CONNECT_IND ID=002 #0x03d0 LEN=0048
Controller/PLCI/NCCI = 0x101
CIPValue = 0x10
CalledPartyNumber = <c1>69******
CallingPartyNumber = <21 83>1775******
CalledPartySubaddress = default
CallingPartySubaddress = default
BC = <80 90 a3>
LLC = default
HLC = <91 81>
AdditionalInfo = default
-- CONNECT_IND (PLCI=0x101,DID=69******,CID=1775******,CIP=0x10,CONTROLLER=0x1)
> ISDN1#02: msn='*' DNID='69******' MSN
== ISDN1#02: setting format alaw - 0x8 (alaw)
== ISDN1#02: Incoming call '01775******' -> '69******'
INFO_IND ID=002 #0x03d1 LEN=0023
InfoNumber = 0x70
InfoElement = <c1>69******
INFO_RESP ID=002 #0x03d1 LEN=0012
-- ISDN1#02: info element CALLED PARTY NUMBER
> ISDN1#02: INFO_IND DID digits not used in this state.
INFO_IND ID=002 #0x03d2 LEN=0016
InfoNumber = 0x18
InfoElement = <89>
INFO_RESP ID=002 #0x03d2 LEN=0012
-- ISDN1#02: info element CHANNEL IDENTIFICATION 89
INFO_IND ID=002 #0x03d3 LEN=0016
InfoNumber = 0xa1
InfoElement = <a1>
INFO_RESP ID=002 #0x03d3 LEN=0012
-- ISDN1#02: info element Sending Complete
-- ISDN1#02: CAPI/ISDN1#02/69******-2: 69****** matches in context eingehend
> CAPI devicestate requested for ISDN1#02/69******
-- Executing [69******@eingehend:1] Answer("CAPI/ISDN1#02/69******-2", "") in new stack
== ISDN1#02: Answering for 69******
CONNECT_RESP ID=002 #0x03d0 LEN=0043
Reject = 0x0
BProtocol
B1protocol = 0x1
B2protocol = 0x1
B3protocol = 0x0
B1configuration = default
B2configuration = default
B3configuration = default
GlobalConfiguration = default
ConnectedNumber = <00 80>69******
ConnectedSubaddress = default
LLC = default
AdditionalInfo
BChannelinformation = default
Keypadfacility = default
Useruserdata = default
Facilitydataarray = default
SendingComplete = default
-- Executing [69******@eingehend:2] Wait("CAPI/ISDN1#02/69******-2", "1") in new stack
== Started pbx on channel CAPI/ISDN1#02/69******-2
CONNECT_ACTIVE_IND ID=002 #0x03d4 LEN=0015
ConnectedNumber = default
LLC = default
CONNECT_ACTIVE_RESP ID=002 #0x03d4 LEN=0012
CONNECT_B3_IND ID=002 #0x03d5 LEN=0013
Controller/PLCI/NCCI = 0x10101
NCPI = default
CONNECT_B3_RESP ID=002 #0x03d5 LEN=0015
Reject = 0x0
NCPI = default
CONNECT_B3_ACTIVE_IND ID=002 #0x03d6 LEN=0013
NCPI = default
CONNECT_B3_ACTIVE_RESP ID=002 #0x03d6 LEN=0012
-- Executing [69******@eingehend:5] Dial("CAPI/ISDN1#02/69******-2", "SIP/02*******@arcor|200|Ttr") in new stack
-- Called 023196******@arcor
== ISDN1#02: Requested RINGING-Indication for CAPI/ISDN1#02/69******-2
-- ISDN1#02: attempting ALERT in state 2
CONNECT_IND ID=002 #0x05d8 LEN=0037
Controller/PLCI/NCCI = 0x201
CIPValue = 0x4
CalledPartyNumber = <c1>96******
CallingPartyNumber = <00 a3>
BC = <90 90 a3>
LLC = default
HLC = default
-- CONNECT_IND (PLCI=0x201,DID=96******,CID=,CIP=0x4,CONTROLLER=0x1)
> ISDN1#01: msn='*' DNID='96******' MSN
== ISDN1#01: setting format alaw - 0x8 (alaw)
== ISDN1#01: Incoming call '' -> '96******'
INFO_IND ID=002 #0x05d9 LEN=0017
InfoNumber = 0x1e
InfoElement = <82 83>
INFO_RESP ID=002 #0x05d9 LEN=0012
-- ISDN1#01: info element PI 82 83
> ISDN1#01: Origination is non ISDN
INFO_IND ID=002 #0x05da LEN=0024
InfoNumber = 0x70
InfoElement = <c1>96******
INFO_RESP ID=002 #0x05da LEN=0012
-- ISDN1#01: info element CALLED PARTY NUMBER
> ISDN1#01: INFO_IND DID digits not used in this state.
INFO_IND ID=002 #0x05db LEN=0016
InfoNumber = 0x18
InfoElement = <8a>
INFO_RESP ID=002 #0x05db LEN=0012
-- ISDN1#01: info element CHANNEL IDENTIFICATION 8a
INFO_IND ID=002 #0x05dc LEN=0016
InfoNumber = 0xa1
InfoElement = <a1>
INFO_RESP ID=002 #0x05dc LEN=0012
-- ISDN1#01: info element Sending Complete
-- ISDN1#01: CAPI/ISDN1#01/96******-3: 96****** matches in context eingehend
> CAPI devicestate requested for ISDN1#01/96******
-- Executing [96******@eingehend:1] Goto("CAPI/ISDN1#01/96******-3", "023196******|s|1") in new stack
-- Goto (023196******,s,1)
== Auto fallthrough, channel 'CAPI/ISDN1#01/96******-3' status is 'UNKNOWN'
== ISDN1#01: CAPI Hangingup for PLCI=0x201 in state 8
-- ISDN1#01: activehangingup (cause=0) for PLCI=0x201
CONNECT_RESP ID=002 #0x05d8 LEN=0019
Reject = 0x2
BProtocol = default
LLC = default
DISCONNECT_IND ID=002 #0x05dd LEN=0014
Reason = 0x0
DISCONNECT_RESP ID=002 #0x05dd LEN=0012
== ISDN1#01: Interface cleanup PLCI=0x201
-- SIP/arcor-081fd488 is making progress passing it to CAPI/ISDN1#02/69******-2
-- ast_get_srv: SRV lookup for '_sip._udp.0231.sip.arcor.de' mapped to host sbc.dus3-4.sip.arcor.de, port 5060
[Jan 16 13:12:29] WARNING[7562]: chan_sip.c:12416 handle_response_register: Got 200 OK on REGISTER that isn't a register
-- SIP/arcor-081fd488 answered CAPI/ISDN1#02/69******-2
== ISDN1#02: Requested Indication-STOP for CAPI/ISDN1#02/69******-2
== Spawn extension (eingehend, 69******, 5) exited non-zero on 'CAPI/ISDN1#02/69******-2'
== ISDN1#02: CAPI Hangingup for PLCI=0x101 in state 2
-- ISDN1#02: activehangingup (cause=16) for PLCI=0x101
DISCONNECT_B3_REQ ID=002 #0x1670 LEN=0013
NCPI = default
DISCONNECT_B3_CONF ID=002 #0x1670 LEN=0014
Info = 0x0
DISCONNECT_B3_IND ID=002 #0x16ed LEN=0015
Reason_B3 = 0x3301
NCPI = default
DISCONNECT_B3_RESP ID=002 #0x16ed LEN=0012
DISCONNECT_REQ ID=002 #0x1671 LEN=0013
DISCONNECT_CONF ID=002 #0x1671 LEN=0014
Info = 0x0
DISCONNECT_IND ID=002 #0x16ee LEN=0014
Reason = 0x3400
DISCONNECT_RESP ID=002 #0x16ee LEN=0012
== ISDN1#02: Interface cleanup PLCI=0x101
