[Problem] VTH5441G Bootvorgang unterbinden nicht möglich via UART
Alex1812A
8 Feb 2021
bei einem Recovery Versuch einer VTH5441G habe ich zwar einen Bootlog, jedoch lässt sich der Bootvorgang durch drücken von * nicht unterbinden. Meine Frage wäre, ob man bei diesen Geräten eine andere Tastenkombi betätigen muss, um in die UART Konsole reinzukommen...?
Danke für jeden Tip!
HELLO! BOOT0 is starting! Mar 12 2019 03:15:40
boot0 version : 4.0.0
boot0 commit : 8
i2c gpio config 22777722
axp209 read error
axp152 read error
DRAM DRIVE INFO: V0.7
DRAM Type = 3 (2:DDR2,3:DDR3,6:LPDDR2,7:LPDDR3)
DRAM CLK = 672 MHz
DRAM zq value: 000039bb
DRAM size = 128 MB
Reg 0x01c20848: 0x00003333
0x01c20028 0x90041811
0x01c200a0 0x8100000f
SpiNand_read_id 00000000 000000ef 000000aa
SPN_BLOCK_SIZE 131072
SPN_PAGE_SIZE 2048
spinand UBOOT_LAST_BLK_NUM 19
Succeed in opening spi nand flash.
Succeed in reading Boot1 file head.
current block is 2.
current block is 3.
current block is 4.
current block is 5.
current block is 6.
current block is 7.
sum=832c0e3e
src_sum=832c0e3e
The file stored in block 2 to block 6 is perfect.
----------storage_type = 5 in boot0-------------------------
Ready to disable icache.
Jump to secend Boot.
[ 0.489]
U-Boot 2011.09-rc1-svn6551 (Aug 01 2024 - 08:10:34)
[ 0.496]version: 1.1.0
[ 0.499]uboot commit : 8
[ 0.504]pmbus: ready
not set main pmu id
axp read error
probe axp20x failed
axp152 read error
probe axp15 failed
axp_probe error
set power on vol to default
dcdc2_vol = 1100
axp set dcdc2_vol to 1100 failed
dcdc3_vol = 3300
axp set dcdc3_vol to 3300 failed
aldo2_vol = 2500
axp set aldo2_vol to 2500 failed
aldo3_vol = 3000
axp set aldo3_vol to 3000 failed
ldo1_vol = 3300
axp set ldo1_vol to 3300 failed
ldo2_vol = 3000
axp set ldo2_vol to 3000 failed
ldo3_vol = 3000
axp set ldo3_vol to 3000 failed
ldo4_vol = 1800
axp set ldo4_vol to 1800 failed
find power_sply to end
vbus exist
no battery, limit to dc
[ 0.764]DRAM: LogMagicNum:0 gBootLogPtr:46a00008.
save config for small mem_size
workmode = 0
storage type = 5
[ 0.825]SPINAND: x5 spinand is initing...OK
spinand id is 0xaaef
spi_nand_scan_id_table chip->pages_per_blk 64
spi_nand_scan_id_table chip->page_size 2048
spi_nand_scan_id_table chip->page_spare_size 64
spi_nand_scan_id_table chip->blks_per_chip 1024
ret 0 status b0 18
ret 0 status b0 18
ret 0 status c0 0
ret 0 status a0 0
find Bbt0
find 1tbB
good block is 1024
[ 0.860]sunxi flash init ok
read mbr from n + 0
can't find corresponding entry
partition file version 2
success to parse partinfo from patition file.
----------------- partinfo ------------------
fs_tpye :0 NO 1 CRAMFS 2 SQUASHFS 3 UBI 4 JFFS2 5 EXT4 6 VFAT
fs_flags:1 Read 2 Write
-name- -offset- -size- -fs_flags- -fs_type- -backup_off-
boot0 : 0 40000 0 0 ffffffff
boot : 40000 240000 0 0 ffffffff
mbr : 280000 20000 0 0 ffffffff
env : 2a0000 20000 0 0 42a0000
updateflag : 2c0000 100000 0 0 ffffffff
partition : 3c0000 100000 1 1 43c0000
kernel : 4c0000 500000 0 0 44c0000
romfs : 9c0000 500000 1 1 49c0000
logo : ec0000 20000 1 0 4ec0000
web : ee0000 500000 1 1 4ee0000
data : 13e0000 500000 1 1 53e0000
usr : 18e0000 f00000 1 1 58e0000
pd : 27e0000 20000 1 1 67e0000
rootfstype cramfs root /dev/mtdblock7
sunxi_partition_get_offset_byname env,0x100
env import count 0
boot0 commit : 8
axp209 read error
axp152 read error
DRAM CLK = 672 MHz
DRAM size = 128 MB
SPN_PAGE_SIZE 2048
current block is 2.
current block is 3.
current block is 4.
current block is 5.
current block is 6.
current block is 7.
sum=832c0e3e
src_sum=832c0e3e
[ 0.498]uboot commit : 8
not set main pmu id
axp read error
probe axp20x failed
axp152 read error
probe axp15 failed
axp_probe error
dcdc2_vol = 1100
dcdc3_vol = 3300
aldo2_vol = 2500
aldo3_vol = 3000
ldo1_vol = 3300
ldo2_vol = 3000
ldo3_vol = 3000
ldo4_vol = 1800
vbus exist
workmode = 0
storage type = 5
[ 0.826]SPINAND: x5 spinand is initing...OK
ret 0 status b0 18
ret 0 status b0 18
ret 0 status c0 0
ret 0 status a0 0
find Bbt0
find 1tbB
good block is 1024
read mbr from n + 0
env import count 0
kiki_III
