TR-069 not working over LAN to get credentials for SIP (Freez/Fritz7113)
davorj
31 Jul 2011
My ISP has apparently changed the SIP credentials – and they can’t tell me which they are. As far as I can tell, they are using TR-069 protocol to publish the credentials to their clients.
Usually this updating worked fine in the past. I could see some references to it in the event log. But since the DSL module broke I put my FrizBox in LAN mode, and it now doesn’t seem to update. Here is the export of the config file.
On the fritz, there are some TR-069 components working, like the crtmgr listening on port 8089, but I don’t know how I can use any of the tools to troubleshoot this.
Has anyone any pointers?
King Manaka
