Skype for Windows: Aktuelle Version 2.0.0.69 (05.01.2006)
RB
Aktives Mitglied
22 Jun 2004
Ist hier zu bekommen
und das komplette Change Log für die Version 2
05.01.2006 version 2.0.0.69
  • feature: Skype video (webcam)
  • feature: contact grouping
  • feature: quickfilter in contact list and history (enable from Options->Advanced)
  • feature: new language - Portuguese (Portugal)
  • feature: new sound events for chat user join, leave and incoming message to existing chat
  • feature: chats and conference calls shown in history
  • feature: expandable "My Panel" (mood, events, services integrated)
  • feature: add contact directly from main window
  • feature: show file transfers in history
  • feature: quickfilter in history
  • feature: delete single or multiple history items
  • feature: compact chat participant list
  • feature: save user's last auth request
  • feature: API commands GET/SET PCSPEAKER
  • feature: API commands BTN_RELEASED PAGEUP/PAGEDOWN
  • feature: API command SET VIDEO_IN <devicename>
  • feature: dropping file onto calltab initiates FT
  • change: auth requests new design
  • change: changed group selection hotkeys to Ctrl-PgUp/PgDn
  • change: call tab visual layout changed
  • change: UI design elements changes
  • change: tray icon flag animation on missed events
  • change: tray icon connecting animation
  • change: changed "Free Internet Telephony" to "The whole world can talk for free" in file description
  • change: import contacts error dialog displayed when there is nowhere to import contacts from
  • change: file transfer in DND mode open file transfer dialog in minimized mode
  • change: new installer and uninstaller icons
  • change: history limited to 30 days for all events
  • change: new login animation
  • change: new layout for sound options
  • change: show my buddy count as an option in profile
  • change: new design for user creation
  • change: new design for log in
  • change: main/tools menu reshuffled
  • change: new sounds
  • change: display full name in profile
  • change: included "Classic" sounds in Sounds Options
  • change: video not supported messages for Win98/2000
  • change: mood message removed from profile
  • bugfix: drag and drop to chat - whole window should accept target
  • bugfix: accessibility: tab navigation on login dialog
  • bugfix: missing window title string for remove group dialog
  • bugfix: MSAA result codes on lists
  • bugfix: accessibility: can't navigate to related tasks in options
  • bugfix: accessibility: advanced settings not accessible by tab
  • bugfix: accessibility: make 'Your e-mail will be kept private...' link accessible
  • bugfix: 98/Me: some languages in EULA not shown
  • bugfix: doubleclick on tray icon brings main form to top correctly
  • bugfix: JPY sign not displayed in client
  • bugfix: import contacts search made faster
  • bugfix: Voicemail was not played if enter is pressed
  • bugfix: low credit notification improved
  • bugfix: voicemail menu item should be visible for non voicemail subscribers
  • bugfix: login - save button should be disabled, if one password is unfilled
  • bugfix: login - incorrect error message, if Skype Name starts with non-Latin letter
  • bugfix: Skype UI doesn't follow Windows DPI changes
  • bugfix: accessibility: speed dial announcement not reported via MSAA
  • bugfix: contact list - delete does not work on multiselect
  • bugfix: API notifications missing
  • bugfix: add a contact and search are not changed maximize on dual-head
  • bugfix: My Profile - each month contains 30 days
  • bugfix: call forwarding and voicemail statuses in MSAA
  • bugfix: profile view: not been online for long time?
  • bugfix: chat participant list MSAA support
  • bugfix: multichat doesn't update names when contacts change them
  • bugfix: invalid date in profile
  • bugfix: profile: Default day item in birthday dropdown
  • bugfix: hotkeys value not changeable back to 'blank'
  • bugfix: better usability of several forms with high dpi settings
  • bugfix: error messages when webcam in use or not detected
  • bugfix: can't send contacts to muptiple users.
  • bugfix: memory leak in conference calls
  • bugfix: History - Click on sent file opens C:
  • bugfix: 98/Me: Cannot drag and drop files to send
  • bugfix: call error descriptions were not displayed
  • bugfix: installer only deletes default avatars
  • bugfix: API - add OPEN VIDEOTEST command
  • bugfix: Avatar selection opens slowly
  • bugfix: Accessibility - call status is not available for screen reader
  • bugfix: Accessibility - MSAA State_System_Selected not set accurately in lists
  • bugfix: redialling number after new number input
  • bugfix: logic of blocking and adding users
  • bugfix: adding SO number - the old dialog opens
  • bugfix: updates language files
  • bugfix: icons shown when contact not expanded
  • bugfix: Addressbar unicode support
  • bugfix: unknown number no avatar
  • bugfix: emoticon list does not scroll with divider
  • bugfix: range check error on some mood messages
  • bugfix: hanging up voicemail from non-call tab
  • bugfix: events panel sizing
  • bugfix: updated EULA text (German version)
  • bugfix: addressbar is not cleared, if you delete some kind of event from history
  • bugfix: scrollbar covers the chat participants right edge
  • bugfix: wrong confirmation text if selected calls are deleted
  • bugfix: 98/Me - another username appears on input field
  • bugfix: Import Contacts suggests to invite contacts that are already in my CL
  • bugfix: eventspanel texts had different font size if system font size was changed from large to normal
  • bugfix: high DPI (125% and higher) messed up the contactlist view
  • new language files: Portuguese (Portugal) - Francisco Miguel Oliveira Ferreira, Arabic - (Maktoob.com Inc), Bulgarian - (Nikolay Filipov, Nikolina Filipova), Chinese Traditional - (Morden Chen/PChome Online), Chinese Simplified - (Leon Yang/TOM Online), Danish - (Eriksen Translations Inc), Dutch - (Kees Koenders), Czech - (Petr Silon), Estonian - (Eve Loopere), Finnish - (Heino Keränen), French - (Fabrice Imperial), German - (Claudius Henrichs & Dick Schiferli), Greek - (Panagiotis Sidiropoulos/Magenta LTD), Hungarian - (Mark Bender), Italian - (Daniele Conte), Korean - (Eriksen Translations Inc), Norwegian - (Stig Auestad), Polish - (Karol Szastok), Swedish - (Anders Olsson)
IDfour
