Sprachenakten CS290
matteoz
25 Jan 2007
Jemand weiß wo zu laden die Sprachenakten für den Elmeg CS290? Vielen Dank!
Downloads Elmeg CS290: da questo server
Prego, non usi la traduzione automatica - è terribile ;-) Usi inglese o italiano.
--gandalfo.
I'm very sorry for the bad translation, I do apologize but unfortunately I can't speak German.
The language files for the CS290 not are present on this server.
I don't remember where I had found it some days ago.
Vielen Dank!
Matteo.
installation folder -> DisplayData.
is this ok or which files you needed?
Sirko
Vielen Dank Sirko,
but unfortunately not is the right folder (and files)... and I don't remember where I had found it. :noidea:
Now I remember!
Yes Sirko, it is the file! ;-)
Thank you very very much!
Now: do You know how to upload this language file in the T484?
Thanks a lot! ;)
From help file:
Language for the PABX menu
Displays in the system menu of the PABX are available in several languages. These language settings are independent from the settings in the individual system phones. Language settings for the system menu are configured in the PABX central configuration program. The selected language displays to be used are loaded into the PABX. Use the telephone directory of the PABX to load displays of the system menu into the PABX in one of the available languages.
Problem SOLVED !!!!
In Phonebook - send language data !!!!
Was so easy! Thank you very much again! ;-)
Wonderfull!! :D
Pianist
