Skype for PPC: Aktuelle Beta 1.2 (15.12.2005)
RB
Aktives Mitglied
22 Jun 2004
Download-Möglichkeit hier, wie immer.
Change Log
15.12.2005 Skype for Pocket PC™ 1.2 beta
* change: Windows Mobile 5.0 supported
* change: devices with 300+ MHz CPU supported. Skype will not operate on devices with ~300MHz CPU while using an external WiFi card
* change: landscape mode support and support for 240x240 and 480x480 screens
* change: new languages (Danish, Dutch, Italian, Japanese, Korean, Norwegian, Portuguese Brazil, Russian, Spanish, Swedish)
* change: languages updated
* feature: automatic language selection depending on regional settings of the device
* change: new EULA text
* feature: call forwarding icon added
* bugfix: authorization stayed pending for receiver
* bugfix: incoming calls when rejected were not sent to VM
* bugfix: incoming calls were not sent to Voicemail after timeout
* bugfix: send Voicemail to SkypeOut user was allowed in log tab
* bugfix: impossible to add SkypeIn number from log tab to contact list
* bugfix: impossible to remove missed call notification in start menu
* bugfix: “Cannot execute Skype.exe” notification appeared when Skype installed on external storage
Am 14.02.2006 wurde eine neue Version veröffentlicht und zwar 2.0.0.51.
Gruss Fabian
Jetzt gibts die Beta 2.1.0.57.
Meiner Meinung nach lohnt es sich upzudaten.
Hier die Änderungen seit Februar:
18.09.2006 Skype for Pocket PC 2.1.0.57 Beta (Pocket PC)
  • feature: Added sounds for events (different depending on event type)
  • feature: Added user setting to turn sound on/off
  • bugfix: Username is not displayed in profile
  • bugfix: Contact names not trunkated in call history
  • bugfix: Impossible to log in with just created username
  • bugfix: Software Input Panel coveres Add Contact Dialogs
  • bugfix: Scrollbar not created in Login page
  • bugfix: 'Enter' displayed as boxes in mood message
  • bugfix: Call hold' status not displayed in conference call
  • bugfix: can't install .exe on ActiveSync 3.8
  • bugfix: received ContactList was is closed after contacts are added
  • bugfix: Disable 'Add contact' button in received contacts dialog when no selection
  • bugfix: Optimized drawing of startview for faster scrolling, also added auto-detect of avatar change
  • bugfix: Changed error message when trying to call 'unknown number' using green toolbar button
  • bugfix: Incorrect icon for received Contacts list
  • bugfix: Cannot use via PHS
  • bugfix: Received ContactList contacts area is not dynamic
  • bugfix: 'Show profile' not disabled in Call menu for SkypeOut contacts
  • bugfix: Capitalized text for Voicemail event in status tab
  • bugfix: Save greeting message text in authorization request dialog
  • bugfix: Add participants list does not contain all contacts from Contacts tab in Chat dialog
  • bugfix: Use 'Call' instead of 'Call Skype name'.
  • bugfix: Conference call clients avatar are too close vertically
  • bugfix: Left soft key Call button disabled sometimes in Contacts tab.
  • bugfix: Call button enabled when wifi is off or user status is offline.
  • bugfix: Removed connectivity description in the end of EULA
  • bugfix: Skype dialer doesn't work for 2003 OS.
  • bugfix: Long real names not displayed properly in Conference Call.
  • bugfix: Domain name validity not checked for e-mail address.
  • bugfix: Light up device screen when new call is received.
  • bugfix: Call duration not updated when scrollbar is created to Call tab
  • bugfix: The Software Input Panel is placed wrongly sometimes in chatdlg.
  • bugfix: Chat button enabled during login
15.08.2006 Skype for Pocket PC 2.1.0.53 Beta (Pocket PC)
  • feature: Multi-chat support
  • feature: SkypeIn support
  • feature: Voicemail support
  • feature: Call forwarding support
  • feature: Profile editing
  • feature: Detailed search
  • feature: Contact list information with avatar and mood messages support
  • feature: Improved chat-more emoticons and 'set topic' ability
  • feature: Animated emoticons
  • feature: Skype Launcher
  • feature: GSM and Skype callsmanagement
  • feature: Larger Dial Pad and delete button in Dial Pad
  • feature: Online help
  • feature: One click access to Skype from the device home screen
  • change: Contact list sorting
  • bugfix: Saved SkypeOut contacts are shown without their name in the Log tab
  • bugfix: VM sender Skype name is displayed instead of the real name
  • bugfix: Chat partner username instead of the real name displayed in tab head
  • bugfix: 'Clear Log' doesn't work for unknown SI call
  • bugfix: Call duration is only in minutes:seconds
  • bugfix: Search enabled while offline
  • bugfix: 'Hold' is enabled, when the call is already on hold
  • bugfix: Call 'hold' is allowed before call is answered
  • bugfix: 'Hold' reminds checked with new conference call
  • bugfix: Possible to send just space in chat
  • bugfix: Overlapped notifications on Start tab
  • bugfix: Contact names are overlapped in Contact list
  • bugfix: Allow calls and allow chats menus are empty while signed out
  • bugfix: Scrollbar doesn't reach the end in Call log
  • bugfix: Selected privacy option not updated first time
  • bugfix: Title bar notifications are not removed after signing out
  • bugfix: Incoming chat will create notification when some dialog is open
  • bugfix: Offline icon changes to pending for contact who hasn't been online for a long time
  • bugfix: Call duration is delayed for longer calls while browsing other programs at the same time
Kriegt jemand über Bluetooth eine anständige Skype Verbindung?
cld
