[Frage] usb isdn to asterisk
binary_dreamer
24 Jul 2009
hi. i am running asterisk in a debian box in Alix 2d3. i would like to make use of my ISDN connection (4 numbers).
i came across the AVM USB ISDN v2 and i would like to know if someone had a similar request or had used any USB ISDN with success.
the box is running debian wheezy with asterisk 11.4
If you're lucky, the box is supported by mISDN. In case it is, you can use chan_lcr to connect Asterisk. Otherwise you could try CAPI and chan_capi.
Recently, I had a HFC based USB ISDN interface up and running and just this weekend I'm going to give something similar a try again. Please let me know how you've done it, if you were quicker than me and did it successfully.
actually, i did not buy it yet. i am looking to buy it and i would like to know which one works best for the job.
is there a well know to work usb to ISDN?
IchBinEsDoch
