Using SIP REFER on Fritz Box
stefanoIT
11 Jul 2007
I'm successfully used REFER message on a fritz box to transfer a call on a different SIP URI. That works.
My question is: is possible use a particular SIP URI in Refer-To header to make a call using fritz box resources (i.e. dialplan, fixed line, etc.).
I would use a USI sip:number instead of sip:number@domanin so fritzbox use own dialplan to place the call.
Thanks.
Stefano
I didn't understand, what you want:
how do you use a certain SIP-Message? - Do you use an IP phone as client connected to the fritzbox? - do you call the fritzbox externally from an IP phone?
I think you should ask your question in the section "telefon" of this forum as I don't see a link to the topic of this section ("avm software").
regards,
Pfeffer.
JSt Aero
