snom 360 & asterisk
sascha45
4 Jun 2005
hallo,
ich habe ein snom 360 an meinem asterisk. telefon rein raus gehen. auch das anzeigen der verbindungen im lokalen netz über <hint> (blinken, bei anruf, leuchten bei besteheneder verbindung.
nun will ich einen auruf übernehem und lege mir da die karten irgendwo ist eindenkfehler drin
hier erstmal die config:
[Edit foschi: nach 111 Postings sollte man die Nutzung des code-tags beherrschen...]
df9xj*CLI> show hints
    -= Registered Asterisk Dial Plan Hints =-
   99                  : sip/phone99           State:Idle            Watchers  1
   6                   : sip/phone6            State:Idle            Watchers  1
   5                   : sip/phone5            State:Idle            Watchers  1
   4                   : sip/phone4            State:Idle            Watchers  1
   2                   : sip/phone2            State:Idle            Watchers  0
   1                   : sip/phone1            State:Idle            Watchers  1
192.168.2.101    phone96     3c26701e211  1                Idle           dialog-info+xml
192.168.2.101    phone96     3c26701e21a  4                Idle           dialog-info+xml
192.168.2.101    phone96     3c26701e21e  5                Idle           dialog-info+xml
192.168.2.101    phone96     3c26701e223  6                Idle           dialog-info+xml
192.168.2.101    phone96     3c26701e22b  99               Idle           dialog-info+xml
5 active SIP subscriptions
features.conf:
; Sample Parking configuration
[general]
parkext => 700                  ; What ext. to dial to park
parkpos => 701-720              ; What extensions to park calls on
context => parkedcalls          ; Which context parked calls are in
parkingtime => 45               ; Number of seconds a call can be parked for (default is 45 seconds)
;transferdigittimeout => 3      ; Number of seconds to wait between digits when transfering a call
;transferdigittimeout => 3      ; Number of seconds to wait between digits when transferring a call
;courtesytone = beep            ; Sound file to play to the parked caller
                                 ; when someone dials a parked call
;xfersound = beep               ; to indicate an attended transfer is complete
;xferfailsound = beeperr        ; to indicate a failed transfer
;adsipark = yes                 ; if you want ADSI parking announcements
pickupexten = *8                ; Configure the pickup extension.  Default is *8
;featuredigittimeout = 500      ; Max time (ms) between digits for
                                ; feature activation.  Default is 500
[featuremap]
blindxfer => #1                 ; Blind transfer, default is #
;disconnect => *0               ; Disconnect (for attended transfer)
automon => *1                   ; One Touch Record
atxfer => *2                    ; Attended transfer
beim snoom 192.168.2.101
<sip:[email protected];user=phone>
asterisk config:
df9xj*CLI> sip show peer phone96
df9xj*CLI>
  * Name       : phone96
  Secret       : <Not set>
  MD5Secret    : <Not set>
  Context      : local
  Subscr.Cont. : local
  Language     : de
  Accountcode  : phone96
  AMA flags    : Unknown
  CallingPres  : Presentation Allowed, Not Screened
  Callgroup    :
  Pickupgroup  :
  Mailbox      : 96
  VM Extension : asterisk
  LastMsgsSent : 256
  Call limit   : 0
  Dynamic      : Yes
  Callerid     : "phone96" <96>
  Expire       : 395961
  Insecure     : no
  Nat          : RFC3581
  ACL          : No
  CanReinvite  : Yes
  PromiscRedir : No
  User=Phone   : No
  Trust RPID   : No
  Send RPID    : No
  DTMFmode     : rfc2833
  LastMsg      : 0
  ToHost       :
  Addr->IP     : 192.168.2.101 Port 2048
  Defaddr->IP  : 0.0.0.0 Port 2048
  Def. Username: phone96
  SIP Options  : (none)
  Codecs       : 0xc (ulaw|alaw)
  Codec Order  : (ulaw,alaw)
  Status       : OK (41 ms)
  Useragent    : snom360/7.1.30
  Reg. Contact : sip:[email protected]:2048;line=dhsajnle
ruft nun jemand das phone6 an blinkt die led beim snom, soweit ok - nun will ich den anruf übernehmen mt dem druck auf die taste neben der leuchtenden led. aber das klappt nicht.
was muss ich noch einstellen?
schau doch mal unter [thread]165741[/thread]
lustig - was soll das?
wäre schön - hab aber nix gefunden. nicht mal bei google. es bricht immer bei "pickup ab"
Ich denke, chaos2000 hat sich nur verschrieben, und wollte Dir sagen, dass das Thema PickUp+Snom+Asterisk hier im Forum in diversen Threads in epischer Breite bereits diskutiert wird, und Du die Suche benutzen solltest.
[offtopic]"Schön" finde ich auch dass die Leute, die in ihrer Signatur mitteilen Asterisk-Installationen durchzuführen, sich das elementare Basiswissen hier im Forum erstmal abgucken müssen...[/offtopic]
Ohja, sorry. ICh meinte eigentlich diesen Thread: http://www.ip-phone-forum.de/showthread.php?t=163239
IchBinEsDoch
