- Mitglied seit
- 18 Aug 2005
- Beiträge
- 42
- Punkte für Reaktionen
- 0
- Punkte
- 0
Hello fellows,
Thanks to all of you, who has been very helpful to make FritzBox Fon Wlan to a wonderful VoIP adapter (especially members: Haveaniceday, dm41, oliestudent, pfeffer, susanne, etc.).
I bought a Fon Wlan Router from eBay/Germany. To make it work in Denmark I did as followed after searching a lot of articles from AVM forum
1. Install Telnet
2. Unbrand the AOL firmware to default AVM
3. Upgrad firmware from 08.03.65 to 08.03.73 (with WDS)
4. Convert Annex B to Annex A
5. Convert Router to ATA adapter (router converted to brigde)
6. Update Codecs by file from member - Haveaniceday -, now used iLBC as main codec like described at http://www.vocal.com/ilbc.html
7. Get CLIP to work in both router and handsets (handset Beo2500 with callerID) thanked to the genial member - Haveaniceday -
German is'nt easy to understand but after a hard try (14 hours) to read a lot of posts here from I got the points to modify the router. Very satisfy with the result. Thanks for all your hard works.
Regards,
größter Respekt,
1. Install Telnet
Regards,
größter Respekt,
