VoIP Connection between 7170 and 7270
elbestcall
2 Jul 2010
I am a user fritz box 7170 and fritz box 7270 . I want to make a TOIP between my two routers using a softphone (X-Lite) and DECT, without forgetting of course SIP. I made a VPN connection between the fritz (it worked well), the problem is that my local displays fritz "FRITZ!Box has no registration information for an Internet telephony provider", and the other poste "Number's 2004 appeal, unregistered".
il y a t-il quelqu'un qui peut m'aider!!!!
Two options:
(1) you need to enter a pseudo-VoIP account into the called box, assigning it a random telephone number xxx as the user name. Using a modification tool described elsewhere in this forum, mark this dummy VoIP account as "do_not_register = yes". This keeps the account from trying to find a provider. In the calling box enter as a shortcut in the telephone book the SIP-URI xxx@remoteip ("xxx" is the remote number and "remoteip" is the IP address of the remote box). Now you may make a direct IP call from one to the other FBF.
(2) if you use the SIP registrar on the remote box, you can register the calling box in the called box as a "VoIP extension number". This way, the called box appears on the calling box just like any provider.
--gandalf.
Yheikjhrya
