Sinus 212 + FB7270, is possible?
vasila
7 Mai 2008
Hello,
I receive (free) a phone T-Com Sinus 212. I d'ont have any documentation of the phone....
Is it a DECT phone ?
Can i connect it to my FB 7270 ?
Can someone tell me here is the menu to register the phone in the FB DECT base!!
I already change the language to english, however i cannot found the menu to register the phone :(
Thanks in advance
Best regards
Thanks for the answer.
In that manual there is no reference to register the phone in a DECT base :(
Someone can help me?
Thanks in advance
Best Regards
In orignal it is not possible to register this model to other base.
But this should work:
Menü, *, *, #, *, #, #, Menü, Menü, PIN, Menü
Und schon ist man an der Basisstation angemeldet.
- It may be impossible to register it back to the original base.
- The original base sends DECT-signal even after that procedure (uses power). It may be possible to open the base and disconnect the base-part to only use as charger.
Thanks fir your answer....
If is impossible to register back the device is very bad :(:(
Thank you
Best regards
I try to re-register the phone in the original base!
I suceed :-) :-)
I choose register in the phone and press for 15 seconds the button that exists in the base !!
Thanks for all the help!
Best regards
Jo12305
