SPA941, IPKall, DynDNS
Daikoku
11 Mrz 2006
ich weite meine US Rufnummer mit IPKall auf meinen DynDNS weiter. Das Telefon klingelt bei Anruf, aber wenn man rangeht passiert nix und beim Anrufer klingelt es weiter. Hier mal ein log:
syslog server(port:514) started on Tue Jul 25 23:45:42 2006
[0:5060]->217.10.79.9:5060
[0:5060]<<217.10.79.9:5060
TP Parser error: 34
[0:5060]<<66.54.140.46:5060
INVITE sip:[email protected] SIP/2.0
Via: SIP/2.0/UDP 66.54.140.46:5060;branch=z9hG4bK14d355be;rport
From: "Unknown" <sip:[email protected]>;tag=as59f0d137
To: <sip:[email protected]>
Contact: <sip:[email protected]>
Call-ID: [email protected]
CSeq: 102 INVITE
User-Agent: Asterisk PBX
Max-Forwards: 70
Date: Tue, 25 Jul 2006 21:45:56 GMT
Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REFER, SUBSCRIBE, NOTIFY
Content-Type: application/sdp
Content-Length: 308
v=0
o=root 9661 9661 IN IP4 66.54.140.46
s=session
c=IN IP4 66.54.140.46
t=0 0
m=audio 18366 RTP/AVP 0 8 3 18 101
a=rtpmap:0 PCMU/8000
a=rtpmap:8 PCMA/8000
a=rtpmap:3 GSM/8000
a=rtpmap:18 G729/8000
a=fmtp:18 annexb=no
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-16
a=silenceSupp:off - - - -
[0:5060]->66.54.140.46:5060
SIP/2.0 100 Trying
CSeq: 102 INVITE
Server: Sipura/SPA941-4.1.9
Content-Length: 0
[1:0]DEC INIT 2
[0:0]AUD ALLOC CALL (port=16456)
[0:0]RTP Rx Up
SIP/2.0 180 Ringing
To: <sip:[email protected]>;tag=63d1981c62e6bbe1i0
CSeq: 102 INVITE
Content-Length: 0
PHN_setAudioPath(1)
SIP/2.0 200 OK
CSeq: 102 INVITE
Contact: "Tom Frey" <sip:[email protected]:5060>
Content-Length: 204
Allow: ACK, BYE, CANCEL, INFO, INVITE, NOTIFY, OPTIONS, REFER
v=0
o=- 107214 107214 IN IP4 192.168.0.4
s=-
c=IN IP4 192.168.0.4
t=0 0
m=audio 16456 RTP/AVP 0 101
a=fmtp:101 0-15
a=ptime:20
a=sendrecv
SIP/2.0 200 OK
CSeq: 102 INVITE
Content-Length: 204
v=0
s=-
t=0 0
a=fmtp:101 0-15
a=ptime:20
a=sendrecv
SIP/2.0 200 OK
CSeq: 102 INVITE
Content-Length: 204
v=0
s=-
t=0 0
a=fmtp:101 0-15
a=ptime:20
a=sendrecv
SIP/2.0 200 OK
CSeq: 102 INVITE
Content-Length: 204
v=0
s=-
t=0 0
a=fmtp:101 0-15
a=ptime:20
a=sendrecv
TP Parser error: 34
SIP/2.0 200 OK
CSeq: 102 INVITE
Content-Length: 204
v=0
s=-
t=0 0
a=fmtp:101 0-15
a=ptime:20
a=sendrecv
SIP/2.0 200 OK
CSeq: 102 INVITE
Content-Length: 204
v=0
s=-
t=0 0
a=fmtp:101 0-15
a=ptime:20
a=sendrecv
PHN_setAudioPath(0)
[0:0]AUD Rel Call
SIP/2.0 200 OK
CSeq: 102 INVITE
Content-Length: 204
v=0
s=-
t=0 0
a=fmtp:101 0-15
a=ptime:20
a=sendrecv
DLG Terminated
Sess Terminated
TP Parser error: 34
jemand eine idee?
Danke,
Daikoku
was ich noch hinzufügen sollte: Wenn ich auf meiner Sipgate Ortsnetznummer anrufe funktioniert alles ohne Probleme
Versuch' es mal mit diesen Einstellungen - sind etwas anders als die, die ich Dir per PN schon gab, aber merk' Dir was Du änderst, damit Du es ggf. wieder rückgängig machen kannst, wenn sipgate dann nicht mehr gehen sollte ;)
Wie versprochen habe ich es jetzt mal selbst probiert mit meinem SPA-3000. Mit den Einstellungen auf der Seite, die ich oben verlinkt habe, funktioniert es bei mir, man muß also doch STUN benutzen. Da die benutzte Line bei mir auf Port 5070 läuft habe ich außerdem bei IPKall unter SIP Proxy mein.dyndns.org:5070 eingetragen.
Gruß,
Tin
also ich hab jetzt eben nochmal die Einstellung von oben probiert und jetzt ist das problem, dass der Anrufer nichts hört, ich höre aber den Anrufer im VoIP phone. Nach ca. einer Minute erscheint allerdings plötzlich Call ended. Hmhm, was könnt denn das noch sein :/
Danke,
Daikoku
Das selbe Problem hatte ich mit den Einstellungen, die ich Dir per PN geschickt hatte, nachdem ich STUN, wie auf der Seite oben beschrieben wieder reingenommen habe und diese NAT Parameter auf der SIP Seite geändert hatte ging es dann:
Setup STUN on your adapter (NOTE: STUN settings are on the SIP tab)
Handle VIA received: no
Handle VIA rport: no
Insert VIA received: no
Insert VIA rport: no
Substitute VIA Addr: yes
Send Resp To Src Port: yes
STUN Enable: yes
STUN Test Enable: no
STUN Server: stun.voxalot.com.au:3478
Evtl. den SPA mal neu starten (Strom ziehen)
Gruß,
Tin
hier mal meine Settings
lol jetzt hab ich mal zum Spass den STUN Server: stun.voxalot.com.au:3478 genommen und jedesmal wenn ich anruf zeigt das Phone "Shared" an und rebooted dann
auch normal rausrufen geht jetzt nimmer :/
Der Parameter "Share Ext." , wo Du "private" ausgewählt hast, ist mir unbekannt vom SPA-3000, ich würde mal in der Doku nachschauen wofür der ist und ggf. mal ändern, außerdem habe ich folgende settings anders als Du:
Line Karteireiter:
SIP TOS/DiffServ Value: 0xaf
RTP TOS/DiffServ Value: 0xef
Network Jitter Level: low
Refer-To Target contact: no
Sticky 183: no
SIP Karteireiter:
RTP Packet Size: 0.040
NAT Keep Alive Intvl: 15
mal angepasst aber geht noch immer nix :/
Ich glaub ich mach mal einen factory reset und richt alles neu ein und meld mich mal bei Carp für Ext1 an oder würdest du zu nem anderen Provider raten?
so, factory reset, neu eingerichtet, jetzt funzt es 1a :)
Keineahnung welche der 1000 Settings das Problem war.
Jedenfalls vielen Dank für deine Hilfe!
Klasse, freut mich :)
Gruß,
Tin
So, leider habe ich noch immer ein Problem mit IPKall und dem SPA-941.
Jetzt ist es nämlich so, dass wenn ich von einem deutschen 2. Anschluss auf der US IPKall Nummer anrufe, das SPA normal klingelt und wenn ich abhebe funktioniert auch die Sprache in beide Richtungen einwandfrei. Das Problem ist jetzt allerding wenn mich US Leute anrufen, dann klingelt das SPA, aber wenn ich abhebe steht im Display "Answering...", es kommt aber kein Gespräch zustande und nach ca. 15 Sekunden kommt dann "Call ended".
Irgendwer ne Idee wieso es von DE Anschluss aus geht aber von US nicht?
IPKall direkt auf SIP Phone - Anruf kommt nicht zustande
ich habe leider seit einiger Zeit folgendes Problem und weiss nicht was ich noch tun kann:
Seitdem Sipgate keine Externen URI-Calls mehr erlaubt leite ich nun meine US IPKall Nummer direkt auf mein Linksys SPA941 weiter. Das komische ist jetzt, wenn ich von einem deutschen Telefonanschluss auf der US IPKall Nummer anrufe, dann klingelt das SPA und wenn ich abhebe kommt (MEISTENS) ohne Probleme eine Kommunikation zustande.
Wenn mich jetzt jedoch jemand aus USA anruft, dann klingelt das Telefon, wenn ich abhebe kommt allerdings keine Kommunikation zustande. Im Display steht dann "Answering..." und nach etwa 10 Sekunden "Call ended".
Hat irgendwer eine Idee was das sein könnte?
Danke,
Daikoku
Wir werden den anderen Thread, den Du angefangen hast, auch hier reinschieben... es bringt nichts, das gleiche Thema an zwei Ecken zu behandeln.
Zu Deiner Frage: was ist denn unterschiedlich zwischen einem Anruf via deutschem oder U.S. Festnetz? Gibt es da Unterschiede mit Caller-Id oder ähnlichem? Sehen die SIP-URIs, die bei Dir ankommen, in beiden Fällen gleich aus? Wird Call Progress anders signalisiert?
Ich habe hier leider kein 941 stehen... Hast Du einen SIP-Trace der beiden Anrufvarianten zur Verfügung?
--gandalf.
was der Unterschied zwischen Anruf von US vs DE Festnetz ist weiss ich nicht... wenn ich es wüsste würde es mich ja vielleicht ein wenig weiterbringen :)
Hier mal ein Log von einem US Festnetzanschluss aus der fehlschlägt wie beschrieben:
2006-08-15 20:32:59    Local0.Info    192.168.0.4    [0:5060]<<66.54.140.46:5060
2006-08-15 20:32:59    Local7.Debug    192.168.0.4    INVITE sip:[email protected] SIP/2.0<013><010>Via: SIP/2.0/UDP 66.54.140.46:5060;branch=z9hG4bK383bcbcb;rport<013><010>From: "9419536800" <sip:[email protected]>;tag=as31c4a545<013><010>To: <sip:[email protected]><013><010>Contact: <sip:[email protected]><013><010>Call-ID: [email protected]<013><010>CSeq: 102 INVITE<013><010>User-Agent: Asterisk PBX<013><010>Max-Forwards: 70<013><010>Date: Tue, 15 Aug 2006 18:33:00 GMT<013><010>Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REFER, SUBSCRIBE, NOTIFY<013><010>Content-Type: application/sdp<013><010>Content-Length: 308<013><010><013><010>v=0<013><010>o=root 1010 1010 IN IP4 66.54.140.46<013><010>s=session<013><010>c=IN IP4 66.54.140.46<013><010>t=0 0<013><010>m=audio 12934 RTP/AVP 0 8 3 18 101<013><010>a=rtpmap:0 PCMU/8000<013><010>a=rtpmap:8 PCMA/8000<013><010>a=rtpmap:3 GSM/8000<013><010>a=rtpmap:18 G729/8000<013><010>a=fmtp:18 annexb=no<013><010>a=rtpmap:101 telephone-event/8000<013><010>a=fmtp:101 0-16<013><010>a=silenceSupp:off - - - -
2006-08-15 20:32:59    Local0.Info    192.168.0.4    <010>
2006-08-15 20:32:59    Local0.Info    192.168.0.4    [0:5060]->66.54.140.46:5060(305)
2006-08-15 20:32:59    Local7.Debug    192.168.0.4    SIP/2.0 100 Trying<013><010>To: <sip:[email protected]><013><010>From: "9419536800" <sip:[email protected]>;tag=as31c4a545<013><010>Call-ID: [email protected]<013><010>CSeq: 102 INVITE<013><010>Via: SIP/2.0/UDP 66.54.140.46:5060;branch=z9hG4bK383bcbcb<013><010>Server: Linksys/SPA941-4.1.15<013><010>Content-Length: 0
2006-08-15 20:32:59    Local2.Debug    192.168.0.4    [1:0]DEC INIT 130
2006-08-15 20:32:59    Local2.Debug    192.168.0.4    [1:0]AUD ALLOC CALL (port=16470)
2006-08-15 20:32:59    Local2.Debug    192.168.0.4    [0:0]RTP Rx Up
2006-08-15 20:32:59    Local0.Info    192.168.0.4    [0:5060]->66.54.140.46:5060(329)
2006-08-15 20:32:59    Local7.Debug    192.168.0.4    SIP/2.0 180 Ringing<013><010>To: <sip:[email protected]>;tag=c22620e911c3e2cdi1<013><010>From: "9419536800" <sip:[email protected]>;tag=as31c4a545<013><010>Call-ID: [email protected]<013><010>CSeq: 102 INVITE<013><010>Via: SIP/2.0/UDP 66.54.140.46:5060;branch=z9hG4bK383bcbcb<013><010>Server: Linksys/SPA941-4.1.15<013><010>Content-Length: 0
2006-08-15 20:33:02    Local0.Info    192.168.0.4    <010>
2006-08-15 20:33:02    Local0.Info    192.168.0.4    [0:5060]->66.54.140.46:5060(674)
2006-08-15 20:33:02    Local7.Debug    192.168.0.4    SIP/2.0 200 OK<013><010>To: <sip:[email protected]>;tag=c22620e911c3e2cdi1<013><010>From: "9419536800" <sip:[email protected]>;tag=as31c4a545<013><010>Call-ID: [email protected]<013><010>CSeq: 102 INVITE<013><010>Via: SIP/2.0/UDP 66.54.140.46:5060;branch=z9hG4bK383bcbcb<013><010>Contact: "Tom Frey" <sip:[email protected]:5060><013><010>Server: Linksys/SPA941-4.1.15<013><010>Content-Length: 202<013><010>Allow: ACK, BYE, CANCEL, INFO, INVITE, NOTIFY, OPTIONS, REFER<013><010>Content-Type: application/sdp<013><010><013><010>v=0<013><010>o=- 66595 66595 IN IP4 192.168.0.4<013><010>s=-<013><010>c=IN IP4 192.168.0.4<013><010>t=0 0<013><010>m=audio 16470 RTP/AVP 0 101<013><010>a=rtpmap:0 PCMU/8000<013><010>a=rtpmap:101 telephone-event/8000<013><010>a=fmtp:101 0-15<013><010>a=ptime:30<013><010>a=sendrecv
2006-08-15 20:33:03    Local0.Info    192.168.0.4    [0:5060]->66.54.140.46:5060(674)
2006-08-15 20:33:03    Local7.Debug    192.168.0.4    SIP/2.0 200 OK<013><010>To: <sip:[email protected]>;tag=c22620e911c3e2cdi1<013><010>From: "9419536800" <sip:[email protected]>;tag=as31c4a545<013><010>Call-ID: [email protected]<013><010>CSeq: 102 INVITE<013><010>Via: SIP/2.0/UDP 66.54.140.46:5060;branch=z9hG4bK383bcbcb<013><010>Contact: "Tom Frey" <sip:[email protected]:5060><013><010>Server: Linksys/SPA941-4.1.15<013><010>Content-Length: 202<013><010>Allow: ACK, BYE, CANCEL, INFO, INVITE, NOTIFY, OPTIONS, REFER<013><010>Content-Type: application/sdp<013><010><013><010>v=0<013><010>o=- 66595 66595 IN IP4 192.168.0.4<013><010>s=-<013><010>c=IN IP4 192.168.0.4<013><010>t=0 0<013><010>m=audio 16470 RTP/AVP 0 101<013><010>a=rtpmap:0 PCMU/8000<013><010>a=rtpmap:101 telephone-event/8000<013><010>a=fmtp:101 0-15<013><010>a=ptime:30<013><010>a=sendrecv
2006-08-15 20:33:03    Local0.Info    192.168.0.4    <010>
2006-08-15 20:33:04    Local0.Info    192.168.0.4    [0:5060]->66.54.140.46:5060(674)
2006-08-15 20:33:04    Local7.Debug    192.168.0.4    SIP/2.0 200 OK<013><010>To: <sip:[email protected]>;tag=c22620e911c3e2cdi1<013><010>From: "9419536800" <sip:[email protected]>;tag=as31c4a545<013><010>Call-ID: [email protected]<013><010>CSeq: 102 INVITE<013><010>Via: SIP/2.0/UDP 66.54.140.46:5060;branch=z9hG4bK383bcbcb<013><010>Contact: "Tom Frey" <sip:[email protected]:5060><013><010>Server: Linksys/SPA941-4.1.15<013><010>Content-Length: 202<013><010>Allow: ACK, BYE, CANCEL, INFO, INVITE, NOTIFY, OPTIONS, REFER<013><010>Content-Type: application/sdp<013><010><013><010>v=0<013><010>o=- 66595 66595 IN IP4 192.168.0.4<013><010>s=-<013><010>c=IN IP4 192.168.0.4<013><010>t=0 0<013><010>m=audio 16470 RTP/AVP 0 101<013><010>a=rtpmap:0 PCMU/8000<013><010>a=rtpmap:101 telephone-event/8000<013><010>a=fmtp:101 0-15<013><010>a=ptime:30<013><010>a=sendrecv
2006-08-15 20:33:04    Local0.Info    192.168.0.4    <010>
2006-08-15 20:33:06    Local0.Info    192.168.0.4    [0:5060]->66.54.140.46:5060(674)
2006-08-15 20:33:06    Local7.Debug    192.168.0.4    SIP/2.0 200 OK<013><010>To: <sip:[email protected]>;tag=c22620e911c3e2cdi1<013><010>From: "9419536800" <sip:[email protected]>;tag=as31c4a545<013><010>Call-ID: [email protected]<013><010>CSeq: 102 INVITE<013><010>Via: SIP/2.0/UDP 66.54.140.46:5060;branch=z9hG4bK383bcbcb<013><010>Contact: "Tom Frey" <sip:[email protected]:5060><013><010>Server: Linksys/SPA941-4.1.15<013><010>Content-Length: 202<013><010>Allow: ACK, BYE, CANCEL, INFO, INVITE, NOTIFY, OPTIONS, REFER<013><010>Content-Type: application/sdp<013><010><013><010>v=0<013><010>o=- 66595 66595 IN IP4 192.168.0.4<013><010>s=-<013><010>c=IN IP4 192.168.0.4<013><010>t=0 0<013><010>m=audio 16470 RTP/AVP 0 101<013><010>a=rtpmap:0 PCMU/8000<013><010>a=rtpmap:101 telephone-event/8000<013><010>a=fmtp:101 0-15<013><010>a=ptime:30<013><010>a=sendrecv
2006-08-15 20:33:06    Local0.Info    192.168.0.4    <010>
2006-08-15 20:33:10    Local0.Info    192.168.0.4    [0:5060]->66.54.140.46:5060(674)
2006-08-15 20:33:10    Local7.Debug    192.168.0.4    SIP/2.0 200 OK<013><010>To: <sip:[email protected]>;tag=c22620e911c3e2cdi1<013><010>From: "9419536800" <sip:[email protected]>;tag=as31c4a545<013><010>Call-ID: [email protected]<013><010>CSeq: 102 INVITE<013><010>Via: SIP/2.0/UDP 66.54.140.46:5060;branch=z9hG4bK383bcbcb<013><010>Contact: "Tom Frey" <sip:[email protected]:5060><013><010>Server: Linksys/SPA941-4.1.15<013><010>Content-Length: 202<013><010>Allow: ACK, BYE, CANCEL, INFO, INVITE, NOTIFY, OPTIONS, REFER<013><010>Content-Type: application/sdp<013><010><013><010>v=0<013><010>o=- 66595 66595 IN IP4 192.168.0.4<013><010>s=-<013><010>c=IN IP4 192.168.0.4<013><010>t=0 0<013><010>m=audio 16470 RTP/AVP 0 101<013><010>a=rtpmap:0 PCMU/8000<013><010>a=rtpmap:101 telephone-event/8000<013><010>a=fmtp:101 0-15<013><010>a=ptime:30<013><010>a=sendrecv
2006-08-15 20:33:10    Local0.Info    192.168.0.4    <010>
2006-08-15 20:33:11    Local0.Info    192.168.0.4    [0:5060]<<217.10.79.9:5060
2006-08-15 20:33:11    Local0.Info    192.168.0.4    <010>
2006-08-15 20:33:11    Local2.Debug    192.168.0.4    TP Parser error: 34
2006-08-15 20:33:14    Local0.Info    192.168.0.4    [0:5060]->66.54.140.46:5060(674)
2006-08-15 20:33:14    Local7.Debug    192.168.0.4    SIP/2.0 200 OK<013><010>To: <sip:[email protected]>;tag=c22620e911c3e2cdi1<013><010>From: "9419536800" <sip:[email protected]>;tag=as31c4a545<013><010>Call-ID: [email protected]<013><010>CSeq: 102 INVITE<013><010>Via: SIP/2.0/UDP 66.54.140.46:5060;branch=z9hG4bK383bcbcb<013><010>Contact: "Tom Frey" <sip:[email protected]:5060><013><010>Server: Linksys/SPA941-4.1.15<013><010>Content-Length: 202<013><010>Allow: ACK, BYE, CANCEL, INFO, INVITE, NOTIFY, OPTIONS, REFER<013><010>Content-Type: application/sdp<013><010><013><010>v=0<013><010>o=- 66595 66595 IN IP4 192.168.0.4<013><010>s=-<013><010>c=IN IP4 192.168.0.4<013><010>t=0 0<013><010>m=audio 16470 RTP/AVP 0 101<013><010>a=rtpmap:0 PCMU/8000<013><010>a=rtpmap:101 telephone-event/8000<013><010>a=fmtp:101 0-15<013><010>a=ptime:30<013><010>a=sendrecv
2006-08-15 20:33:14    Local0.Info    192.168.0.4    <010>
2006-08-15 20:33:18    Local0.Info    192.168.0.4    [0:5060]->66.54.140.46:5060(674)
2006-08-15 20:33:18    Local7.Debug    192.168.0.4    SIP/2.0 200 OK<013><010>To: <sip:[email protected]>;tag=c22620e911c3e2cdi1<013><010>From: "9419536800" <sip:[email protected]>;tag=as31c4a545<013><010>Call-ID: [email protected]<013><010>CSeq: 102 INVITE<013><010>Via: SIP/2.0/UDP 66.54.140.46:5060;branch=z9hG4bK383bcbcb<013><010>Contact: "Tom Frey" <sip:[email protected]:5060><013><010>Server: Linksys/SPA941-4.1.15<013><010>Content-Length: 202<013><010>Allow: ACK, BYE, CANCEL, INFO, INVITE, NOTIFY, OPTIONS, REFER<013><010>Content-Type: application/sdp<013><010><013><010>v=0<013><010>o=- 66595 66595 IN IP4 192.168.0.4<013><010>s=-<013><010>c=IN IP4 192.168.0.4<013><010>t=0 0<013><010>m=audio 16470 RTP/AVP 0 101<013><010>a=rtpmap:0 PCMU/8000<013><010>a=rtpmap:101 telephone-event/8000<013><010>a=fmtp:101 0-15<013><010>a=ptime:30<013><010>a=sendrecv
2006-08-15 20:33:18    Local0.Info    192.168.0.4    <010>
[EDIT: habe das Log mal in code-Tags gepackt, damit man es auch lesen kann... das hält ja sonst kein Mensch aus --gandalf94305]
quickbooks2026
