ich habe Probleme bei der Konfiguration meines SIP Accounts auf einem Cisco 1751-V mit CCME 4.0.3 und einem Cisco Softphone.
Raustelefonieren ist kein Problem nur das reintelefonieren klappt einfach nicht.
Hier mal meine Konfig :
voice service voip
allow-connections h323 to h323
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
no supplementary-service h450.2
supplementary-service h450.12
sip
bind control source-interface FastEthernet0/0
bind media source-interface FastEthernet0/0
registrar server expires max 1200 min 300
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g729r8
voice translation-rule 1
rule 1 /491805xxxxxx / /1000/
voice translation-profile incomming
translate called 1
dial-peer voice 1 voip
description ** Rein/Raus **
translation-profile incoming incomming
service session
destination-pattern .T
voice-class codec 1
session protocol sipv2
session target dns:siplogin.de
incoming called-number 491805xxxxxx
dtmf-relay rtp-nte
fax rate disable
no vad
sip-ua
credentials username 491805xxxxxx password xxx realm siplogin.de
authentication username 491805xxxxxx password xxx realm siplogin.de
nat symmetric role active
no remote-party-id
retry invite 3
retry response 3
retry bye 3
retry cancel 3
retry register 10
timers trying 1000
timers register 1000
registrar dns:siplogin.de:5060 expires 3600
sip-server dns:siplogin.de
ephone-dn 1
number 1000 no-reg primary
ephone-dn 2 dual-line
number 491805xxxxxx!
ephone 2
mac-address 0050.22E3.970D
type CIPC
button 1:2 button 2:1
night-service bell
Debug ccsip all beim eingehenden Anruf.
*Mar 2 09:48:26.129: //-1/xxxxxxxxxxxx/SIP/Info/HandleUdpSocketReads: Msg enqueued for SPI with IP addr: 80.237.199.1:506
*Mar 2 09:48:26.129: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 2 for vent 1
*Mar 2 09:48:26.129: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportProcessNWNewConnMsg: context=0x83D298B4
*Mar 2 09:48:26.133: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
INVITE sip:[email protected]:54606 SIP/2.0
Record-Route: <sip:80.237.199.1;lr=on;ftag=as7492f334>
Via: SIP/2.0/UDP 80.237.199.1;branch=z9hG4bK4b6f.24699037.3
Via: SIP/2.0/UDP 80.237.199.41:5060;branch=z9hG4bK16dc59b5;rport=5060
From: "+4952xxxxx" <sip:[email protected]>;tag=as7492f334
To: <sip:[email protected]>
Contact: <sip:[email protected]>
Call-ID: [email protected]
CSeq: 102 INVITE
User-Agent: Cantata 1 13 18.45.6 (gate99)
Max-Forwards: 69
Date: Sun, 24 Aug 2008 12:33:29 GMT
Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REFER, SUBSCRIBE, NOTIFY
X-PRODUCT: inbound
X-PRODUCT: inbound
X-CallID: [email protected]
Content-Type: application/sdp
Content-Length: 399
v=0
o=root 32227 32227 IN IP4 80.237.199.41
s=session
c=IN IP4 80.237.199.41
t=0 0
m=audio 16928 RTP/AVP 8 0 97 3 111 101
a=rtpmap:8 PCMA/8000
a=rtpmap:0 PCMU/8000
a=rtpmap:97 iLBC/8000
a=rtpmap:3 GSM/8000
a=rtpmap:111 G726-32/8000
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-16
a=silenceSupp
ff - - - -
m=video 51016 RTP/AVP 31 34
a=rtpmap:31 H261/90000
a=rtpmap:34 H263/90000
*Mar 2 09:48:26.137: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_new_msg_preprocessor: Checking Invite Dialog
*Mar 2 09:48:26.137: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIAddContextToTable: Added context(0x84684D80) with key=[367] to tabl
*Mar 2 09:48:26.141: //-1/xxxxxxxxxxxx/SIP/Transport/sipSPIUpdateResponseInfo: Dialog Transaction Address 80.237.199.1,Pot 5060, Transport 1, SentBy Port 5060
*Mar 2 09:48:26.141: //-1/7A2028728182/SIP/State/sipSPIChangeState: 0x84684D80 : State change from (STATE_NONE, SUBSTATE_ONE) to (STATE_IDLE, SUBSTATE_NONE)
*Mar 2 09:48:26.141: //-1/xxxxxxxxxxxx/SIP/Info/sipSPISetDateHeader: Clock Time Zone is UTC, same as GMT: Using GMT
*Mar 2 09:48:26.145: //-1/xxxxxxxxxxxx/SIP/Transport/sipSPIUpdateResponseInfo: Dialog Transaction Address 80.237.199.1,Pot 5060, Transport 1, SentBy Port 5060
*Mar 2 09:48:26.149: //-1/xxxxxxxxxxxx/SIP/Error/sipSPI_validate_own_ip_addr: ReqLine IP addr does not match with host IPaddr
*Mar 2 09:48:26.153: //-1/7A2028728182/SIP/Error/sact_idle_new_message_invite: Invalid URL in incoming INVITE
*Mar 2 09:48:26.153: //-1/7A2028728182/SIP/Info/ccsip_set_cc_cause_for_spi_err: Categorized cause:100, category:100
*Mar 2 09:48:26.153: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_set_release_source_for_peer: ownCallId[-1], src[6]
*Mar 2 09:48:26.153: //-1/7A2028728182/SIP/Info/sipSPIUaddCcbToUASReqTable: ****Adding to UAS Request table.
*Mar 2 09:48:26.153: //-1/7A2028728182/SIP/Info/sipSPIUaddCcbToTable: Added to table. ccb=0x84684D80 [email protected]
*Mar 2 09:48:26.153: //-1/7A2028728182/SIP/Info/sipSPIUaddCcbToUASRespTable: ****Adding to UAS Response table.
*Mar 2 09:48:26.157: //-1/7A2028728182/SIP/Info/sipSPIUaddCcbToTable: Added to table. ccb=0x84684D80 [email protected]
*Mar 2 09:48:26.161: //-1/7A2028728182/SIP/Transport/sipSPITransportSendMessage: msg=0x8471EEC4, addr=80.237.199.1, port=060, sentBy_port=5060, is_req=0, transport=1, switch=0, callBack=0x80BA7984
*Mar 2 09:48:26.161: //-1/7A2028728182/SIP/Transport/sipSPITransportSendMessage: Proceedable for sending msg immediately
*Mar 2 09:48:26.161: //-1/7A2028728182/SIP/Transport/sipTransportLogicSendMsg: switch transport is 0
*Mar 2 09:48:26.161: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostSendMessage: Posting send for msg=0x8471EEC4, addr=8.237.199.1, port=5060, connId=0 for UDP
*Mar 2 09:48:26.161: //-1/7A2028728182/SIP/Info/sentErrResDisconnecting: Sent an 3456XX Error Response
*Mar 2 09:48:26.161: //-1/7A2028728182/SIP/State/sipSPIChangeState: 0x84684D80 : State change from (STATE_IDLE, SUBSTATE_ONE) to (STATE_DISCONNECTING, SUBSTATE_NONE)
*Mar 2 09:48:26.165: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 400 Bad Request - 'Invalid Host'
Via: SIP/2.0/UDP 80.237.199.1;branch=z9hG4bK4b6f.24699037.3,SIP/2.0/UDP 80.237.199.41:5060;branch=z9hG4bK16dc59b5;rport=500
To: <sip:[email protected]>;tag=59A0AB8-816
Date: Sat, 02 Mar 2002 09:48:26 GMT
Server: Cisco-SIPGateway/IOS-12.x
CSeq: 102 INVITE
Allow-Events: telephone-event
Reason: Q.850;cause=100
Content-Length: 0
*Mar 2 09:48:26.209: //-1/xxxxxxxxxxxx/SIP/Info/HandleUdpSocketReads: Msg enqueued for SPI with IP addr: 80.237.199.1:506
*Mar 2 09:48:26.209: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 2 for vent 1
*Mar 2 09:48:26.213: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportProcessNWNewConnMsg: context=0x83D298B4
*Mar 2 09:48:26.213: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
ACK sip:[email protected]:54606 SIP/2.0
CSeq: 102 ACK
User-Agent: Xip (embedded openSER)
Content-Length: 0
*Mar 2 09:48:26.213: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_new_msg_preprocessor: Checking Invite Dialog
*Mar 2 09:48:26.217: //-1/7A2028728182/SIP/Info/sipSPIFindCcbUASRespTable: *****CCB found in UAS Response table. ccb=0x8484D80
*Mar 2 09:48:26.221: //-1/xxxxxxxxxxxx/SIP/Transport/sipSPIUpdateResponseInfo: Subsq Transaction Address 80.237.199.1,Por 5060, Transport 1, SentBy Port 5060
*Mar 2 09:48:26.221: //-1/xxxxxxxxxxxx/SIP/Info/sipSPISetDateHeader: Clock Time Zone is UTC, same as GMT: Using GMT
*Mar 2 09:48:26.225: //-1/7A2028728182/SIP/State/sipSPIChangeState: 0x84684D80 : State change from (STATE_DISCONNECTING, UBSTATE_NONE) to (STATE_DEAD, SUBSTATE_NONE)
*Mar 2 09:48:26.225: //-1/7A2028728182/SIP/Call/sipSPICallInfo:
The Call Setup Information is:
Call Control Block (CCB) : 0x84684D80
State of The Call : STATE_DEAD
TCP Sockets Used : NO
Calling Number :
Called Number : 491805xxxxx
Source IP Address (Sig ): 192.168.1.253
Destn SIP Req Addr
Destn SIP Resp Addr
Destination Name : 80.237.199.1
Disconnect Cause (CC) : 100
Disconnect Cause (SIP) : 400
*Mar 2 09:48:26.225: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIDeleteContextFromTable: Context for key=[367] removed.
*Mar 2 09:48:26.229: //-1/7A2028728182/SIP/Info/sipSPIUdeleteCcbFromUASReqTable: ****Deleting from UAS Request table.
*Mar 2 09:48:26.229: //-1/7A2028728182/SIP/Info/sipSPIUdeleteCcbFromTable: Deleting from table. ccb=0x84684D80 [email protected]
*Mar 2 09:48:26.229: //-1/7A2028728182/SIP/Info/sipSPIUdeleteCcbFromUASRespTable: ****Deleting from UAS Response table.
*Mar 2 09:48:26.233: //-1/7A2028728182/SIP/Info/sipSPIFlushEventBufferQueue: There are 0 events on the internal queue tha are going to be free'd
*Mar 2 09:48:26.233: //-1/7A2028728182/SIP/Info/sipSPIUfreeOneCCB: Freeing ccb 84684D80
*Mar 2 09:48:26.233: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetContextFromTable: NO context for key[367]
Router#show sip-ua register status
Line peer expires(sec) registered
491805xxxxxx 20016 99 yes
Hat jemand ne Idee was hier falsch ist?
voice service voip
sip
voice class codec 1
translate called 1
service session
voice-class codec 1
dtmf-relay rtp-nte
fax rate disable
no vad
sip-ua
no remote-party-id
retry invite 3
retry response 3
retry bye 3
retry cancel 3
retry register 10
timers trying 1000
ephone-dn 1
ephone 2
type CIPC
night-service bell
Received:
CSeq: 102 INVITE
Max-Forwards: 69
X-PRODUCT: inbound
X-PRODUCT: inbound
Content-Length: 399
v=0
s=session
t=0 0
a=rtpmap:3 GSM/8000
a=fmtp:101 0-16
a=silenceSupp
Sent:
CSeq: 102 INVITE
Content-Length: 0
Received:
CSeq: 102 ACK
Content-Length: 0
Calling Number :
Destn SIP Req Addr
Destn SIP Resp Addr
