Skype for Windows: Aktuelle BETA 2.0.0.63 (20.12.2005)
RB
Aktives Mitglied
22 Jun 2004
Moin zusammen!
Seit heute gibt es die Beta der neuen Version 2.0 bei Skype.com als Download.
Change Log
1.12.2005 version 2.0.0.43 beta
* feature: Skype video (webcam)
* feature: contact grouping
* feature: quickfilter in contact list and history (enable from Options->Advanced)
* feature: new language - Portuguese (Portugal)
* feature: new sound events for chat user join, leave and incoming message to existing chat
* feature: chats and conference calls shown in history
* feature: expandable "My Panel" (mood, events, services integrated)
* feature: add contact directly from main window
* feature: show file transfers in history
* feature: quickfilter in history
* feature: delete single or multiple history items
* feature: compact chat participant list
* feature: save user's last auth request
* feature: API commands GET/SET PCSPEAKER
* feature: API commands BTN_RELEASED PAGEUP/PAGEDOWN
* feature: API command SET VIDEO_IN <devicename>
* change: auth requests new design
* change: changed group selection hotkeys to Ctrl-PgUp/PgDn
* change: call tab visual layout changed
* change: UI design elements changes
* change: tray icon flag animation on missed events
* change: tray icon connecting animation
* change: changed "Free Internet Telephony" to "The whole world can talk for free" in file description
* change: import contacts error dialog displayed when there is nowhere to import contacts from
* change: file transfer in DND mode open file transfer dialog in minimized mode
* change: new installer and uninstaller icons
* change: history limited to 30 days for all events
* change: new login animation
* change: new layout for sound options
* change: show my buddy count as an option in profile
* change: new design for user creation
* change: new design for log in
* change: main/tools menu reshuffled
* change: new sounds
* change: display full name in profile
* bugfix: drag and drop to chat - whole window should accept target
* bugfix: accessibility: tab navigation on login dialog
* bugfix: missing window title string for remove group dialog
* bugfix: MSAA result codes on lists
* bugfix: accessibility: can't navigate to related tasks in options
* bugfix: accessibility: advanced settings not accessible by tab
* bugfix: accessibility: make 'Your e-mail will be kept private...' link accessible
* bugfix: 98/Me: some languages in EULA not shown
* bugfix: doubleclick on tray icon brings main form to top correctly
* bugfix: JPY sign not displayed in client
* bugfix: import contacts search made faster
* bugfix: Voicemail was not played if enter is pressed
* bugfix: low credit notification improved
* bugfix: voicemail menu item should be visible for non voicemail subscribers
* bugfix: login - save button should be disabled, if one password is unfilled
* bugfix: login - incorrect error message, if Skype Name starts with non-Latin letter
* bugfix: Skype UI doesn't follow Windows DPI changes
* bugfix: accessibility: speed dial announcement not reported via MSAA
* bugfix: contact list - delete does not work on multiselect
* bugfix: API notifications missing
* bugfix: add a contact and search are not changed maximize on dual-head
* bugfix: My Profile - each month contains 30 days
* bugfix: call forwarding and voicemail statuses in MSAA
* bugfix: profile view: not been online for long time?
* bugfix: chat participant list MSAA support
* bugfix: multichat doesn't update names when contacts change them
* bugfix: invalid date in profile
* bugfix: profile: Default day item in birthday dropdown
* bugfix: hotkeys value not changeable back to 'blank'
* bugfix: better usability of several forms with high dpi settings
* new language files: Portuguese (Portugal) - Francisco Miguel Oliveira Ferreira, Arabic - (Maktoob.com Inc), Bulgarian - (Nikolay Filipov, Nikolina Filipova), Chinese Traditional - (Morden Chen/PChome Online), Chinese Simplified - (Leon Yang/TOM Online), Danish - (Eriksen Translations Inc), Dutch - (Kees Koenders), Czech - (Petr Silon), Estonian - (Eve Loopere), Finnish - (Heino Keränen), French - (Fabrice Imperial), German - (Claudius Henrichs & Dick Schiferli), Greek - (Panagiotis Sidiropoulos/Magenta LTD), Hungarian - (Mark Bender), Italian - (Daniele Conte), Korean - (Eriksen Translations Inc), Norwegian - (Stig Auestad), Polish - (Karol Szastok), Swedish - (Anders Olsson)
Neue Version vom 20.12.2005
Change Log
20.12.2005 version 2.0.0.63 beta
* feature: dropping file onto calltab initiates FT
* change: included "Classic" sounds in Sounds Options
* change: video not supported messages for Win98/2000
* change: mood message removed from profile
* bugfix: error messages when webcam in use or not detected
* bugfix: can't send contacts to muptiple users.
* bugfix: memory leak in conference calls
* bugfix: History - Click on sent file opens C:
* bugfix: 98/Me: Cannot drag and drop files to send
* bugfix: call error descriptions were not displayed
* bugfix: installer only deletes default avatars
* bugfix: API - add OPEN VIDEOTEST command
* bugfix: Avatar selection opens slowly
* bugfix: Accessibility - call status is not available for screen reader
* bugfix: Accessibility - MSAA State_System_Selected not set accurately in lists
* bugfix: redialling number after new number input
* bugfix: logic of blocking and adding users
* bugfix: adding SO number - the old dialog opens
* bugfix: updates language files
* bugfix: icons shown when contact not expanded
* bugfix: Addressbar unicode support
* bugfix: unknown number no avatar
* bugfix: emoticon list does not scroll with divider
* bugfix: range check error on some mood messages
* bugfix: hanging up voicemail from non-call tab
* bugfix: events panel sizing
* bugfix: updated EULA text (German version)
* bugfix: addressbar is not cleared, if you delete some kind of event from history
* bugfix: scrollbar covers the chat participants right edge
* bugfix: wrong confirmation text if selected calls are deleted
* bugfix: 98/Me - another username appears on input field
* bugfix: Import Contacts suggests to invite contacts that are already in my CL
* bugfix: eventspanel texts had different font size if system font size was changed from large to normal
* bugfix: high DPI (125% and higher) messed up the contactlist view
Beta-Phase am 05.01.2006 beendet...
ehg47
