Vigor 2900V Firmware 2.5.8
eisen
16 Mai 2005
Release Notes for Vigor2900V Series
Firmware Version : v2.5.8
Release Date : April. 04 2006
Applied Models : Vigor2900V series
Please ensure you download and use the latest router tools when upgrading the firmware.
[Improvement and Correct problems]
1. Improve Denmark type DTMF CallerID.
2. Correct 1st subnet hosts can't visit WAN IP to manage the router issue.
3. Improve PPPoE interoperability with German Arcor ISP.
4. Correct NAT Loopback not work issue.
5. Improve WPA stability.
6. Correct WUI button error in LAN-To-LAN "more" setup page.
7. Other minor problem corrections.
[Changes in v2.5.7]
[New Features]
VOIP Part:
1. Support VoIP supplementary service functions including:
1-1. call forwarding (always/busy/no answer)
1-2. DND(Do Not Disturb).
1-3. call waiting.
1-4. call transfer.
2. Support T.38 fax relay function.
3. Support port fallover function.
4. Support Hotline function.
WLAN Part:
1.WPA2
2.Access Control,WLAN Isolation
3.Access Point Discovery
4.WDS(Wireless Distribution System)
[Improvements]
1. Add TearDrop/New TearDrop, Bonk Attack detection.
2. Support IP un-number in 2nd subnet.
3. Support VCI less than 33.
[Corrected Problem]
1. Correct eMule + KAD will buffer leakage.
2. Correct 2nd subnet NAT-loopback problem can't passthrough UDP.
3. Correct arp table buffer leakage problem.
4. Correct USB Printer can't be detect after Router power-on.
5. Correct QoS may crash Router.
[END oF FILE]
hab meinen 2900V mal geupdatet...bis jetzt läufts problemlos...
nikitarajusa
