Snom registriert sich nicht
blacktowa
7 Jul 2009
Hallo Zusammen,
folgendes Problem: ein Snom360 (v. 7.3.23) registriert sich nicht.
In der Log-Datei des Telefones steht folgendes drin:
[5]24/12/2001 00:00:10: Using GUI language Deutsch from: /mnt/snomlang/gui_lang_DE.xml
[5]24/12/2001 00:00:11: Using WEB language Deutsch from: /mnt/snomlang/web_lang_DE.xml
[5]24/12/2001 00:00:12: read_xml_settings: found dial-plan XML header
[5]24/12/2001 00:00:12: read_xml_settings: found one byte encoding: 0
[5]24/12/2001 00:00:20: Setting server was already set: http://192.168.200.253/settings/settings.xml
[5]24/12/2001 00:00:20: Fetching URL: http://server/settings/settings.xml
[5]24/12/2001 00:00:20: DHCP: Received IP address server
[0]24/12/2001 00:00:21: Phone::uboot_version:1.1.3-s
[5]24/12/2001 00:00:21: Opening TCP socket on port 843
[5]24/12/2001 00:01:05: read_xml_settings: found setting-files XML header
[5]24/12/2001 00:01:05: read_xml_settings: found one byte encoding: 1
[5]24/12/2001 00:01:05: read_setting_file_list: added URL: http://server/settings/gui_language.xml
[5]24/12/2001 00:01:05: read_setting_file_list: added URL: http://server/settings/web_language.xml
[5]24/12/2001 00:01:05: Conf setup: found xml style settings
[5]24/12/2001 00:01:05: Fetching URL: http://server/settings/settings-00041329A2CB.xml
[5]24/12/2001 00:01:05: read_xml_settings: found settings (container) XML header
[5]24/12/2001 00:01:05: read_xml_settings: found phone-settings XML header
[5]24/12/2001 00:01:05: read_xml_settings: found one byte encoding: 0
[5]24/12/2001 00:01:05: read_xml_settings: found function-keys XML header
[5]24/12/2001 00:01:05: Fetching URL: http://server/settings/gui_language.xml
[5]24/12/2001 00:01:06: read_xml_settings: found gui-languages XML header
[5]24/12/2001 00:01:06: read_xml_settings: found one byte encoding: 1
[5]24/12/2001 00:01:06: Conf setup: found xml style settings
[5]24/12/2001 00:01:06: Fetching URL: http://server/settings/web_language.xml
[5]24/12/2001 00:01:06: read_xml_settings: found web-languages XML header
[5]24/12/2001 00:01:06: Fetching URL: http://127.0.0.1/dummy.htm
[1]24/12/2001 00:01:06: Conf setup: code: 500, host: 127.0.0.1:80, file: /dummy.htm
[5]24/12/2001 00:01:06: Fetching FW URL: http://server/settings/firmware_snom360.xml
[5]24/12/2001 00:01:06: Fetching URL: http://server/settings/firmware_snom360.xml
[2]24/12/2001 01:01:06: start_dst(985485600) end_dst(1004238000) offset_dst(3600) offset_utc(3600)
[2]24/12/2001 01:01:06: start DST: 03/25/2001 02:00:00 (985485600)
[2]24/12/2001 01:01:06: end DST: 10/28/2001 03:00:00 (1004238000)
[5]24/12/2001 01:01:07: read_xml_settings: found phone-book XML header
[5]24/12/2001 01:01:07: read_xml_settings: found one byte encoding: 0
[5]24/12/2001 01:01:08: Using GUI language Deutsch from: /mnt/snomlang/gui_lang_DE.xml
[5]24/12/2001 01:01:09: Using WEB language Deutsch from: /mnt/snomlang/web_lang_DE.xml
[5]24/12/2001 01:01:10: Opening TCP socket on port 80
[5]24/12/2001 01:01:10: Opening TCP socket on port 443
[5]24/12/2001 01:01:10: Opening TCP socket on port 1800
[5]24/12/2001 01:01:32: Settings applied!
[2]24/12/2001 01:01:42: Transport Error: Pending packet 1000007: generating fake
[2]24/12/2001 01:01:42: Registrar 340@server timed out
[2]24/12/2001 01:01:42: Registrar 340@server refused with code 401
[5]24/12/2001 01:01:42: Will try to reregister in 300 seconds
[5]24/12/2001 01:01:53: read_xml_settings: found firmware-settings XML header
[5]24/12/2001 01:01:53: read_xml_settings: found one byte encoding: 1
[5]24/12/2001 01:06:42: sip::process_auth:Match challenge for user=340, realm=vipcox
[2]24/12/2001 01:06:42: Registered at registrar as 340@server (Expires: 3600 secs)
[5]24/12/2001 01:06:57: Dialog -2/1 going to early
[5]24/12/2001 01:06:59: Dialog -2/1 going to terminated
[5]24/12/2001 01:06:59: timeout::callback: Registering with timeout of 0 ms
[5]24/12/2001 01:07:04: Dialog -4/2 going to early
[5]24/12/2001 01:07:05: Dialog -4/2 going to terminated
[5]24/12/2001 01:07:05: timeout::callback: Registering with timeout of 0 ms
[5]24/12/2001 01:07:27: Settings applied!
[5]24/12/2001 01:07:30: Dialog -6/3 going to early
[5]24/12/2001 01:07:32: Dialog -6/3 going to terminated
[5]24/12/2001 01:07:32: timeout::callback: Registering with timeout of 0 ms
[5]24/12/2001 01:07:53: Settings applied!
[5]24/12/2001 01:08:07: Dialog -8/4 going to early
[5]24/12/2001 01:08:16: Dialog -8/4 going to confirmed
Wobei ich denke, dass es an den Zeilen hier liegt:
Soweit ich weiß, heißt es, dass die Benutzerdaten nicht stimmen. Aber ich hab sie noch mal überprüft und sie stimmen. Wenn ich dann ein Re-Register über die Weboberfläche des Telefones mache, dann registriert sich es auch... :confused:
Hallo blacktowa,
code 401 bedeutet = "Unauthorized". Kann auch dann kommen, wenn keine Verbindung zum Sip-Server zustande kommt.
Probiere mal "Keep alive" und evtl. STUN aus.
cpuprofi
Joybar
