Some questions for technician, FRITZ!Mini, HD, G722, 7170, 7270, paralel calls, pair
vpe
24 Feb 2006
1) is FRITZ!Mini 07.02.07 capable connect (pair) with to 2 Fritz boxes like as DECT Phone to connect to 2 or more DECT base stations without unpair?
2) how much FRITZ!Mini 07.02.07 phones is possible connect (pair) to one fritz!box 7170 or 7270?
3) how much FRITZ!Mini 07.02.07 phones is possible make call simultaneously via fritz!box 7170 or 7270??
4) fritz!box 7170 make 3 SIP + 1 PSTN, sum 4 cals simultaneously, sure (maximal limit)? And 7270 have these limitations too or have beter CPU and more cals paralell?
5) is FRITZ!Mini 07.02.07 capable via 7170 make HD G722 call? Have latest 7170 firmware G722 codec?
1. no
2. 4 (says AVM, you can test ist with 4 computers and simulator)
4. yes, also 3 VoIP. But PSTN kann be 2 if it is ISDN (the same at 7170 and other)
thx for this info.
i have some q: i save in latest GINI setting but how i LOAD saved setting?
Is possible?
Yes.
- Select the Benutzer in Benutzer-Menu
- Then Datei / Einstellungen sichern
- Einstellungen wiederherstellen
Ach ja, i noot look into Sichern.. Found wizard here :-/
Gini is only in German :-(
Import of previous saved version not work, but WinMerge and 3 minutes of text edit settings solve this... But i get error, know you why? (UPnP i have in FBF Enabled) and next start gini my order (Radios, podcasts) is resorted :-/
Maybe is possible copy direct var/flash/browser-data or any parsing operation make gini, try anyone?
And I have today info from AVM:
ad 2): You can connect 3 FRITZ!MINIs simultaneously to the FRITZ!Box.
ad 3): Two of them can use telephony functions simultaneously with the FRITZ!Box.
You may reboot the Fritz!Box, Computer,...
Or you try to copy the radio-links from the saved configuration to Gini!
Der_fragende_Unwissende
