[Solved] 7340 directory permissions not inherited on external drive with sftp
Michael999
24 Dez 2008
When I login with a user whose homedir is on an external usb drive, via the console, directory permissions are inherited. So, for example, I can create: dir1/dir2. However, when I try to do this not via the console, but with an sftp client I can't create "dir2" because directory permissions are not inherited.
By using the console all is fine:
root@fritz:/var# mkdir /var/media/ftp/uStor06/ext/ftp/test
root@fritz:/var# adduser -h /var/media/ftp/uStor06/ext/ftp/test test
Changing password for test
New password:
Bad password: too short
Retype password:
Password for test changed by root
root@fritz:/var# ls -ld /var/media/ftp/uStor06/ext/ftp/test
drwxr-sr-x    2 test     test          4096 Apr 30 00:51 /var/media/ftp/uStor06/ext/ftp/test
root@fritz:/var# login test
Password:
   __  _   __  __ ___ __
  |__ |_) |__ |__  |   /
  |   |\  |__ |__  |  /_
   The fun has just begun ...
BusyBox v1.18.4 (2011-04-26 18:53:42 CEST) built-in shell (ash)
Enter 'help' for a list of built-in commands.
-sh: /etc/init.d/rc.conf: line 4: can't create /var/env: Permission denied
rm: can't remove '/var/htmltext.db': Permission denied
ln: /var/htmltext.db: File exists
rm: can't remove '/var/TZ': Permission denied
ln: /var/TZ: File exists
test@fritz:~$ mkdir -p dir1/dir2
test@fritz:~$ ls -ld dir1
[B]drwxrwsrwx[/B]    3 root     test          4096 Apr 30 00:53 dir1
test@fritz:~$ ls -ld dir1/dir2
drwxrwsrwx    2 root     test          4096 Apr 30 00:53 dir1/dir2
But when using an sftp client I can't create "dir2" and get a "permission denied". The console shows the directory permissions of "dir1" are different using an sftp client than when using the console (in bold):
[B]drwxr-sr-x[/B]    2 root     test          4096 Apr 30 00:59 dir1
Is there some way to change the default umask when logging in with a user using an sftp client? I tried changing the default umask by setting it in "/etc/profile", but that didn't work.
Why can I create directories multiple levels deep using the console, but not using the dropbear sftp method?
Why are the uids/gids of your directories "root test" and not "test test"?
Regards
Oliver
I don't know why, homedir "test" is owned by "test":
root@fritz:/var/mod/root# ls -ld /var/media/ftp/uStor06/ext/ftp/test
drwxr-sr-x    3 test     test          4096 Apr 30 15:20 /var/media/ftp/uStor06/ext/ftp/test
However, as you said, directories created while logged in as test are owned by root.
How is this possible?
Have a look at your passwd and groups file?
Regards
Oliver
Seems ok, or am I missing something?
root@fritz:/var/mod/root# cat /etc/passwd
root:x:0:0:root:/mod/root:/bin/sh
nobody:x:100:1000:nobody:/home/nobody:/bin/false
ntp:x:101:1:NTP daemon:/home/ntp:/bin/false
openvpn:x:1000:1001:OpenVPN account:/home/openvpn:/bin/false
wwwrun:x:1001:1002:lighttpd account:/home/wwwrun:/bin/false
ftp:x:102:1:FTP account:/home/ftp:/bin/false
boxusr80:any:1080:0:box user:/home-not-used:/bin/sh
test:x:1003:1003:Linux User,,,:/var/media/ftp/uStor06/ext/ftp/test:/bin/sh
root@fritz:/var/mod/root# cat /etc/group
root:x:0:
users:x:1:ntp,ftp
nobody:x:1000:nobody
openvpn:x:1001:openvpn
wwwrun:x:1002:wwwrun
test:x:1003:
With the 7390 there are problems on ext2 disks when using Freetz ex2 modules. AVM's sources seem a bit out of date. But that does not seem to be the cause for your problem.
Perhaps you can tune the umask for the sftp connection?
Regards
Oliver
Thanks, that worked! I manually set the umask to 0002 when starting dropbear. How can I make it so the umask is set automatically for dropbear?
What's the default umask when you don't set it? How did you set it exactly? I searched dropbear and sftp (openssh-source) but didn't get it...
Regards
Oliver
I'm not sure how to get the umask of a running process in this case. On a regular linux system I'd attach gdp and call the umask function, but I don't know how to do it in this environment.
I set it manually by:
umask 0002;dropbear -p [port]
I've read that on a regular linux system I could modify sshd_config and change the umask of the sftp subsystem like this:
Subsystem sftp /bin/sh -c ‘umask 0002; /usr/libexec/openssh/sftp-server’
But how do I do that in freetz?
What is the default umask for your root? Does it differ for your test user? For me umask was set to 0022 on my box.
Regards
Oliver
For root and test the umask is 0022. 0022 doesn't allow me to create directories more than one level deep with sftp. It will allow me to do that with a umask of 0002.
Sure? I created two directories with a standard linux. test is created with umask set to 0022 and test2 with umask 0077.
drwxr-xr-x 2 oliver oliver 4096 2011-04-30 18:53 test
drwx------ 2 oliver oliver 4096 2011-04-30 18:53 test2
Regards
Oliver
edit: ah, but the g+w and o+w are missing
Okay, now we are back at the question "Why are your directories created as user root...". Can you please create a directory under /var. Does this happen there too?
test@fritz:~$ mkdir /var/media/ftp/uStor06/ext/ftp/test/dir1
drwxr-sr-x    2 root     test          4096 Apr 30 19:35 dir1
test@fritz:~$ mkdir /var/test
mkdir: can't create directory '/var/test': Permission denied
Please show your permissions of /var directory?
drwxr-xr-x   18 root     root           800 Apr 30 21:28 /var
Is it the same for /var/tmp? I don't have access to a box right now so I can't test...
It's different:
root@fritz:/var/mod/root# ls -ld /var/tmp
drwxrwxrwt    8 root     root          1060 Apr 30 21:56 /var/tmp
What happens if you create a directory there? permissions?
root@fritz:/var/mod/root# mkdir /var/tmp/test
root@fritz:/var/mod/root# ls -ld /var/tmp/test
drwxr-xr-x    2 root     root            40 Apr 30 22:19 /var/tmp/test
Use user test please. ;-)
