usbhost.users_enabled missing in ar7.cfg
johnbock
2 Mrz 2008
I was reviewing the avm samba control system and the above stuck out at me. Just a moment ago searched the entire original build path for references and found them in
  • build/original/filesystem/etc/hotplug/run_mount
  • build/original/filesystem/etc/hotplug/storage
  • build/original/filesystem/etc/samba_control
On my box I wasn't able to find any configuration for it though:confused: This feature seems to control unconditional rw access (independent of configured ro/passwd) to the different subsystems.
The missing configuration may lead to ro access to the above.
Is this a depreciated feature that hasn't been removed in the subsequent avm releases?
Auf keiner meiner Boxen liefert users_enabled einen Wert. Hast du dir die /etc/default.samba/samba_conf vom Freetz-Samba 3 angeschaut? Da wird usbhost.readonly für ro/rw genutzt, allerdings nur für die AVM-Freigaben. Eigentlich sollte das doch kein Problem sein
figo12
