Hier meine aktuelle Config:
Current configuration : 3215 bytes
version 12.3
service timestamps debug datetime msec
service timestamps log datetime msec
no service password-encryption
hostname CME
boot-start-marker
boot-end-marker
tdm clock bri-auto
voice-card 2
no aaa new-model
ip subnet-zero
no ip domain lookup
ip dhcp excluded-address 10.1.100.253 255.255.255.0
ip dhcp excluded-address 10.1.200.253 255.255.255.0
ip dhcp pool Daten
network 10.1.100.0 255.255.255.0
default-router 10.1.100.254
domain-name cisco.com
ip dhcp pool voice
network 10.1.200.0 255.255.255.0
default-router 10.1.200.254
option 150 ip 10.1.200.254
ip cef
ip audit notify log
ip audit po max-events 100
ip ssh break-string
no ftp-server write-enable
password encryption aes
isdn switch-type basic-net3
no crypto isakmp enable
translation-rule 1
Rule 0 ^.% 0 national national
Rule 1 ^.% 00 international international
interface FastEthernet0/0
no ip address
speed auto
interface FastEthernet0/0.100
description Subinterface Trunkport Daten
encapsulation dot1Q 100
ip address 10.1.100.254 255.255.255.0
interface FastEthernet0/0.200
description Subinterface Trunkport Voice
encapsulation dot1Q 200
ip address 10.1.200.254 255.255.255.0
interface Serial1/0
no ip address
shutdown
no fair-queue
interface BRI2/0
no ip address
isdn overlap-receiving
isdn protocol-emulate network
isdn tei-negotiation first-call
isdn incoming-voice voice
no isdn outgoing display-ie
isdn skipsend-idverify
interface BRI2/1
description VOICE_GATEWAY_ISDN_TK
no ip address
isdn point-to-point-setup
isdn layer1-emulate network
ip classless
no ip http server
no ip http secure-server
tftp-server flash
00303020214.bin
tftp-server flash:CP79050101SCCP030530B.sbin
control-plane
voice-port 2/0
translate calling 1
compand-type a-law
cptone DE
bearer-cap 3100Hz
voice-port 2/1
translate calling 1
compand-type a-law
cptone DE
bearer-cap 3100Hz
dial-peer voice 1 pots
destination-pattern 0671xxxxxxx
incoming called-number 0671xxxxxxx
direct-inward-dial
port 2/1
dial-peer voice 3 voip
destination-pattern 0671xxxxx..
num-exp 4.. 0671xxxxx..
telephony-service
load 7960-7940 P00303020214
load 7905 CP79050101SCCP030530B
max-ephones 10
max-dn 10
ip source-address 10.1.200.254 port 2000
auto assign 1 to 10
system message VoIP Telefonie
user-locale DE
network-locale DE
create cnf-files version-stamp 7960 Jul 06 2005 10:01:26
dialplan-pattern 1 0671xxxxx.. extension-length 2
max-conferences 4
time-format 24
date-format dd-mm-yy
dn-webedit
time-webedit
transfer-system full-consult
ephone-dn 1
number 91
name Dario
ephone-dn 2
number 92
name peter
ephone 1
mac-address 000E.D759.5C3D
type 7905
button 1:1
ephone 2
mac-address 000E.D7B1.1D2C
type 7940
button 1:2
