Hello
I have problem with speedport W500v it crashes after about 40 hours. When starting or reseting everything seems to be fine but after mentioned time it stops responding I can't connect trough the WIFI, voip phone is dead, even the reset button is not working. It helps only to cut the power and wait some time to turn on again. I have 0.3.6 firmware and getting internet through the Lan connection and then broadcasting via WIFI. Any suggestion for solution??
