uc500 analoges fax | keine Faxe eingehend
crus4der
19 Apr 2006
ich habe ein analoges Fax an einem der 4 fxs Ports. Heraus faxen funktioniert nur herein kommen keine Faxe bzw. das Faxgerät wird erst gar nicht angesprochen. Wenn ich auf die Faxnummer anrufe bekomme ich ein Freizeichen.
Faxnummer: 5019150
Config:
voice-port 0/0/1
 timeouts ringing infinity
 station-id name FAX
 station-id number 5019150
dial-peer voice 2 pots
 destination-pattern 5019150
 port 0/0/1
debug:
UC520#
Jun 10 01:40:57.483: ISDN BR0/1/1 Q931: RX <- SETUP pd = 8  callref = 0x01
        Sending Complete
        Bearer Capability i = 0x8090A3
                Standard = CCITT
                Transfer Capability = Speech
                Transfer Mode = Circuit
                Transfer Rate = 64 kbit/s
        Channel ID i = 0x89
                Exclusive, B1
        Calling Party Number i = 0x2183, '1752xxxx'
                Plan:ISDN, Type:National
        Called Party Number i = 0xC1, '5019150'
                Plan:ISDN, Type:Subscriber(local)
        High Layer Compat i = 0x9181
Jun 10 01:40:57.495: ISDN BR0/1/0 Q931: Applying typeplan for sw-type 0x1 is 0x2 0x1, Calling num 001752xxxx
Jun 10 01:40:57.495: ISDN BR0/1/0 Q931: Applying typeplan for sw-type 0x1 is 0x4 0x1, Called num 50
Jun 10 01:40:57.495: ISDN BR0/1/1 Q931: TX -> CALL_PROC pd = 8  callref = 0x81
        Channel ID i = 0x89
                Exclusive, B1
Jun 10 01:40:57.495: ISDN BR0/1/0 Q931: TX -> SETUP pd = 8  callref = 0x72
                Standard = CCITT
        Channel ID i = 0x81
                Preferred, B1
        Progress Ind i = 0x8183 - Origination address is non-ISDN
        Calling Party Number i = 0x2183, '001752xxxx'
        Called Party Number i = 0xC1, '50'
        Sending Complete
Jun 10 01:40:57.631: ISDN BR0/1/0 Q931: RX <- CALL_PROC pd = 8  callref = 0xF2
        Channel ID i = 0x89
                Exclusive, B1
        Progress Ind i = 0x8288 - In-band info or appropriate now available
Jun 10 01:40:57.639: ISDN BR0/1/1 Q931: TX -> ALERTING pd = 8  callref = 0x81
Jun 10 01:40:57.651: ISDN BR0/1/0 Q931: RX <- DISCONNECT pd = 8  callref = 0xF2
        Cause i = 0x829C - Invalid number format (incomplete number)
Jun 10 01:41:24.171: ISDN BR0/1/1 Q931: RX <- DISCONNECT pd = 8  callref = 0x01
        Cause i = 0x8090 - Normal call clearing
Jun 10 01:41:24.175: ISDN BR0/1/1 Q931: TX -> RELEASE pd = 8  callref = 0x81
Jun 10 01:41:24.183: ISDN BR0/1/0 Q931: TX -> RELEASE pd = 8  callref = 0x72
Meine Vermutung liegt bei der translation-rule. Ich lasse die Nummer nach intern folgendermaßen übersetzten:
voice translation-rule 1
 rule 1 /501910/ /40/
 rule 2 /50191/ //
und die 50 gibt es ja natürlich nicht als Extension. Habt ihr eine Idee wie das lösen kann?
Gruss
Nabend,
bisschen sehr kurz und unpräzise Deine Angaben bezgl. Translation-Rule. Wo hängt die dran? Am eingehenden Port? BRI? Wie sieht die komplette config des Ports aus? Soweit ich das sehe wird ja die Nummer 5019150 durch 50 ersetzt. Die kommt dann ja auch via ISDN rein (Called Numer). Wenn es dazu kein Ziel gibt - das Fax hat als dest-pattern 5019150 - ist das klar das da nix klingelt. Also erstmal dest-pattern auf 50 ändern und dann im BRI noch direct-inward-dial eingeben und gucken obs klingelt...
Ciao
Hi vielen Dank für deine Antwort.
Sorry falls die Infos zu kurz waren. ich war mir nicht ganz sicher was genau von Interesse sein könnte.
Also das destination-pattern hat auf jedenfall das Problem gelöst :-) habe es auf die 50 geändert und schwubs kommen auch faxe an.
Manchmal ist es doch zu einfach :D
Gruss
Koilyutra
