[Frage] sip trunk with multiple numbers, how to separate them
binary_dreamer
24 Jul 2009
hi. my ISP gives me voip through its adsl and it offers a registration string and a bunch of numbers under the same registration.
I had that registered in fritzbox and i cannot find how to separate the DDIs that are under that registration.
i thought that something is wrong in that trunk and i gave it a try in a ASTERISK 1.8 testbox that i have. Fortunatelly everything is ok for the trunk and i can separate each number for each extension.
all i would like to have is 2 numbers in each of the fxs port of the fritzbox and 4 numbers in the sip extensions of the fritzbox. i do not want to use the asterisk box, but only the fritzbox. is that possible please?
the fritzbox is a 7270v3
rehe992
