Ubuntu 10.04, Asterisk 1.6.2.15 Problem bei AVM FritzCard PCI V2.0
felixdong
20 Jan 2011
für meine Diplomarbeit habe eine Asterisk PBX mit IDSN Schnittstelle eingerichtet. Für den eingehenden Anruf scheint mir folgendes:
== ISDN1#02: Incoming call '3825' -> ''
== ISDN1#02: CAPI Hangingup for PLCI=0x101 in state 4
Nach Aktivierung des Capi Debug Modes:
CAPI: ApplId=0x0003 Command=0x02 SubCommand=0x82 MsgNum=0x003a NCCI=0x00000101
CONNECT_IND ID=003 #0x003a LEN=0034
Controller/PLCI/NCCI = 0x101
CIPValue = 0x10
CalledPartyNumber = default
CallingPartyNumber = <00 80>3825
CalledPartySubaddress = default
CallingPartySubaddress = default
BC = <80 90 a3>
LLC = default
HLC = <91 81>
AdditionalInfo = default
-- CONNECT_IND (PLCI=0x101,DID=,CID=3825,CIP=0x10,CONTROLLER=0x1)
== ISDN1#02: setting format alaw - 0x8 (alaw)
CAPI: ApplId=0x0003 Command=0x08 SubCommand=0x82 MsgNum=0x003b NCCI=0x00000101
INFO_IND ID=003 #0x003b LEN=0019
InfoNumber = 0x28
InfoElement = 3825
INFO_RESP ID=003 #0x003b LEN=0012
-- ISDN1#02: info element DSP
CAPI: ApplId=0x0003 Command=0x08 SubCommand=0x82 MsgNum=0x003c NCCI=0x00000101
INFO_IND ID=003 #0x003c LEN=0016
InfoNumber = 0x18
InfoElement = <89>
INFO_RESP ID=003 #0x003c LEN=0012
-- ISDN1#02: info element CHANNEL IDENTIFICATION 89
CAPI: ApplId=0x0003 Command=0x08 SubCommand=0x82 MsgNum=0x003f NCCI=0x00000101
INFO_IND ID=003 #0x003f LEN=0019
InfoNumber = 0x28
InfoElement = 3825
INFO_RESP ID=003 #0x003f LEN=0012
CAPI: ApplId=0x0003 Command=0x08 SubCommand=0x82 MsgNum=0x0040 NCCI=0x00000101
INFO_IND ID=003 #0x0040 LEN=0016
InfoNumber = 0x18
InfoElement = <89>
INFO_RESP ID=003 #0x0040 LEN=0012
CAPI: ApplId=0x0003 Command=0x08 SubCommand=0x82 MsgNum=0x0041 NCCI=0x00000101
INFO_IND ID=003 #0x0041 LEN=0019
InfoNumber = 0x28
InfoElement = 3825
INFO_RESP ID=003 #0x0041 LEN=0012
CAPI: ApplId=0x0003 Command=0x08 SubCommand=0x82 MsgNum=0x0042 NCCI=0x00000101
INFO_IND ID=003 #0x0042 LEN=0016
InfoNumber = 0x18
InfoElement = <89>
INFO_RESP ID=003 #0x0042 LEN=0012
CAPI: ApplId=0x0003 Command=0x04 SubCommand=0x82 MsgNum=0x0043 NCCI=0x00000101
DISCONNECT_IND ID=003 #0x0043 LEN=0014
Reason = 0x0
DISCONNECT_RESP ID=003 #0x0043 LEN=0012
-- ISDN1#02: DISCONNECT_IND on incoming without pbx, doing hangup.
> CAPI/ISDN1#02/-0: set channel task to 1
== ISDN1#02: Interface cleanup PLCI=0x101
> chan_capi devicestate requested for ISDN1#02/ is 'Not in use'
Der Inhalt der capi.conf Datei:
; CAPI config
[general]
nationalprefix=0
internationalprefix=00
rxgain=0.8
txgain=0.8
[ISDN1]
; mode: ptmp (point-to-multipoint) or ptp (point-to-point)
isdnmode=msn
; allow incoming calls to this list of MSNs, * == any
incomingmsn=*
; capi controller number
controller=1
; dialout group
group=1
; enable/disable software dtmf detection, recommended for AVM cards
softdtmf=yes
; accountcode to use in CDRs
accountcode=
; context for incoming calls
context=capi-in
; _VERY_PRIMITIVE_ echo suppression
;echosquelch=1
; EICON DIVA SERVER echo cancelation
;echocancel=yes
;echotail=64
; call group
;callgroup=1
; deflect incoming calls to 12345678 if all B channels are busy
;deflect=12345678
; number of concurrent calls on this controller (2 makes sense for single BRI)
devices => 2
Kann jemand mir dabei helfen?:p
PS: Die anrufende Nummer 3825 ist eine interne Rufnummer von der Firma, die extern unter Vorwahl+Ortswahl+Durchwanl+3825 erreichbar ist.
Kannst Du mal verbose auf 3 setzen und dann die CLI Ausgabe posten (ohne CAPI debug). Ich vermute, Du hast das übliche Problem mit dem Call Setup.
Ach ja, und zeig auch gleich den [capi-in] aus der extensions.conf.
Verbose 3:
Ohne Debug wird gar nichts im CLI angezeigt.
Mit Debug ist wie folgendes:
Kontext aus extensions.conf:
[capi-in]
exten => _.,1,Answer()
exten => _.,n,Playback(hello-world)
exten => _.,n,Hangup()
Ich vermute, dass es mit dem Kontext aus extensions.conf nix zu tun hat. :)
Das Problem ist, die angerufene Nummer wurde nicht erfasst. Hat jemand eine Idee. Liegt es an der TK-Anlage der Firma selber?
Feedback:
Hab die Zeile immediate=yes in capi.conf hinzugefügt. Das Problem hat sich somit erledigt.
Callendaar
