[Solved / gelöst] DropBear Wan access (forwarding)
flemse
14 Mrz 2007
Hi.
I want to access my Fritz(7050) from outside with SSH, but how to make the forwarding?
Yes it look like simple stuff but it’s not.
In normally manner I will use the www interface on the Fritz, but in this case the SSH ip is inside the Fritz and identically with the Fritz ip!
I have a setup running configured with 2 Fritz. The first Fritz make a normally port forwarding to the second Fritz(DropBear-SSHd)
But I want to run only with one Fritz?
How to make it working?
Hints…
Regards
Flemming
Hi.
There is a package for dsmod called virtual ip. This gives you a virtual ip (e.g. 192.168.178.253). And you then can make your forwarding in the webinterface.
Greets, Oliver
Hi.
Thanks for the hint!
Regards
Flemming
An alternative (better) solution is to edit /var/flash/ar7.cfg . But you should edit this file only using nvi, nnano or nmcedit.
Best regards,
Hi
Hm.. I know the file but how to make the forwarding without a IP-addr?
Smal hint's...
Best
Flemming
Example:
[I]  "tcp 0.0.0.0:22 0.0.0.0:22 0 # PuTTy"
Greets Oliver
[/I]
Hi
Thanks.
//Can be closed!
Best
Flemming
cmdms
