Unable to create channel of type 'SIP' (cause 20 - Unknown)
Kip86
23 Sep 2008
Hi!
Habe wieder einen Denkfehler :(
Funktionieren tut: Mailbox, Extern telefonieren, von 901 auf 910 rufen :confused:
Nicht funktionieren tut: Intern Telefonieren (bis auf o.g.), Extern angerufen werden
Hier meine Configs:
sip.conf
[901]
type=friend
regexten=900                   ; When they register, create extension 900
callerid="xxx" <900>
host=dynamic                    ; This device needs to register
nat=yes                         ; X-Lite is behind a NAT router
canreinvite=no                  ; Typically set to NO if behind NAT
;disallow=all
;allow=gsm                       ; GSM consumes far less bandwidth than ulaw
;allow=ulaw
;allow=alaw
mailbox=900@default		; Subscribe to status of mailbox
registertrying=yes              ; Send a 100 Trying when the device registers.
secret=xxx
context=sipphones90
(902 sieht bis auf die Zahlen genauso aus)
[910]
type=friend
regexten=910                   ; When they register, create extension 910
callerid="xxx" <910>
;disallow=all
;allow=ulaw
;allow=alaw
secret=xxx
context=sipphones91
[sipgate-out]
type=peer
username=7xxx
fromuser=7xxx
secret=xxx
host=sipgate.at
fromdomain=sipgate.at
insecure=port,invite
canreinvite=no
nat=no
disallow=all
allow=ulaw
[internetcalls90-out]
type=peer
username=xxx
fromuser=xxx
secret=xxx
host=sip.internetcalls.com
fromdomain=sip.internetcalls.com
canreinvite=no
nat=no
disallow=all
allow=ulaw
fromuser=431xxx
[internetcalls91-out]
type=peer
username=xxx
fromuser=xxx
secret=xxx
canreinvite=no
nat=no
disallow=all
allow=ulaw
fromuser=432xxx
[7xxx]
type=peer
username=7xxx
fromuser=7xxx
secret=xxx
host=sipgate.at
canreinvite=no
nat=no
disallow=all
allow=ulaw
extensions.conf:
[incoming]
exten => 7xxx,1,Dial(SIP/901&SIP/902,15)
exten => 7xxx,2,VoiceMail(900)
exten => 7xxx,3,HangUp
include => intern
[intern]
exten => 900,1,Dial(SIP/901&SIP/902,15)
exten => 900,2,VoiceMail(900)
exten => 900,n,HangUp
exten => _9XX,1,Dial(SIP/${EXTEN},20)
exten => _9XX,2,VoiceMail(${EXTEN})
exten => _9XX,n,HangUp
exten => 999,1,VoicemailMain(s${CALLERID(num)})
exten => 999,2,Hangup
exten => _X.,1,Dial(SIP/${EXTEN}@internetcalls90-out,,r)
exten => _X.,1,Dial(SIP/${EXTEN}@internetcalls91-out,,r)
[sipgate-out]
exten => _9.,1,Dial(SIP/${EXTEN:1}@sipgate-out,60)
exten => _9.,2,Congestion
exten => _9.,102,Busy
[sipphones90]
include => intern
include => incoming
include => sipgate-out
include => internetcalls90-out
[sipphones91]
include => intern
include => incoming
include => internetcalls91-out
Wenn ich von extern meine Sipgate-Nummer anrufe:
== Using SIP RTP CoS mark 5
-- Executing [7xxx@incoming:1] Dial("SIP/sipgate-out-007a9d08", "SIP/901&SIP/902,15") in new stack
-- Called 901
Wieso ruft der sipgate-out?!?!
Wenn ich intern von 910 auf 901 rufe:
-- Executing [901@sipphones91:1] Dial("SIP/910-007a9d08", "SIP/901,20") in new stack
-- Called 901
Wieso ruft der 910, wo ich doch von 910 anrufe?!
Ich verstehs nicht :grab:
LG und bedanke mich schonmal fürs Lesen :D
Ich habe ernsthaft nichts verändert, jetzt nochmal getestet und es geht wieder :?
Fehlermeldung ist aber immernoch da:
[Sep 23 19:52:25] WARNING[22304]: app_dial.c:1528 dial_exec_full: Unable to create channel of type 'SIP' (cause 20 - Unknown)
W
Der Ruft nicht sipgate out, sipgate-out ruft 901 und 902
sonst müsste es heissen 901@sipgate-out
eigentlich dürfte das gar nicht funktionieren, denn es fehlt die Zeile context=incomming im Kontext [7xxx].
Das bedeutet, du hast noch einen Kontext default den du uns unterschlagen hast. Über den kommt dein Anruf rein.
Callendaar
