Skype für OS X: Aktuelle Version 1.3.0.17 (25.10.2005)
  • Ersteller Ersteller Staubsauger
S
Staubsauger
Guest
Zu finden hier: http://www.skype.com/products/skype/macosx/
Zusätzlich gibt es jetzt noch ein Widget, mit dem man direkt wählen kann sowie Skype Out-Raten abfragen kann.
Skype for Mac OS X Change Log
08.09.2005 Skype for Mac OS X version 1.3.0.8
* new feature: events and services module in the main window
* new feature: in "Do Not Disturb" mode new incoming chat's are not opened in chat window(s)
* new feature: online status set to AWAY when screensaver starts
* new feature: option to show online contacts only
* new feature: red badge of missed events on the dock icon
* new feature: return values for Skype API AppleScript interface
* new feature: tooltips in contact list
* new feature: unread chats count
* new feature: drag & drop contacts from contact list to chat to add them to the chat
* improvement: use Safari's download folder for incoming FT if user has not specified other
* improvement: some Emoticon definitions have been changed to be compatible with other platforms
* improvement: added Call one Member, Chat with one Member submenus to MC drawer views
* improvement: "Add Users to Chat" sheet is now resizable
* improvement: bookmarked chats now sorted alphabetically
* improvement: my profile area in the chat window drawer slightly improved
* improvement: new buttons in "Add Users to Chat" sheet
* improvement: Skype API: BTN_RELEASED 0123456789*# gives focus to the address field, while "BUTTON UP/DOWN" gives focus to the contacts list (or call list).
* improvement: Skype API: when there is no call going on, BTN_RELEASED NO deletes last character from the address line
* Improvement: you can now associate up to three e-mail addresses with your account (enter them in the "Edit Profile" window)
* change: removed My Skype tab
* change: "Edit Profile" window layout updated
* change: alert panel when going into "Do Not Disturb" mode
* change: updated online status pop-up menu
* change: when Skype is the active application, then a click on the dock icon always brings the main window to front
* bugfix: "@" was shown as mailto link in chats
* bugfix: chat window popped up when online status was "Do Not Disturb"
* bugfix: cmd-W, cmd-shift-W in chat windows now work like in Safari
* bugfix: improved handling of +####### in chats
* bugfix: password was not remembered, when user set the preference in the preference panel (not in the login dialog)
* bugfix: phone numbers including letters, a la "+1800IWANTPIZZA", are converted properly now
* bugfix: remote profile panel shows now homepage as link
* bugfix: runs also on Mac OS X 10.3.0 - 10.3.8
* bugfix: Skype API: HOOK OFF answers incoming call
* bugfix: Skype API: HOOK ON clears the address field
* bugfix: Skype API: HOOK ON hangs up ongoing call
* bugfix: Skype API: implemented GET/SET AUDIO_IN/AUDIO_OUT
* bugfix: Skype API: implemented MINIMIZE and HIDE
* bugfix: Skype crashed sometimes, when trying to make a conference call and the number of a participant was invalid
* bugfix: Skype didn't respect "hide on Mac OS X login" setting
* bugfix: sometimes accepting an incoming conference call put it on hold
OK, das hat noch in der Sammlung gefehlt :-)
Dann mach ich das auch mal zum "Wichtig". Wobei das so langsam ein bißchen viele "Wichtig" werden. Mal überlegen, ob man das nicht übersichtlicher gestalten kann...
PS
Das Apfel-Icon finde ich gut! Endlich mal eine sinnvolle Anwendung für diese Icons.
Gerade erst festgestellt, daß die Mac-Version ja auch schon längst weiter ist.
25.10.2005 Skype for Mac OS X version 1.3.0.17
* bugfix: fixed a bug in networking code that made Skype vulnerable to remotely induced crash (Skype Security Bulletin SKYPE-SB/2005-003)
05.10.2005 Skype for Mac OS X version 1.3.0.14
* improvement: support for new Skype buttons
densen420
