Darf asterisk.asterisk das Programm gpio ausführen?
Dann probier mal was Manne44 als dooropen[.sh] benutzt...
#!/bin/bash
gpio write 3 1
sleep 1
gpio write 3 0
Wie sind die Rechte der Verzeichnisse bzw. der Datei(en), die Du in deinem Script verwendest?
Manne verwendet WiringPi , das hab ich noch nicht installiert.
[Beitrag 2:]
pi@raspberrypi ~ $ ls -ld /sys/
dr-xr-xr-x 12 root root 0 Jan  1  1970 /sys/
pi@raspberrypi ~ $ ls -ld /sys/class/
drwxr-xr-x 39 root root 0 Aug  3 21:59 /sys/class/
pi@raspberrypi ~ $ ls -ld /sys/class/gpio/
drwxrwx--- 2 root gpio 0 Aug  3 21:59 /sys/class/gpio/
pi@raspberrypi ~ $ ls -ld /sys/class/gpio/gpio4
lrwxrwxrwx 1 root gpio 0 Aug  3 21:59 /sys/class/gpio/gpio4 -> ../../devices/virtual/gpio/gpio4
pi@raspberrypi ~ $ ls -ld /sys/class/gpio/gpio4/value
-rwxrwx--- 1 root gpio 4096 Aug  3 22:00 /sys/class/gpio/gpio4/value
pi@raspberrypi ~ $
[Beitrag 3:]
Hallo Koyaanisqatsi,
root@raspberrypi:/home/pi# su - asterisk
root@raspberrypi:/home/pi# whoami
root
root@raspberrypi:/home/pi# id
uid=0(root) gid=0(root) Gruppen=0(root),1001(indiecity)
Komisch, bei mir geht als root das: su - [irgend ein user aus/etc/passwd]
...und dann bin ich der auch.
Das ist ja auch kein Ordner sondern eine Textdatei mit den Benutzern.
So kannst du sie dir ansehen:
cat /etc/passwd
Pianist
