Siptraffic.com neuer Anbieter von Finarea
Bei mir hat es mit siptraffic funktioniert eine CallerID zu setzen. Man muss auf deren Website in den Einstellungen die IP des eigenen SIP-Clients angeben - dann gehts.
I cant write German. But read it. So you can reply to me in German.
Do i understand this correct ? You only set the IP adres in there web interface ?
So under Other options/IP config/ IP-address ? And then leave the username and password ? And also set the Outbound CID for the Extentions i think ?
Like "Name" <your number> is that correct ?
Thanx It works for me !!!!!! Great so simple :-))))))))))))))))
For Outbound CID use for Germany 0049xxxxxx x =your number 0049 Code Germany if needed LOL ... ppfff ..
Yes you are right.
[voicetrading]
qualify = yes
type = friend
canreinvite = no
insecure=port,invite
host=[your_IP-adress]
disallow=all
allow=g729
allow=ulaw
FraSche
