Siemens Home Station Kabel
M@rcel
6 Dez 2008
(Mein Deutsch ist warscheinlich nicht sehr gut...:rolleyes:, entschuldige)
Ich kan mir ein Siemens Home Station kaufen. Dieses will ich anwenden um mobil-gespräche billiger zu machen (lcr mit Fritz 7170).
Dieses Home Station fehlt aber der Kabel von Station zu Handy. Kan Jemand mir das Schaltplan diese Kabel zeigen? Dan kan Ich selbst eine machen. Vielleicht kan Jemand seine Kabel messen?
Danke!
Marcel
Anyone? Please? I can't find it anywhere on the net...:(
A very, very kind person on the Internet has determined the pinout of this cable for me by measuring his own cable. The pinout appears to be a 1:1. (For privacy reasons I wil not reveal his/her identity, but thank you thank you THANK YOU).
I ordered two C45 datacables, just for the connectors. I asked several sellers if the connectors on their cables had all twelve contacts. One seller on ebay responded with a "yes", the picture also showed that the connectors could be opened.
http://cgi.ebay.nl/DATAKABEL-USB-Si...11310QQcmdZViewItemQQ_trksidZp1713.m153.l1262
Perhaps not the cheapest but guaranteed to have all 12 contacts. The cables contained 6 wires each, so by combining them I had the 12 wires I needed.
After soldering and testing: Succes!
Perhaps this writing is of help for someone in the future.
ms9063
