Smartnode 4520 Eingehende Nummer wird nicht angezeigt.
nativenoble
6 Aug 2012
Hi wir haben die Smartnodes ganz neu und sind schon ganz froh das sie soweit laufen. Jetzt haben wir noch das Problem das die eingehende Nummer nicht angezeigt wird. Hat hier vielleicht jemand einen Rat ??
# SN4524/JO/EUI                                                  #
cli version 3.20
webserver port 80 language en
system
  ic voice 0
    low-bitrate-codec g729
profile napt NAPT
profile ppp default
profile tone-set default
profile voip default
  codec 1 g729 rx-length 20 tx-length 20
  codec 2 g711alaw64k rx-length 20 tx-length 20
  codec 3 g711ulaw64k rx-length 20 tx-length 20
  fax transmission 1 relay t38-udp
profile pstn default
profile sip default
profile dhcp-server DHCP
profile aaa default
  method 1 local
  method 2 none
context ip router
  interface eth0
# SET on the line below the IP address of this SmartNode
    ipaddress 172.20.11.240 255.255.255.0
    use profile napt NAPT
    tcp adjust-mss rx mtu
    tcp adjust-mss tx mtu
  interface eth1
    ipaddress 192.168.0.1 255.255.255.0
context ip router
# SET on the line below the default gateway`s IP address
  route 0.0.0.0 0.0.0.0 172.20.11.1 0
context cs switch
  routing-table called-e164 fromFxo0
    route default dest-interface SIP_CPE setCdPN200
  routing-table called-e164 fromFxo1
    route default dest-interface SIP_CPE setCdPN201
  routing-table calling-e164 DEMUX
    route 200 dest-interface Line0
    route 201 dest-interface Line1
  mapping-table called-e164 to called-e164 setCdPN200
    map default to 200
  mapping-table called-e164 to called-e164 setCdPN201
    map default to 201
  interface sip SIP_CPE
    bind context sip-gateway GW_SIP
    route call dest-table DEMUX
#SET on the line below the IP of the other SmartNode
    remote 172.20.11.241
  interface fxo Line1
    route call dest-table fromFxo1
    disconnect-signal loop-break
    ring-number 1
    dial-after timeout 1
    no use profile tone-set
  interface fxo Line0
    route call dest-table fromFxo0
    ring-number 1
context cs switch
  no shutdown
  no shutdown
  interface SIP
    bind interface eth0 context router port 5060
  no shutdown
port ethernet 0 0
  medium auto
  encapsulation ip
  bind interface eth0 router
  no shutdown
port ethernet 0 1
  medium auto
  encapsulation ip
  bind interface eth1 router
  no shutdown
port fxo 0 0
  encapsulation cc-fxo
  bind interface Line0 switch
  no shutdown
port fxo 0 1
  bind interface Line1 switch
  no shutdown
und
cli version 3.20
system
  ic voice 0
profile napt NAPT
profile ppp default
profile ringing-cadence default
  play 1 1000
  pause 2 4000
profile sip default
profile aaa default
  method 1 local
  method 2 none
context ip router
  interface eth0
    ipaddress 172.20.11.241 255.255.255.0
  interface eth1
context ip router
context cs switch
  routing-table called-e164 DEMUX
    map default to 200
    map default to 201
    remote 172.20.11.240
  interface fxs Line0
    route call dest-interface SIP_CPE
    caller-id-presentation pre-ring
    subscriber-number 200
  interface fxs Line1
    subscriber-number 201
context cs switch
  no shutdown
  interface SIP
  no shutdown
port ethernet 0 0
  medium auto
  encapsulation ip
  no shutdown
port ethernet 0 1
  medium auto
  encapsulation ip
  no shutdown
port fxs 0 0
  encapsulation cc-fxs
  no shutdown
port fxs 0 1
  no shutdown
Danke schon mal !!!
Achso was ich vielleicht vergessen hab es handelt sich um eine Analog Line Extension
holh-66
