<HTML>
<HEAD>
<TITLE>Startseite</TITLE>
<SCRIPT language="JavaScript" src="/html/js_fade.txt" type="text/JavaScript"></SCRIPT>
<SCRIPT type="text/javascript" src="/html/ajax.js"></SCRIPT>
<SCRIPT language="JavaScript">
var bi_akt = 2;
function chk(){
bildkl(2);
top.frames[0].m_akt=1;
top.frames[1].location.href = "/html/m_startseite.htm";
status(5,0,"#550275415671#[email protected]",'1');
oldversion = false;
if (top.frames[0].provname.length>2) oldversion = true;
if (!(top.frames[0].check_dirty)) oldversion = true;
if (!(top.frames[0].showlogin)) oldversion = true;
if (!(top.frames[0].voipprovemptypass)) oldversion = true;
if (!(top.frames[0].voipprovemptypassuser)) oldversion = true;
else
if (top.frames[0].voipprovemptypass[top.frames[0].voipprovemptypass.length-1] !=
top.frames[0].voipprovemptypass[0]) oldversion = true
if (oldversion)
alert("Sie haben erfolgreich eine neue Firmware-Version aufgespielt.\x0d\x0a\x0d\x0a"+
"Bitte leeren Sie jetzt den Cache Ihres Browsers (Temporäre Internetdateien) und\x0d\x0a"+
"starten Sie das Konfigurationsprogramm erneut.");
setTimeout('stReload()',10000);
function stReload(){
ajaxInit();
if (http)
var req = "/cgi-bin/webcm?getpage=../html/query.txt&var:cnt=5";
req += "&var:n0=connection0:pppoe:status/connect";
req += "&var:n1=sar:status/dsl_carrier_state";
req += "&var:n2=box:status/hint_dsl_no_cable";
req += "&var:n3=connection0:pppoe:settings/username";
req += "&var:n4=connection0:settings/enabled";
ajaxGet(req,ajaxCallback);
else
var ishow = nr_akt;
if (ihg > 0) ishow = 0; // Hintergrundtimer schon gestartet?
top.frames[2].location.href = "/cgi-bin/webcm?getpage=../html/hcti_startseite.htm&var:ishow="+ishow+"&var:bi="+bi_akt;
function ajaxCallback(){
try {
if (http.readyState==4 && http.status==200)
var resp = http.responseText;
if (resp)
var part = resp.split(String.fromCharCode(10));
if (part.length>2)
status(part[0],part[2],part[3],part[4]);
} catch(e) {
status(0,0,"foo",1);
function stInet(um){
if (um=="1") document.inetform.PostCon.disabled = false;
if (um=="0")
document.inetform.PostDis.disabled = false;
document.inetform.PostState.value = 0;
document.inetform.PostBi.value = bi_akt;
document.inetform.submit();
function stUnlock(um){
if (um=='1' || sperrwarn())
document.lockform.PostOn.value = um;
document.lockform.submit();
function status(state,nocable,username,unlocked)
var image = 'aktiv';
var li = null;
var re = null;
var info = '46';
if (unlocked==0)
image = 'gesperrt';
re = 'unlock';
info = '44';
else
re = 'lock';
li = 'disconnect';
if (state!=5)
li = 'connect';
if (nocable==1)
image = 'kein_dsl';
re = null;
li = null;
info = '43';
else
if (username=="")
image = 'keine_zdat'
re = null;
li = null;
info = '41';
else
image = 'getrennt';
info = '45';
document.getElementById("c_status").innerHTML='<img border="0" src="/html/pic_c_inet_'+image+'.gif" onmouseover=i_showElem('+info+') onmouseout=i_showElem(0)>';
if (li==null)
document.getElementById('disconnect').style.visibility = 'hidden';
document.getElementById('connect').style.visibility = 'hidden';
else
if (li=='disconnect')
document.getElementById('disconnect').style.visibility = 'visible';
else
document.getElementById('connect').style.visibility = 'visible';
if (re==null)
document.getElementById('lock').style.visibility = 'hidden';
document.getElementById('unlock').style.visibility = 'hidden';
else
if (re=='lock')
document.getElementById('lock').style.visibility = 'visible';
else
document.getElementById('unlock').style.visibility = 'visible';
function sperrwarn(){
return confirm("Wenn Sie das Internet sperren, werden alle Verbindungen ins Inter-\x0d\x0a" +
"net sofort getrennt. Das betrifft auch Telefongespräche, die über\x0d\x0a" +
"das Internet geführt werden.\x0d\x0a"+
"Ein erneuter Verbindungsaufbau wird solange verhindert, bis diese\x0d\x0a" +
"Sperre mit 'Internet freischalten' wieder aufgehoben wird.\x0d\x0a" +
"\x0d\x0a" +
"Um den Internetzugang weiterhin zu ermöglichen, klicken Sie auf\x0d\x0a" +
"'Abbrechen'.\x0d\x0a" +
"\x0d\x0a" +
"Um das Internet jetzt zu sperren und alle Verbindungen zu trennen\x0d\x0a" +
"klicken Sie auf 'OK'.");
function rahmen(high, typ){
if (high==0){
document.getElementById("t_but" + typ).style.color='#000000';
document.getElementById("t_but" + typ).style.borderColor='#666666';
else{
document.getElementById("t_but" + typ).style.color='#E20074';
document.getElementById("t_but" + typ).style.borderColor='#E20074';
function butrahmen(high, typ){
if (high==0){
document.getElementById(typ).style.color='#000000';
document.getElementById(typ).style.borderColor='#666666';
else{
document.getElementById(typ).style.color='#E20074';
document.getElementById(typ).style.borderColor='#E20074';
function bildklrahmen(high,nr){
if (high==0){
i_showElem(0);
else
i_showElem(nr);
if (nr != bi_akt){
if (high==0){
document.getElementById("c_bild_kl" + nr).style.borderColor='#666666';
else{
document.getElementById("c_bild_kl" + nr).style.borderColor='#E20074';
function bildkl(nr){
if (nr!=bi_akt)
document.getElementById("c_bild_kl" + bi_akt).style.borderColor='#666666';
bi_akt = nr;
document.getElementById("c_bild_kl" + bi_akt).style.borderColor='#E20074';
switch (nr){
case 1:
document.getElementById("c_as0").style.visibility = "hidden";
document.getElementById("c_as1").style.visibility = "hidden";
document.getElementById("c_bild_gr").innerHTML='<img border="0" src="/html/pic_c_startbild_o.jpg" usemap="#M1">';
break;
case 2:
document.getElementById("c_as0").style.visibility = "visible";
document.getElementById("c_as1").style.visibility = "visible";
document.getElementById("c_bild_gr").innerHTML='<img border="0" src="/html/pic_c_startbild_u.jpg" usemap="#M2">';
break;
function bildrahmen(high,nr){
if (high==0){
document.getElementById("c_as" + nr).style.borderColor='#666666';
i_showElem(0);
else{
document.getElementById("c_as" + nr).style.borderColor='#E20074';
i_showElem(4);
function as(nr){
top.frames[0].as_akt = nr;
nr+=1;
top.frames[2].location.href = "/cgi-bin/webcm?getpage=../html/hcti_telefon_as.htm&var:as="+nr;
top.frames[0].m_akt=34;
for(i=0;i<top.frames[1].mpkt.length;i++){
top.frames[1].document.getElementById("m_but" + top.frames[1].mpkt[i]).style.color='#000000';
top.frames[1].document.getElementById("m_but" + top.frames[1].mpkt[i]).style.backgroundImage='none';
top.frames[1].document.getElementById("m_but34").style.color='#FFFFFF';
top.frames[1].document.getElementById("m_but34").style.backgroundImage='url(/html/pic_m_marker.gif)';
</SCRIPT>
<LINK rel="stylesheet" href="/html/style.css" type="text/css">
<STYLE type="text/css">
#c_bild_kl1 {
POSITION: absolute; LEFT: 15px; border-color: #666666; border-width: 1px; border-style: solid;
#c_bild_kl2 {
POSITION: absolute; LEFT: 240px; border-color: #E20074; border-width: 1px; border-style: solid;
#c_bild_gr {
POSITION: absolute; LEFT: 15px; TOP: 140px;
#c_as0 {
POSITION: absolute; LEFT: 98px; TOP: 267px; border: 1px solid #666666;
#c_as1 {
POSITION: absolute; LEFT: 118px; TOP: 267px; border: 1px solid #666666;
#c_status {
POSITION: absolute; LEFT: 17px; TOP: 422px;
#i_content11 {Z-INDEX: 2; POSITION: absolute; LEFT: 10px; WIDTH: 180px; TOP: 10px; VISIBILITY: hidden}
#i_content12 {Z-INDEX: 2; POSITION: absolute; LEFT: 10px; WIDTH: 180px; TOP: 10px; VISIBILITY: hidden}
#i_content13 {Z-INDEX: 2; POSITION: absolute; LEFT: 10px; WIDTH: 180px; TOP: 10px; VISIBILITY: hidden}
#i_content14 {Z-INDEX: 2; POSITION: absolute; LEFT: 10px; WIDTH: 180px; TOP: 10px; VISIBILITY: hidden}
#i_content15 {Z-INDEX: 2; POSITION: absolute; LEFT: 10px; WIDTH: 180px; TOP: 10px; VISIBILITY: hidden}
#i_content16 {Z-INDEX: 2; POSITION: absolute; LEFT: 10px; WIDTH: 180px; TOP: 10px; VISIBILITY: hidden}
#i_content17 {Z-INDEX: 2; POSITION: absolute; LEFT: 10px; WIDTH: 180px; TOP: 10px; VISIBILITY: hidden}
#i_content18 {Z-INDEX: 2; POSITION: absolute; LEFT: 10px; WIDTH: 180px; TOP: 10px; VISIBILITY: hidden}
#i_content19 {Z-INDEX: 2; POSITION: absolute; LEFT: 10px; WIDTH: 180px; TOP: 10px; VISIBILITY: hidden}
#i_content20 {Z-INDEX: 2; POSITION: absolute; LEFT: 10px; WIDTH: 180px; TOP: 10px; VISIBILITY: hidden}
#i_content21 {Z-INDEX: 2; POSITION: absolute; LEFT: 10px; WIDTH: 180px; TOP: 10px; VISIBILITY: hidden}
#i_content22 {Z-INDEX: 2; POSITION: absolute; LEFT: 10px; WIDTH: 180px; TOP: 10px; VISIBILITY: hidden}
#i_content31 {Z-INDEX: 2; POSITION: absolute; LEFT: 10px; WIDTH: 180px; TOP: 10px; VISIBILITY: hidden}
#i_content32 {Z-INDEX: 2; POSITION: absolute; LEFT: 10px; WIDTH: 180px; TOP: 10px; VISIBILITY: hidden}
#i_content33 {Z-INDEX: 2; POSITION: absolute; LEFT: 10px; WIDTH: 180px; TOP: 10px; VISIBILITY: hidden}
#i_content34 {Z-INDEX: 2; POSITION: absolute; LEFT: 10px; WIDTH: 180px; TOP: 10px; VISIBILITY: hidden}
#i_content35 {Z-INDEX: 2; POSITION: absolute; LEFT: 10px; WIDTH: 180px; TOP: 10px; VISIBILITY: hidden}
#i_content36 {Z-INDEX: 2; POSITION: absolute; LEFT: 10px; WIDTH: 180px; TOP: 10px; VISIBILITY: hidden}
#i_content37 {Z-INDEX: 2; POSITION: absolute; LEFT: 10px; WIDTH: 180px; TOP: 10px; VISIBILITY: hidden}
#i_content38 {Z-INDEX: 2; POSITION: absolute; LEFT: 10px; WIDTH: 180px; TOP: 10px; VISIBILITY: hidden}
#i_content39 {Z-INDEX: 2; POSITION: absolute; LEFT: 10px; WIDTH: 180px; TOP: 10px; VISIBILITY: hidden}
#i_content40 {Z-INDEX: 2; POSITION: absolute; LEFT: 10px; WIDTH: 180px; TOP: 10px; VISIBILITY: hidden}
#i_content41 {Z-INDEX: 2; POSITION: absolute; LEFT: 10px; WIDTH: 180px; TOP: 10px; VISIBILITY: hidden}
#i_content42 {Z-INDEX: 2; POSITION: absolute; LEFT: 10px; WIDTH: 180px; TOP: 10px; VISIBILITY: hidden}
#i_content43 {Z-INDEX: 2; POSITION: absolute; LEFT: 10px; WIDTH: 180px; TOP: 10px; VISIBILITY: hidden}
#i_content44 {Z-INDEX: 2; POSITION: absolute; LEFT: 10px; WIDTH: 180px; TOP: 10px; VISIBILITY: hidden}
#i_content45 {Z-INDEX: 2; POSITION: absolute; LEFT: 10px; WIDTH: 180px; TOP: 10px; VISIBILITY: hidden}
#i_content46 {Z-INDEX: 2; POSITION: absolute; LEFT: 10px; WIDTH: 180px; TOP: 10px; VISIBILITY: hidden}
#i_content49 {Z-INDEX: 2; POSITION: absolute; LEFT: 10px; WIDTH: 180px; TOP: 10px; VISIBILITY: hidden}
#i_content50 {Z-INDEX: 2; POSITION: absolute; LEFT: 10px; WIDTH: 180px; TOP: 10px; VISIBILITY: hidden}
#i_content51 {Z-INDEX: 2; POSITION: absolute; LEFT: 10px; WIDTH: 180px; TOP: 10px; VISIBILITY: hidden}
</STYLE>
</HEAD>
<BODY onload=chk()>
<map name="M1">
<area shape="rect" coords="112,245,138,285" title="Power LED" nohref onmouseover=i_showElem(11) onmouseout=i_showElem(0)>
<area shape="rect" coords="139,245,167,285" title="WAN LED" nohref onmouseover=i_showElem(12) onmouseout=i_showElem(0)>
<area shape="rect" coords="168,245,198,285" title="TDSL LED" nohref onmouseover=i_showElem(13) onmouseout=i_showElem(0)>
<area shape="rect" coords="199,245,225,285" title="Online LED" nohref onmouseover=i_showElem(14) onmouseout=i_showElem(0)>
<area shape="rect" coords="226,245,254,285" title="Internet LED" nohref onmouseover=i_showElem(15) onmouseout=i_showElem(0)>
<area shape="rect" coords="255,245,288,285" title="Festnetz LED" nohref onmouseover=i_showElem(16) onmouseout=i_showElem(0)>
<area shape="rect" coords="112,5,138,40" title="Status LED" nohref onmouseover=i_showElem(17) onmouseout=i_showElem(0)>
<area shape="rect" coords="139,5,167,40" title="LAN 1 LED" nohref onmouseover=i_showElem(18) onmouseout=i_showElem(0)>
<area shape="rect" coords="168,5,198,40" title="LAN 2 LED" nohref onmouseover=i_showElem(19) onmouseout=i_showElem(0)>
<area shape="rect" coords="199,5,225,40" title="LAN 3 LED" nohref onmouseover=i_showElem(20) onmouseout=i_showElem(0)>
<area shape="rect" coords="226,5,254,40" title="LAN 4 LED" nohref onmouseover=i_showElem(21) onmouseout=i_showElem(0)>
<area shape="rect" coords="255,5,288,40" title="WLAN LED" nohref onmouseover=i_showElem(22) onmouseout=i_showElem(0)>
</map>
<map name="M2">
<area shape="rect" coords="22,137,48,157" title="DECT" nohref onmouseover=i_showElem(31) onmouseout=i_showElem(0)>
<area shape="rect" coords="332,137,360,157" title="WLAN" nohref onmouseover=i_showElem(32) onmouseout=i_showElem(0)>
<area shape="rect" coords="30,161,48,175" title="Reset" nohref onmouseover=i_showElem(51) onmouseout=i_showElem(0)>
<area shape="rect" coords="70,250,95,262" title="int. / ext." nohref onmouseover=i_showElem(49) onmouseout=i_showElem(0)>
<area shape="rect" coords="102,253,127,273" title="T-Net / T-ISDN" nohref onmouseover=i_showElem(34) onmouseout=i_showElem(0)>
<area shape="rect" coords="139,253,166,273" title="T-DSL" nohref onmouseover=i_showElem(35) onmouseout=i_showElem(0)>
<area shape="rect" coords="175,248,202,270" title="WAN / LAN1" nohref onmouseover=i_showElem(36) onmouseout=i_showElem(0)>
<area shape="rect" coords="203,248,228,270" title="LAN2" nohref onmouseover=i_showElem(37) onmouseout=i_showElem(0)>
<area shape="rect" coords="229,248,255,270" title="LAN3" nohref onmouseover=i_showElem(38) onmouseout=i_showElem(0)>
<area shape="rect" coords="256,248,281,270" title="LAN4" nohref onmouseover=i_showElem(39) onmouseout=i_showElem(0)>
<area shape="rect" coords="282,248,300,270" title="Power" nohref onmouseover=i_showElem(50) onmouseout=i_showElem(0)>
<area shape="rect" coords="301,248,315,270" title="Netzgerät" nohref onmouseover=i_showElem(40) onmouseout=i_showElem(0)>
</map>
<DIV id=c_Frame>
<DIV id=c_bild_kl1 onclick=bildkl(1) onmouseover=bildklrahmen(1,1) onmouseout=bildklrahmen(0,1)><img src="/html/pic_c_startbild_o_kl.jpg"></DIV>
<DIV id=c_bild_kl2 onclick=bildkl(2) onmouseover=bildklrahmen(1,2) onmouseout=bildklrahmen(0,2)><img src="/html/pic_c_startbild_u_kl.jpg"></DIV>
<DIV id=c_bild_gr><img border="0" src="/html/pic_c_startbild_u.jpg" usemap="#M2"></DIV>
<SCRIPT type="text/javascript">
for (i=0;i< 2;i++){
document.write('<DIV id=c_as' + i + ' onclick=as(' + i + ') onmouseover=bildrahmen(1,' + i + ') onmouseout=bildrahmen(0,' + i + ')><img src="/html/pic_c_as' + (i+1) + '.gif"></DIV>');
</SCRIPT>
<DIV id=c_status></DIV>
</DIV>
<DIV id=t_Frame>
<DIV class="t_butli" id="disconnect" onclick=stInet("0") onmouseover=butrahmen(1,"disconnect") onmouseout=butrahmen(0,"disconnect")>Internet trennen</DIV>
<DIV class="t_butli" id="connect" onclick=stInet("1") onmouseover=butrahmen(1,"connect") onmouseout=butrahmen(0,"connect")>Internet verbinden</DIV>
<DIV class="t_butre" id="lock" onclick=stUnlock("0") onmouseover=butrahmen(1,"lock") onmouseout=butrahmen(0,"lock")>Internet sperren</DIV>
<DIV class="t_butre" id="unlock" onclick=stUnlock("1") onmouseover=butrahmen(1,"unlock") onmouseout=butrahmen(0,"unlock")>Internet freischalten</DIV>
</DIV>
<form name="inetform" method="POST" action="/cgi-bin/webcm">
<input type="hidden" name="getpage" value="../html/hcti_startseite.htm" />
<input type="hidden" name="errorpage" value="../html/hcti_startseite.htm" />
<input type="hidden" name="var:bi" id="PostBi" />
<input type="hidden" name="connection0:settings/cmd_connect" value="1" disabled="disabled" id="PostCon" />
<input type="hidden" name="connection0:settings/cmd_disconnect" value="1" disabled="disabled" id="PostDis" />
<input type="hidden" name="var:state" value="5" id="PostState" />
</form>
<form name="lockform" method="POST" action="/cgi-bin/webcm">
<input type="hidden" name="connection0:settings/enabled" id="PostOn" />
</form>
<DIV id=i_Frame>
<DIV id=i_content>
<h2>Konfigurationsprogramm</h2>
<p>Dieses Programm ermöglicht es Ihnen, Einstellungen in Ihrem Router vorzunehmen.</p>
<p><b><font color="#999999">ASSISTENT</font></b><br>
<b>> Schritt für Schritt</b><br>
Für den Einstieg empfehlen wir Ihnen den Assistenten. Er führt Sie Schritt für
Schritt durch die notwendigen Einstellungen.</p>
<p><b><font color="#999999">KONFIGURATION</font></b><br>
Erfahrene Benutzer können in diesem Bereich detaillierte Einstellungen vornehmen.</p>
<p><b><font color="#999999">STATUS</font></b><br>
In der Übersicht sehen Sie die wichtigsten Infos zum Status.</p>
<p><b><font color="#999999">VERWALTUNG</font></b><br>
Hier können Sie u.a. Ihre Konfiguration laden und sichern.</p>
<p>Weitere <b>Informationen</b> erhalten Sie, wenn Sie den <b>Mauszeiger</b> über die Grafik bewegen.</p>
</DIV>
<DIV id=i_content1>
<h2><b>Ansichten</b></h2>
<p><b>Draufsicht Leuchtdioden (LED)</b><br>
Klicken Sie auf das Bild um einen Überblick über die Leuchtdiodenanzeige zu erhalten.</p>
</DIV>
<DIV id=i_content2>
<p><b>Unterseite</b><br>
Klicken Sie auf das Bild um einen Überblick über die Anschlüsse zu erhalten.</p>
</DIV>
<DIV id=i_content4>
<h2><b>Unterseite</b></h2>
<p><b>Interne Anschlüsse</b><br>
Klicken Sie hier um Ihren internen Anschluss für die Telefonie einzustellen.
Die Buchse zum Einstecken des Telefons finden Sie auf der Rückseite dieses Gerätes.</p>
</DIV>
<DIV id=i_content11>
<h2><b>Draufsicht Leuchtdioden (LED)</b></h2>
<p><b>Power LED Aus</b><br>
Router ist ausgeschaltet.</p>
<p><b>Power LED blinkt langsam</b><br>
Der Router führt einen Selbsttest durch.</p>
<p><b>Power LED blinkt schnell</b><br>
Beim Selbsttest wurde ein Fehler festgestellt.</p>
<p><b>Power LED leuchtet grün</b><br>
Router betriebsbereit</p>
</DIV>
<DIV id=i_content12>
<p><b>WAN LED Aus</b><br>
Der Router befindet sich im ADSL Modus</p>
<p><b>WAN LED leuchtet grün</b><br>
Der Router verwendet ein VDSL2-Modem.</p>
</DIV>
<DIV id=i_content13>
<p><b>T DSL LED Aus</b><br>
Der Router befindet sich im VDSL2 Modus.</p>
<p><b>T DSL LED blinkt langsam</b><br>
Training des Modems zum DSLAM.
<p><b>T DSL LED leuchtet grün</b><br>
ADSL Modem hat mit DSLAM synchronisiert.</p>
</DIV>
<DIV id=i_content14>
<p><b>Online LED Aus</b><br>
Keine Verbindung zum Internet Service Provider (ISP).</p>
<p><b>Online LED blinkt langsam</b><br>
Es ist ein Fehler beim Internet Service Provider (ISP) aufgetreten.</p>
<p><b>Online LED blinkt schnell</b><br>
Die Zugangsdaten (Benutzername/Passwort) sind falsch.</p>
<p><b>Online LED leuchtet grün</b><br>
PPPoE-Verbindung zum ISP besteht.</p>
</DIV>
<DIV id=i_content15>
<p><b>Internet LED Aus</b><br>
Keine Registrierung zu einem Provider.</p>
<p><b>Internet LED blinkt langsam</b><br>
Ein Anruf ist im Vorgang.</p>
<p><b>Internet LED blinkt schnell</b><br>
Der Zugang mit dem Benutzernamen und dem Passwort ist fehl geschlagen.</p>
<p><b>Internet LED leuchtet grün</b><br>
Die Registrierung zu einem Provider besteht.</p>
</DIV>
<DIV id=i_content16>
<p><b>Festnetz LED Aus</b><br>
Das Gerät ist nicht mit einem ISDN Anschluss verbunden.</p>
<p><b>Festnetz LED blinkt</b><br>
Es wird ein Gespräch über das Festnetz geführt.</p>
<p><b>Festnetz LED leuchtet grün</b><br>
Das Gerät ist mit einem ISDN Anschluss verbunden.</p>
</DIV>
<DIV id=i_content17>
<p><b>Status LED Aus</b><br>
Es liegt kein Fehler vor.</p>
<p><b>Status LED blinkt langsam</b><br>
Die automatische Konfiguration des Internetzugangs und der DSL Telefonie wird versucht zu starten.</p>
<p><b>Status LED blinkt schnell</b><br>
Die automatische Konfiguration des Internetzugangs und der DSL Telefonie ist nicht verfügbar.</p>
<p><b>Status LED leuchtet grün</b><br>
Die automatische Konfiguration des Internetzugangs und der DSL Telefonie wird vorgenommen.</p>
</DIV>
<DIV id=i_content18>
<p><b>LAN 1 LED Aus</b><br>
Es ist kein aktives Netzwerkgerät angeschlossen.</p>
<p><b>LAN 1 LED flackert grün</b><br>
Es werden Daten an das angeschlossene Netzwerkgerät übertragen.</p>
<p><b>LAN 1 LED leuchtet grün</b><br>
Es ist ein aktives Netzwerkgerät angeschlossen.</p>
</DIV>
<DIV id=i_content19>
<p><b>LAN 2 LED Aus</b><br>
<p><b>LAN 2 LED flackert grün</b><br>
<p><b>LAN 2 LED leuchtet grün</b><br>
</DIV>
<DIV id=i_content20>
<p><b>LAN 3 LED Aus</b><br>
<p><b>LAN 3 LED flackert grün</b><br>
<p><b>LAN 3 LED leuchtet grün</b><br>
</DIV>
<DIV id=i_content21>
<p><b>LAN 4 LED Aus</b><br>
<p><b>LAN 4 LED flackert grün</b><br>
<p><b>LAN 4 LED leuchtet grün</b><br>
</DIV>
<DIV id=i_content22>
<p><b>WLAN LED Aus</b><br>
WLAN ist ausgeschaltet.</p>
<p><b>WLAN LED leuchtet grün</b><br>
WLAN ist aktiv.</p>
</DIV>
<DIV id=i_content31>
<p><b>DECT</b><br>
Diese Taste hat bei diesem Gerät keine Funktion.</p>
</DIV>
<DIV id=i_content32>
<p><b>WLAN Ein/Aus</b><br>
Durch Drücken auf den WLAN Taster können Sie das WLAN ein- und ausschalten.</p>
</DIV>
<DIV id=i_content49>
<p><b>int. / ext.</b><br>
Bei der Schalterstellung <b>int.</b> wird das <b>interne Modem</b> verwendet.</p>
<p>Bei der Schalterstellung <b>ext.</b> kann ein <b>externes VDSL 2 Modem</b> verwendet
werden, das an die WAN/LAN1 Buchse angeschaltet werden muss.</p>
</DIV>
<DIV id=i_content33>
<p><b>S0-int</b><br>
Anschlussbuchse für ISDN Telefone.</p>
</DIV>
<DIV id=i_content34>
<p><b>T-Net/T-ISDN</b><br>
Anschlussbuchse für den T-Net Anschluss bzw. T-ISDN Anschluss ins öffentliche Netz.</p>
</DIV>
<DIV id=i_content35>
<p><b>T-DSL</b><br>
Über diesen Anschluss stellen Sie die Verbindung zum Splitter her. Über den Splitter erfolgt die
Verbindung in das öffentlichen Netz.</p>
</DIV>
<DIV id=i_content36>
<p><b>WAN/LAN1</b><br>
Ethernet-Buchse für den Anschluss eines PCs oder eines VDSL2 Modems.</p>
<p>Wenn Sie ein externes VDSL2 Modem verwenden möchten, muss der Schalter ext./int. auf ext. stehen.</p>
</DIV>
<DIV id=i_content37>
<p><b>LAN2</b><br>
Ethernet-Buchse für den Anschluss eines PCs.</p>
</DIV>
<DIV id=i_content38>
<p><b>LAN3</b><br>
</DIV>
<DIV id=i_content39>
<p><b>LAN4</b><br>
</DIV>
<DIV id=i_content40>
<p><b>Netzgerät</b><br>
Buchse zum Anschluss des Netzgerätes.</p>
</DIV>
<DIV id=i_content50>
<h2>Unterseite</h2>
<p><b>Power</b><br>
Schalter zum ein- und ausschalten des Gerätes.</p>
</DIV>
<DIV id=i_content51>
<h2>Unterseite</h2>
<p><b>Reset</b><br>
Wenn Sie die Reset- Taste für ca. 2 sec gedrückt halten, dann wird das Gerät in den Auslieferungszustand zurück gesetzt.</p>
</DIV>
<DIV id=i_content41>
<h2><b>Status Internetverbindung</b></h2>
<p>Keine Zugangsdaten.</p>
<p>Eine Verbindung ins Internet ist nicht möglich, weil Sie noch keine Zugangsdaten eingegeben haben.</p>
<p>Klicken Sie im Menü links, unter Assistent auf die Schaltfläche <b>Schritt für Schritt</b>.</p>
<p>Durchlaufen Sie den Assistenten, Sie werden innerhalb des Assistenten nach den Zugangsdaten gefragt.</p>
</DIV>
<DIV id=i_content43>
<p>Kein DSL.</p>
<p>Eine Verbindung ins Internet ist nicht möglich, weil keine T-DSL Verbindung besteht.</p>
<p>Prüfen Sie bitte ob Ihr DSL Kabel zwischen Ihrem Endgerät (T-DSL Buchse) und dem Splitter richtig verbunden ist.</p>
</DIV>
<DIV id=i_content44>
<p>Internetverbindung gesperrt.</p>
<p>Zum Freischalten der Internetverbindung klicken Sie bitte auf die Schaltfläche: 'Internet freischalten'.</p>
</DIV>
<DIV id=i_content45>
<p>Internetverbindung getrennt.</p>
<p>Zum Verbinden klicken Sie bitte auf die Schaltfläche: 'Internet verbinden'.</p>
<p>Zum dauerhaften Sperren der Internetverbindung klicken Sie bitte auf die Schaltfläche: 'Internet sperren'.</p>
</DIV>
<DIV id=i_content46>
<p>Internetverbindung aktiv.</p>
<p>Zum Trennen klicken Sie bitte auf die Schaltfläche: 'Internet trennen'.</p>
</DIV>
</DIV>
</BODY>
</HTML>
