TK-Anlage an HFC-S NT-Mode, keine Rufumleitung möglich
MassiveBlue
1 Feb 2005
Hi!
Ich habe folgendes Problem:
In meinem Asterisk habe ich 2 HFC-S Karten, die mit den externen S0 meiner alten Agfeo-Telefonanlage verbunden sind. Die Teilnehmer an der Telefonanlage können auch problemlos rauswählen, nur wenn sie eine Rufumleitung in der Agfeo-Telefonanlage setzen, funktioniert das nicht.
Hier mal der Log-Auszug:
asterisk-rc*CLI>
    -- Executing Macro("SIP/40-4d63", "superdial|ZAP/g1/3812711||Ttm||pstn1||Mr.XYZ|40|pstn|u11") in new stack
    -- Executing SetGroup("SIP/40-4d63", "pstn1") in new stack
    -- Executing CheckGroup("SIP/40-4d63", "") in new stack
May  3 10:18:48 WARNING[6827]: app_groupcount.c:185 group_check_exec: CheckGroup requires an argument(max)
    -- Executing GotoIf("SIP/40-4d63", "0?macro-superdial|s|5") in new stack
    -- Executing SetCIDName("SIP/40-4d63", "Mr.XYZ") in new stack
    -- Executing GotoIf("SIP/40-4d63", "0?macro-superdial|s|7") in new stack
    -- Executing SetCIDNum("SIP/40-4d63", "40") in new stack
    -- Executing GotoIf("SIP/40-4d63", "0?macro-superdial|s|9") in new stack
    -- Executing SetAccount("SIP/40-4d63", "pstn") in new stack
    -- Executing Dial("SIP/40-4d63", "ZAP/g1/3812711||Ttm|") in new stack
    -- Called g1/3812711
    -- Started music on hold, class 'default', on SIP/40-4d63
    -- Zap/1-1 is making progress passing it to SIP/40-4d63
    -- Starting simple switch on 'Zap/2-1'
    -- Accepting overlap voice call from '11' to '<unspecified>' on channel 0/2, span 1
    -- Executing Macro("Zap/2-1", "superdial|SIP/01711234567@sipgate|30|Tt||||11|11|voip") in new stack
    -- Executing SetGroup("Zap/2-1", "") in new stack
May  3 10:18:51 WARNING[6827]: app_groupcount.c:144 group_set_exec: SetGroup requires an argument (group name)
    -- Executing CheckGroup("Zap/2-1", "") in new stack
May  3 10:18:51 WARNING[6827]: app_groupcount.c:185 group_check_exec: CheckGroup requires an argument(max)
    -- Executing GotoIf("Zap/2-1", "0?macro-superdial|s|5") in new stack
    -- Executing SetCIDName("Zap/2-1", "11") in new stack
    -- Executing GotoIf("Zap/2-1", "0?macro-superdial|s|7") in new stack
    -- Executing SetCIDNum("Zap/2-1", "11") in new stack
    -- Executing GotoIf("Zap/2-1", "0?macro-superdial|s|9") in new stack
    -- Executing SetAccount("Zap/2-1", "voip") in new stack
    -- Executing Dial("Zap/2-1", "SIP/01711234567@sipgate|30|Tt|") in new stack
    -- Called 01711234567@sipgate
    -- Channel 0/1, span 1 got hangup
    -- Hungup 'Zap/1-1'
  == No one is available to answer at this time
    -- Stopped music on hold on SIP/40-4d63
    -- Executing Goto("SIP/40-4d63", "s-NOANSWER|1") in new stack
    -- Goto (macro-superdial,s-NOANSWER,1)
    -- Executing GotoIf("SIP/40-4d63", "0?macro-superdial|s-NOANSWER|3") in new stack
    -- Executing VoiceMail("SIP/40-4d63", "u11") in new stack
May  3 10:18:52 WARNING[6827]: app_voicemail.c:1545 leave_voicemail: No entry in voicemail config file for '11'
    -- Executing NoOp("SIP/40-4d63", "") in new stack
May  3 10:18:52 NOTICE[6827]: chan_zap.c:8768 pri_dchannel: hangup, did not find cref 133, tei 0
May  3 10:18:52 WARNING[6827]: chan_zap.c:8769 pri_dchannel: Hangup on bad channel 0/1 on span 1
    -- Channel 0/2, span 1 got hangup
  == Spawn extension (macro-superdial, s, 9) exited non-zero on 'Zap/2-1' in macro 'superdial'
  == Spawn extension (from-internal, 01711234567, 1) exited non-zero on 'Zap/2-1'
    -- Hungup 'Zap/2-1'
May  3 10:18:56 NOTICE[6827]: chan_zap.c:8768 pri_dchannel: hangup, did not find cref 133, tei 0
May  3 10:18:56 WARNING[6827]: chan_zap.c:8769 pri_dchannel: Hangup on bad channel 0/1 on span 1
Stört euch da aber nicht an dem WARNING wegen dem SetGroup, es hat genauso nicht geklappt, als ich die gruppe noch gesetzt hatte.
Hier noch meine zapata.conf
[channels]
switchtype = euroisdn
signalling = bri_net
pridialplan = local
prilocaldialplan = local
nationalprefix = 0
internationalprefix = 00
echocancel = yes
overlapdial = yes
echotraining=100
echocancelwhenbridged=yes
immediate = no
usecallerid = yes
group = 1
context = from-internal
usecallingpres=yes
threewaycalling=yes
transfer=yes
cancallforward=yes
channel => 1-2
pridialplan = local
nationalprefix = 0
echocancel = yes
overlapdial = yes
echotraining=100
immediate = no
usecallerid = yes
group = 1
usecallingpres=yes
threewaycalling=yes
transfer=yes
cancallforward=yes
channel => 4-5
Falls ihr noch mehr Infos braucht, nur zu. Wollte jetzt der Lesbarkeit halber nicht zu viel posten.
MfG MassiveBlue
Das setzen von Rufumleitungen direkt ueber ISDN-Signalisierung ist mit Bristuff nicht moeglich. Da musst du entweder ne Sirrix-Karte kaufen oder das ganze ueber den Dialplan implementieren und dann halt immer die Rufumleitung ueber die Wahl von Ziffern setzen.
Die Umleitung geschieht ja durch die TK-Anlage. Im Falle einer Umleitung würden also 2 Kanäle belegt werden.
Kikii
