Hi all,
make fails after lots of errors like below...
What should I do?
Is it otherwise possible to use the AVM webdav support?
Thanks in advance
[Edit frank_m24: Please use CODE Tags]
What should I do?
Thanks in advance
PATH="/home/gf/freetz-1.1.3/toolchain/target/bin:/bin:/sbin:/usr/bin:/usr/sbin:/usr/local/bin:/usr/local/sbin" \
make -j2 -C source/davfs2-1.4.5 \
LIBS="\$(NEON_LIBS)"
make[1]: Entering directory `/home/gf/freetz-1.1.3/source/davfs2-1.4.5'
make all-recursive
make[2]: Entering directory `/home/gf/freetz-1.1.3/source/davfs2-1.4.5'
Making all in po
make[3]: Entering directory `/home/gf/freetz-1.1.3/source/davfs2-1.4.5/po'
make[3]: Nothing to be done for `all'.
make[3]: Leaving directory `/home/gf/freetz-1.1.3/source/davfs2-1.4.5/po'
Making all in etc
make[3]: Entering directory `/home/gf/freetz-1.1.3/source/davfs2-1.4.5/etc'
make[3]: Leaving directory `/home/gf/freetz-1.1.3/source/davfs2-1.4.5/etc'
Making all in man
make[3]: Entering directory `/home/gf/freetz-1.1.3/source/davfs2-1.4.5/man'
Making all in de
make[4]: Entering directory `/home/gf/freetz-1.1.3/source/davfs2-1.4.5/man/de'
make[4]: Nothing to be done for `all'.
make[4]: Leaving directory `/home/gf/freetz-1.1.3/source/davfs2-1.4.5/man/de'
Making all in es
make[4]: Entering directory `/home/gf/freetz-1.1.3/source/davfs2-1.4.5/man/es'
make[4]: Leaving directory `/home/gf/freetz-1.1.3/source/davfs2-1.4.5/man/es'
make[4]: Entering directory `/home/gf/freetz-1.1.3/source/davfs2-1.4.5/man'
make[4]: Nothing to be done for `all-am'.
make[4]: Leaving directory `/home/gf/freetz-1.1.3/source/davfs2-1.4.5/man'
make[3]: Leaving directory `/home/gf/freetz-1.1.3/source/davfs2-1.4.5/man'
Making all in src
make[3]: Entering directory `/home/gf/freetz-1.1.3/source/davfs2-1.4.5/src'
/home/gf/freetz-1.1.3/toolchain/target/bin/mipsel-linux-uclibc-gcc -DPROGRAM_NAME=\"mount.davfs\" -DDAV_SYS_CONF_DIR=\"/etc/davfs2\" -DDAV_SYS_RUN=\"/var/run/mount.davfs\" -DDAV_SYS_CACHE=\"/var/cache/davfs2\" -DDAV_SECRETS=\"secrets\" -DDAV_CONFIG=\"davfs2.conf\" -DDAV_CERTS_DIR=\"certs\" -DDAV_CLICERTS_DIR=\"private\" -DDAV_DATA_DIR=\"/usr/share/davfs2\" -DLOCALEDIR=\"/usr/share/locale\" -DDAV_USER=\"davfs2\" -DDAV_GROUP=\"davfs2\" -DHAVE_CONFIG_H -I. -I.. -Wall -Os -pipe -march=4kc -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/gf/freetz-1.1.3/toolchain/build/gcc-4.2.1-uClibc-0.9.29/mipsel-linux-uclibc/usr/include/neon -MT webdav.o -MD -MP -MF .deps/webdav.Tpo -c -o webdav.o webdav.c
webdav.c:28:19: error: iconv.h: No such file or directory
webdav.c:200: error: expected '=', ',', ';', 'asm' or '__attribute__' before 'from_utf_8'
webdav.c:204: error: expected '=', ',', ';', 'asm' or '__attribute__' before 'to_utf_8'
webdav.c:208: error: expected '=', ',', ';', 'asm' or '__attribute__' before 'from_server_enc'
webdav.c:212: error: expected '=', ',', ';', 'asm' or '__attribute__' before 'to_server_enc'
webdav.c:230: error: expected declaration specifiers or '...' before 'iconv_t'
webdav.c: In function 'dav_init_webdav':
webdav.c:316: error: 'from_utf_8' undeclared (first use in this function)
webdav.c:316: error: (Each undeclared identifier is reported only once
webdav.c:316: error: for each function it appears in.)
webdav.c:316: warning: implicit declaration of function 'iconv_open'
webdav.c:317: error: 'iconv_t' undeclared (first use in this function)
webdav.c:319: error: 'to_utf_8' undeclared (first use in this function)
webdav.c:327: error: 'from_server_enc' undeclared (first use in this function)
webdav.c:328: error: 'to_server_enc' undeclared (first use in this function)
webdav.c: In function 'dav_conv_from_utf_8':
webdav.c:540: error: 'from_utf_8' undeclared (first use in this function)
webdav.c:541: error: too many arguments to function 'convert'
webdav.c: In function 'dav_conv_to_utf_8':
webdav.c:550: error: 'to_utf_8' undeclared (first use in this function)
webdav.c:551: error: too many arguments to function 'convert'
webdav.c: In function 'dav_conv_from_server_enc':
webdav.c:560: error: 'from_server_enc' undeclared (first use in this function)
webdav.c:561: error: too many arguments to function 'convert'
webdav.c: In function 'dav_conv_to_server_enc':
webdav.c:570: error: 'to_server_enc' undeclared (first use in this function)
webdav.c:571: error: too many arguments to function 'convert'
webdav.c: At top level:
webdav.c:1241: error: expected declaration specifiers or '...' before 'iconv_t'
webdav.c: In function 'convert':
webdav.c:1250: warning: implicit declaration of function 'iconv'
webdav.c:1250: error: 'conv' undeclared (first use in this function)
webdav.c: In function 'prop_result':
webdav.c:1774: error: 'from_server_enc' undeclared (first use in this function)
webdav.c:1775: error: too many arguments to function 'convert'
make[3]: *** [webdav.o] Error 1
make[3]: Leaving directory `/home/gf/freetz-1.1.3/source/davfs2-1.4.5/src'
make[2]: *** [all-recursive] Error 1
make[2]: Leaving directory `/home/gf/freetz-1.1.3/source/davfs2-1.4.5'
make[1]: *** [all] Error 2
make[1]: Leaving directory `/home/gf/freetz-1.1.3/source/davfs2-1.4.5'
make: *** [source/davfs2-1.4.5/src/mount.davfs] Error 2
