[Problem] VPN in: connection to internal server blocked by outgoing filter !?
cgabriel
2 Sep 2006
I don't know all the German words for this, so here it is in English...
I have a properly working FB 7490 with VPN in; I also have a few internal machines (vuplus receiver, nas) which I access over normal http web interface, either from local network for via VPN. Everything works fine.
Now I wanted to protect my connection from "unauthorized" internet usage (read p2p and similar).
I created a virtual Netzwerkanwendung "Unsafe" containing all TCP/UDP ports above 5500 (outgoing = Zielport).
When I added this list to the "Standard" profile, I can't access my internal servers via http from VPN!
With netstat I see that the source port of the http connection is usually a high value (> 50000), and it looks like the blocking rule is applicable to those connections over VPN!
Is this a known problem, is it "by design", is there a solution ???
Thanks,
Gabriel
P.S. I can read German replies :)
najsai
