Tomato 1.26
  • Ersteller Ersteller Deleted member 193577
D
Guest
Zur Info, es gibt eine neue Version der Tomato Firmware: 1.26
Changelog
* Allow a different port to be entered in Basic:Network:Static DNS (enter as "ip:port"). Be aware that dnsmasq must act as the DNS server (the default setting) when not using the normal port 53.
* Allow DHCP to serve the user-entered gateway (in Basic:Network) if the option in Advanced:DHCP is enabled.
* Do not start miniupnpd early to avoid warning messages.
* Update Australian DST (need to re-select), add Darwin, Brisbane TZ. Thanks to Peter O. for the info.
* Avoid double loading of tomato.css
* Fix possible null dereference in sendpage
* Collapsed all menus. For the old look, set nvram: "web_mx=status,bwm,tools"
* Obscured some key/password fields when not in focus.
* Accept more than two MAC addresses per IP address (ex: one IP for a laptop either wired or wireless [one at a time]). Note: Some computers may not like seeing the same IP unless it's restarted.
* Added LED options back in Admin:Buttons/LED.
* Added ID for WLA2-G54L, TrueMobile 2300 thanks to Nick B. and David J.
* Added EditDNS thanks to Keith M.
* Added UTC+4:30 Kabul time zone.
* Fixed port set validation allowed more than what could be handled.
* Allow rstats to log if WAN port is used for LAN.
* Update dnsmasq to 2.51, miniupnpd 1.4, busybox 1.14.4, matrixssl 1.8.8.
http://www.polarcloud.com/
stefan311
