Skype for Windows: Neue Version 1.3.0.51 (22.06.2005)
kossy
Aktives Mitglied
24 Apr 2004
Unter www.skype.com gibts mal wieder eine neue Version zum Download.
18.06.2005 version 1.3.0.48
* bugfix: if e-mail field was empty in profile, Skype generated excessive traffic under some circumstances
13.06.2005 version 1.3.0.45
* known issue: when you have chatted a lot, new version startup might
take several minutes
* feature: improved Contact Importers
* feature: Voicemail subscribers can leave voicemails to anyone
* feature: animated emoticons
* feature: missed events panel
* feature: services panel
* feature: possibility to send multiple authorization requests from one window
* feature: Arabic (Eriksen Translations based on Skype user ketkat-666 translation), Hungarian (Peter Simon), Bulgarian (Nikolina Filipova & Nikolay Filipov), Czech (Petr Silon) and Turkish (Emin Dede) languages added
* feature: improved Profile
* feature: main menu -> help -> Getting Started Wizard
* feature: automatically answer the call option is back
* change: VM options visible to everyone
* change: Receive contacts: requesting authorization through one
single form
* change: removed calltab toolbar
* change: added hold and mute buttons to main toolbar
* change: improved chats and calls connectivity behind proxy
* change: improved logging in behind proxy
* change: improved Central Contact List
* change: if a SkypeIn call is sent to voicemail, custom greeting is
played
* change: new splash and About images
* change: updated translations in Chinese Simplified (TOM Online), Chinese Traditional (PChome Online), Swedish (Anders Olsson), Finnish (Heino Keränen), Danish (Mathias Schwarz), Norwegian (Stig Auestad), German (Claudius Henrichs & Dick Schiferli), Dutch (Kees Koenders), French (Fabrice Imperial), Italian (Conte Daniele), Greek (Magneta Ltd, Panagiotis Sidiropoulos), Japanese (Livedoor), Hebrew (Ronen Ben-Naftali), Russian (Viktoria Randalainen), Romanian (Paraschiv Ion), Polish (Karol Szastok), Spanish (Angel Dominguez Jimenez), Portuguese Brazil (Carlos Pires and Anna Christina Nyström)
* bugfix: current status is disabled in onlinestatus selector menus
* bugfix: File Transfer toolbar button disabled if address bar does
not contain valid Skype Name
* bugfix: range check errors when moving window on dual-monitor setup
* bugfix: accessibilty — extra large fonts support improved
* bugfix: some login and startup related issues cleared
* bugfix: could not bookmark a chat without topic
* bugfix: rare access violation in 'Manage blocked users'
* bugfix: multiple language support in search
* bugfix: trayicon did not always respond correctly to doubleclicks
* bugfix: close the search tab if no results found
* bugfix: status not updated when USB phone is used
* bugfix: options: Sound Alert keeps playing
* bugfix: call history context menu 'listen' is now visible only on
voicemails
Na Super,habe die neue Version inzwischen,mir fiel aber beim reinen "Palabbern" nichts auf,was nun unbedingt eine Verbesserung erbracht hätte.
Habe ich etwas übersehen?
Gruß von Tom
Da es derzeit mit den neuen Versionen recht schnell geht habe ich den Titel einfach mal nacheditiert.
Change Log
22.06.2005 version 1.3.0.51
change: Added new translations and language files
bugfix: Changed icon for "Clear Call List" in context menu
bugfix: API: Removed item from manage API access control dialog
bugfix: Contacts sometimes appear as "Online" when they are not actually connected
Quelle und Download: www.skype.com
Die überschlagen sich ja (zumindest bei der Windows-Variante) :shock:
Das ist ja das Komische,sollen mal lieber ein SIP-Gateway schaffen,das wäre ein großer Fortschritt!
Gruß von Tom
jrf
