TC300 can be used like SIP phone with other wireless router (excepting DSL routers)?
unudepenet
8 Jun 2007
I have a TC 300 (s/w version D910.0.3.63) and I can not connect to different wirelles broadband routers (Micronet, SMC, Digitus) for using it like a SIP phone? I need a new firmware?
Can anybody help me?
Thanks!
Hy,
with the Firmware on your TC300 you can connect only to T-COM Voip.
To use other Voip Account you need to change the Firmware.
Flash the original Pirelli Firmware and you can use any Voip Account.
Then you can connect to every W-Lan Router.
Look at these Thread:
http://www.ip-phone-forum.de/showthread.php?t=124489
PS. i use the Pirelli Firmware D910.0.3.98f
Cu
Frogsta
Thank you for your reply!
I am in doubt now: which utility I have to use for upgrade: TC300 Utility (it can not load pirelli firmware ) or DMT Utility (can not detect the phone)?
Hello unudepenet,
if you cant upload the pirelli Firmware , make a hardreset before upload.
Look here:
http://www.ip-phone-forum.de/showthread.php?t=134823
for the first upgrade to the Pirelli Firmware you can use TC300 utilitys.
After the Flashing only the DMT Utility will syncronize with your PC.
SAVE YOUR SETTINGS BEFORE FLASHING !!!!
CU
Frogsta
Pirelli Firmware D910.0.3.98f flashed succesfully, but I can not connect to VoipStunt!
I used the following configuration:
Benutzername: (dein Name bei VoipStunt)
Passwort: dein Voipstunt- Passwort
Emailadresse: (freilassen)
Domänenname: sip.voipstunt.com
Lokaler Port: 5060
Proxyserver: sip.voipstunt.com
Proxyport: 5060
Anmeldeserver: sip.voipstunt.com
Anmeldeport: 5060
Intervall: 600
Ausgangsserver: leer
Ausgangsport: leer
Rip- Audioport: 30000
RIP-PKT-Intervall: 20
Codec: G711A
NAT-Einstellungen
RPort: einschalten
Stun: einschalten
Serveradresse: stun.voipstunt.com
Portnummer: 3478
Auffrischzyklus: 60
There are VoipStunt users to help me?
Thanks!
You know the exact name. How about a forum- or even a google search?
Hy,
That is not entirely true. It _is_ possible to connect to other VoIP providers, this has been shown many times even in this forums.
True is: the T-Com firmware version is the oldest compared to the other versions available (ARCOR, PIRELLI) and the T-One product line behind has been abandoned by T-Com, hence there is no further firmware expectable in future. So you'll probably have to face a lot of interop problems, which might prevent you from connecting to other providers, than T-Com, for which this version was optimized to, but (as I said) not built exclusively.
Finally it is not such a bad idea to upgrade the phone with the latest firmware revision. Hints ant tricks may be found here (searching for "Twintel", "Pirelli", "TC300" or simply asking a question).
Regards
I would second that.
But I dont recommend latest beta test versions.
Lokaler Port: 5060
Proxyport: 5060
Anmeldeport: 5060
Intervall: 600
Ausgangsport: leer
Codec: G711A
NAT-Einstellungen
RPort: einschalten
Stun: einschalten
Portnummer: 3478
Auffrischzyklus: 60
Tell me providers you are using, please!
Or do you have any idea?
I have WLAN acces (verified with phone WEB access over WLAN). My router is "allow any to any"
Thanks!
Are you able to trace the REGISTER attempts of the phone using Wireshark?
Here is my tcpdump report from router:
09:27:58.021710 192.168.10.250.5060 > 80-239-235-219.customer.teliacarrier.com.3479: udp 28 [tos 0xe0]
09:28:37.185612 192.168.10.250.5060 > 80-239-235-195.customer.teliacarrier.com.5060: udp 432 [tos 0xe0]
 [tos 0xe0]
09:28:47.418669 192.168.10.250.5060 > 80-239-235-195.customer.teliacarrier.com.5060: udp 620 [tos 0xe0]
It seems that I can not reach VoipStunt servers from my location...
Hmm. TCPDUMP in that form is not very self explaining. But I see lots of "udp 28", could be ICMP error packets.
Try to provide a trace which is telling a bit more than this.
Regards
SUCCEDED! It is working now!
14:20:45.673774 192.168.10.251.30000 > 194.221.62.164.41434: udp 172 [tos 0xe0]
14:20:45.686822 192.168.10.251.30000 > 194.221.62.164.41434: udp 172 [tos 0xe0]
14:20:45.691225 194.221.62.164.41434 > 192.168.10.251.30000: udp 172 (DF)
14:20:45.694736 194.221.62.164.41434 > 192.168.10.251.30000: udp 172 (DF)
14:20:45.703981 192.168.10.251.30000 > 194.221.62.164.41434: udp 172 [tos 0xe0]
14:20:45.715092 194.221.62.164.41434 > 192.168.10.251.30000: udp 172 (DF)
14:20:45.728701 192.168.10.251.30000 > 194.221.62.164.41434: udp 172 [tos 0xe0]
14:20:45.734482 194.221.62.164.41434 > 192.168.10.251.30000: udp 172 (DF)
14:20:45.754701 194.221.62.164.41434 > 192.168.10.251.30000: udp 172 (DF)
Thank you very much for your help!
PS. It is possble to do anything with TC 300 Sinus BaseStation in other location, excepting T-Com?
A kind of firmware for ADLS modem (PPPoE)?
pls post your solution, thx.
sinus tc 300 works with the analog PSTN ports of my touchstone arris cable modem as it should with every ITU compatible telephone network, at least in western europe.
uhm sorry, misunderstanding.
well the GPL sources are availlable on the T-Com supportsite, except for WLan driver and maybe other ADMtek proprietary parts. The ADM8668 core has ethernet ports build in, but not connected. adding driver circuits will be hard on that PCB and You need the full databook for the chip to add extra features to the firmware. And theres no real use for such a project, since the tc-300 can connect to every wlan/modem extended inet router.
I am thinking at something like m0n0wall or dd-wrt for using basestation like router in PSTN networks (simillary to speedtouch ADSL routers).
In my network (ROMTELECOM) ADSL is PPPoE type (VPI/VCI=0.35).
Heiko2026
