SN 4554 an Toplink PBX
chili_666
30 Jul 2008
ich versuche verzweifelt meinen Patton SN4554 an unserer Toplink PBX zu registrieren - aber anscheinend bin ich zu dämlich dazu. Der SmartNode soll eigentlich nichts weiter machen, als unser Fax weiterzuversorgen.
Anbei mal die akutelle Konfig des Pattons:
# SN4554/2BIS/EUI                                                #
# R5.2 2008-11-14 SIP                                            #
# 1970-01-01T01:05:33                                            #
# SN/00A0BA041A9F                                                #
# Generated configuration file                                   #
cli version 3.20
gui type basic
clock local offset +01:00
dns-client server 192.168.1.51
dns-client server 212.126.196.211
dns-client server 212.126.196.212
dns-relay
webserver port 80 language en
sntp-client
sntp-client server primary 0.de.pool.ntp.org port 123 version 4
system
  ic voice 0
system
  clock-source 1 bri 0 0
  clock-source 2 bri 0 1
profile service-policy SP_WAN_OUT
  no rate-limit
profile service-policy SP_WAN_IN
  no rate-limit
profile napt NAPT_WAN
profile ppp default
profile tone-set default
profile voip default
  codec 1 g711alaw64k rx-length 20 tx-length 20
  codec 2 g711ulaw64k rx-length 20 tx-length 20
profile voip VOIP
  codec 1 g729 rx-length 20 tx-length 20
  codec 2 g711alaw64k rx-length 20 tx-length 20
  codec 3 g711ulaw64k rx-length 20 tx-length 20
  dejitter-mode static
  dejitter-max-delay 120
  fax transmission 1 relay t38-udp
profile pstn default
profile sip default
profile dhcp-server DHCPS_LAN
  network 192.168.1.13 255.255.255.0
  default-router 1 192.168.1.13
  domain-name-server 1 192.168.1.13
profile aaa default
  method 1 local
  method 2 none
context ip router
  interface IF_IP_WAN
    ipaddress 192.168.1.13 255.255.255.0
    tcp adjust-mss rx mtu
    tcp adjust-mss tx mtu
  interface IF_IP_LAN
    ipaddress unnumbered
context ip router
  route 0.0.0.0 0.0.0.0 192.168.1.51 0
  route 0.0.0.0 0.0.0.0 IF_IP_WAN 0
subscriber ppp SUB_PPPOE
  dial in
  no multilink
context cs switch
  interface isdn IF_S0_00
    route call dest-interface IF_SIP_SERVICE
  interface isdn IF_S0_01
  interface sip IF_SIP_SERVICE
    bind context sip-gateway GW_SIP
    route call dest-interface IF_S0_00
    use profile voip VOIP
  service hunt-group SER_HG_PSTN_FALLBACK
    drop-cause normal-unspecified
    drop-cause no-circuit-channel-available
    drop-cause network-out-of-order
    drop-cause temporary-failure
    drop-cause switching-equipment-congestion
    drop-cause access-info-discarded
    drop-cause circuit-channel-not-available
    drop-cause resources-unavailable
    route call 1 dest-interface IF_SIP_SERVICE
context cs switch
  no shutdown
authentication-service AUTH_SVC
  realm # ##
  username ## password ########= encrypted
location-service LOCATION_SVC
  domain 1 d#########.tplpbx.de 5060
  identity-group default
    registration outbound
      registrar d#########.tplpbx.de 5060
      proxy 1 d#########.tplpbx.de
      lifetime 3600
      register auto
      retry-timeout on-system-error 10
      retry-timeout on-client-error 10
      retry-timeout on-server-error 10
    call outbound
      proxy 1 d#########.tplpbx.de 5060
    call inbound
  identity 40 inherits default
    bind interface IF_IP_WAN context router port 5060
  bind location-service LOCATION_SVC
  no shutdown
port ethernet 0 0
  bind interface IF_IP_WAN router
  pppoe
    session SES_PPPOE
      shutdown
port ethernet 0 0
  no shutdown
port bri 0 0
  clock auto
  encapsulation q921
  q921
    uni-side auto
    encapsulation q931
    q931
      protocol dss1
      uni-side user
      bchan-number-order ascending
      encapsulation cc-isdn
      bind interface IF_S0_00 switch
port bri 0 0
  no shutdown
port bri 0 1
  clock auto
  encapsulation q921
  q921
    uni-side auto
    encapsulation q931
    q931
      protocol dss1
      uni-side user
      bind interface IF_S0_01 switch
port bri 0 1
  no shutdown
Der Support von Toplink meinte ich bräuchte zwingend die FW 5.2 um den Patton ans Laufen zu bekommen. Eigentlich schade, denn mit der FW 4.2 konnte ich mich zumindest registrieren.
Der Patton hängt derzeit im Status immer bei "Registering", taucht auch nicht als REG in der PBX auf und das VOIP-LED blinkt fleissig.
Wäre nett, wenn jemand mal kurz über die Konfig gucken kann und mich in die richtige Richtung schubst.
Vielen, vielen Dank schonmal....
Chili_666
Ich kann dir nur als Beispiel die Config von uns für das Verbinden zu Sipgate geben, vielleicht findest du da nette Optionen. Ich hab gerade FW 5.3...
  interface sip IF_SIP_MESSER
    bind context sip-gateway GW_SIPGATE
    route call dest-table RT_SIPEXT_2_INT
    remote sipgate.de
    local sipgate.de
    early-connect
    early-disconnect
    privacy
    address-translation outgoing-call from-header user-part fix 18954321 host-part call
    address-translation outgoing-call identity-header user-part fix 0892345234 host-part call
    use profile voip VOIP_SIPGATE
    use profile sip sipgate
LM1818
