- Span 3: Channel 0/1 got hangup, cause 18 > == Everyone is busy/congested at this ti
mdipolt
6 Sep 2011
Bekomm Error wenn ich vom SIP Phone (1001) nach draußen telefonieren will.
Wenn ich externe Nummer anrufe kommt nur kurzer biep, und asterisk cli zeigt nichts an.
Betreiber: UPC
Karte: digicum b410p mit te modus, smartnode4553(bri 0/1) hängt auf port 3, status ist ok, led leuchtet grün
asterisk CLI Ausgabe:
== Using SIP RTP CoS mark 5
-- Executing [06802333572@default:1] Dial("SIP/1001-00000007", "DAHDI/g13/06802333572") in new stack
-- Requested transfer capability: 0x00 - SPEECH
-- Called DAHDI/g13/06802333572
== Primary D-Channel on span 3 up
-- Span 3: Channel 0/1 got hangup, cause 18
-- Hungup 'DAHDI/i3/06802333572-7'
== Everyone is busy/congested at this time (1:0/0/1)
-- Executing [06802333572@default:2] Hangup("SIP/1001-00000007", "") in new stack
== Spawn extension (default, 06802333572, 2) exited non-zero on 'SIP/1001-00000007'
asterisk*CLI> - Span 3: Channel 0/1 got hangup, cause 18
No such command '- Span 3: Channel 0/1 got hangup, cause 18' (type 'core show help - Span' for other possible commands)
asterisk*CLI>
Disconnected from Asterisk server
Executing last minute cleanups
dahdi show status (von asterisk cli):
Description                              Alarms  IRQ    bpviol CRC4   Fra Codi Options  LBO
B4XXP (PCI) Card 0 Span 1                YEL     0      0      0      CCS AMI           0 db (CSU)/0-133 feet (DSX-1)
B4XXP (PCI) Card 0 Span 2                RED     0      0      0      CCS AMI           0 db (CSU)/0-133 feet (DSX-1)
B4XXP (PCI) Card 0 Span 3                OK      0      0      0      CCS AMI           0 db (CSU)/0-133 feet (DSX-1)
B4XXP (PCI) Card 0 Span 4                RED     0      0      0      CCS AMI           0 db (CSU)/0-133 feet (DSX-1)
dahdi show channels
 Chan Extension  Context         Language   MOH Interpret        Blocked    State
 pseudo            default                    default                         In Service
      1            from-pstn                  default                         In Service
      2            from-pstn                  default                         In Service
      4            from-pstn                  default                         In Service
      5            from-pstn                  default                         In Service
      7            from-pstn                  default                         In Service
      8            from-pstn                  default                         In Service
     10            from-pstn                  default                         In Service
     11            from-pstn                  default                         In Service
/etc/asterisk/dahdi-channels.conf:
Span 1: B4/0/1 "B4XXP (PCI) Card 0 Span 1" AMI/CCS RED
group=0,11
context=from-pstn
switchtype = euroisdn
signalling = bri_cpe_ptmp
channel => 1-2
context = default
group = 63
; Span 2: B4/0/2 "B4XXP (PCI) Card 0 Span 2" AMI/CCS RED
group=0,12
context=from-pstn
channel => 4-5
context = default
group = 63
; Span 3: B4/0/3 "B4XXP (PCI) Card 0 Span 3" (MASTER) AMI/CCS
group=0,13
context=from-pstn
channel => 7-8
context = default
group = 63
; Span 4: B4/0/4 "B4XXP (PCI) Card 0 Span 4" AMI/CCS RED
group=0,14
context=from-pstn
channel => 10-11
context = default
group = 63
/etc/asterisk/sip.conf:
[general]
context = default
bindport = 5060
bindaddr = 0.0.0.0
tcpbindaddr = 0.0.0.0
tcpenable = yes
[1001]
type = friend
callerid = User One <1001>
secret = 1001
host = dynamic
canreinvite = no
dtmfmode = rfc2833
mailbox = 1001
disallow = all
allow = ulaw
transport = udp
[1002]
type = friend
callerid = User Two <1002>
secret = 1002
host = dynamic
canreinvite = no
dtmfmode = rfc2833
mailbox = 1002
disallow = all
allow = ulaw
transport = udp
/etc/asterisk/extension.conf:
[default]
exten => 1001,1,Answer()
exten => 1001,n,Dial(SIP/1001,20,tr)
exten => 1001,n,Hangup
exten => 1002,1,Answer()
exten => 1002,n,Dial(SIP/1002,20,tr)
exten => 1002,n,Hangup.
exten => _XXXXX.,1,Dial(DAHDI/g13/${EXTEN})
exten => _XXXXX.,2,Hangup()
exten => 890077,1,Answer()
exten => 890077,n,Dial(SIP/1001,20,tr)
exten => 890077,n,Hangup.
Hat jemand nen Rat wo der Fehler liegen könnte?
this was a setup and debian and the command "pri show spans"(shows bri and pri) in the asterisk cli didnt work, i think there was troubles with the libpri installation
i set up asterisk now distribution with same config, i was able to call out
First it was out, but after changing landconfig correct to my country (at instead of us) it goes up and i was able to call out
pri show spans(as it worked):
PRI span 1/0: Provisioned, In Alarm, Down, Active
PRI span 2/0: Provisioned, In Alarm, Down, Active
PRI span 3/0: Provisioned, Up, Active
PRI span 4/0: Provisioned, In Alarm, Down, Active
figo12
