[Solved / gelöst] Disable ping from WAN side?
flemse
14 Mrz 2007
Hi
I miss a options or some hints to disable WAN side ping.
Some hints…
Best
Flemming
There is no option like this for the FBox. This would be a mission for iptables. Unfortunately iptables isn't working correctely at the moment.
Hi
Is it not possibel to a ruel in ar7.cfg:
reject icmp any any ???
I know I can try but if other have, and it's not working so...
Best
Flemming
Two years ago it worked... Link
Hi
You are the best; can confirm it's still working:D
//Can be closed!
Best
Flemming
Protonator
