W900V - Kein Upload bei speed-to-fritz
golf44
11 Aug 2010
hallo akapuma,
habe die Box (W900V) jetzt mit Speedport2Fritz geflasht - nach Neustart erscheint die AVM-Oberfläche Speed!Box
FRITZ!Box Fon WLAN 7170 Speedport W900V !
Jetzt wollte ich die Box "freetzen" (wegen h-cs) komme aber damit nicht zu Abschluß !
Ich füge mal die letzten Log-Zeilen an.
Was mache ich da falsch ?
Phase 10: Pack and deliver.
Settings:
Script version               : 17.08.10-multi
Firmware for update via GUI  : fw_C_Speedport_900_34.04.57-10974_Fritz_Box_DECT_W900V_29.04.80-16352-freetz-5542M-sp2fr-10.08.17-r-1003M-983_OEM-avm_annexB_de.image
Firmware for update via FTP  : kernel.image
Output directory             : /home/hirsch/Desktop/speed-to-fritz/Firmware.new
for Speedport model          : W900V
Branding set to              : avm
AVM source is                : Fritz_Box_7170
AVM source firmware mod is   : 7170
Ready for packing... Press 'ENTER' to continue...
Creating filesystem image, be patient ...
 Packing var.tar
Squashfs filesystem blocksize: 65536
Test kernel size is OK
kernel image size: 7307520 (max: 7798784, free: 491264)
-- Approximately free time for the answering machine: 127s (2min 7s)
Adding checksum
Generation of new 'kernel.image' completed successfully!
Packing ...
Don't restart the PC in case the router is or ends up in a reboot loop,
repeat the flashing, or repeat the complete script if it did not work in the
first place. There is no need to power of a router that is in a reboot loop even
the script asks you to do this. Nothig is damaged if the router ends up or stays
in a reboot loop, the router is waiting for a firmware on one of the following
FTP IPs 192.168.178.1 or 192.168.2.1. If you have trouble to establish a
connection, add to your PC Network settings a static IP 192.168.178.2 and
mask 255.255.0.0 gateway IP 192.168.178.1.
If a VM machine is in use be sure you did start the VM as Administrator.
Flashing firmware image /home/hirsch/Desktop/speed-to-fritz/Firmware.new/kernel.image...
Network  cards set up for search active netconnections:  eth0 eth1 eth2 eth3 eth4 eth5
This list was set to default, but can be set to advance.
Ethernet card found on: eth0
Imagedirectory=/home/hirsch/Desktop/speed-to-fritz/Firmware.new
oem: avm  Produkt: Fritz_Box_DECT_W900V  HWResvison: 102.1.1.0  Eth: eth0  IP: 192.168.178.1  jffs2size: 32  kernel_args: annex=B
All settings will be removed, because clear mtd3 and mtd4 was selected!
Press 'ENTER' to proceed!
You should now reboot your box. Waiting for box to shut down for restart ...
Initiating file transfer of 'kernel.image' ...
Please be patient, it takes about one minute to erase the mtd1 partition ...
Reset environment...
ftp: connect: Network is unreachable
Not connected.
Not connected.
Debugging on (debug=1).
Hash mark printing on (1024 bytes/hash mark).
Not connected.
Not connected.
Not connected.
Not connected.
Not connected.
Waiting for box to shut down again for restart ...
If the Box is not rebooting you have to switch off / on the powerline of the box now.
Not connected.
Not connected.
Not connected.
Not connected.
Not connected.
Not connected.
Not connected.
Not connected.
Not connected.
Not connected.
Not connected.
Not connected.
Finished transfering kernel.image to Speedport. Enjoy!
All done .... Press 'ENTER' to return to the calling shell.
[Beitrag verschoben und Bildschirmausgabe in code-tags gesetzt - Ernest015]
Augenscheinlich handelt es sich nicht um die fertige VM, sondern um eine selbst erzeugte Ubuntu-Installation. Mit Freetz hat das Problem nichts zu tun, das fällt in den Bereich speed-to-fritz.
Es gäbe nun mehrere mögliche Fehlerursachen:
1.) Der Rechner arbeitet mit festen IP-Adressen, die nicht im Bereich 192.168.178.xxx liegen
2.) Falls die "Partitionen" mtd3 und mtd4 mal per FTP durch Überschreiben mit einer leeren Datei (empty) gelöscht worden sind, wird in den meisten Fällen die FTP-Zugangsadresse für das Hochladen per Script auf 192.168.2.1 gesetzt (bootloader-äbhängig). Für diesen Fall kann unten im Script-Menü die FTP-Adresse geändert werden.
3.) Im Rechner sind weitere Netzwerkkarten (auch WLAN-, IDSN- oder TV-Karten zählen als solche) aktiv. Auch Switches oder Hubs können unter Umständen die Kommunikation verhindern
4.) Falls eine VM oder VirtualBox verwendet wird: unter Win7 oder Vista muss sie mit Administratorrechten (Rechtsklick auf das Icon - Als Administrator ausführen) gestartet werden
5.)Der FTP-Port wird möglicherweise durch zusätzliche Firewalls blockiert.
Falls der automatische Upload partout nicht klappen will: das Script hat bereits im Ordner Firmware.new eine Datei mit langem Filenamen (fw_C_speedport...image) erzeugt. Diese Datei kann als Firmware-Update über die Weboberfläche hochgeladen werden.
mfg
danke für die schnelle rückantwort !
zu 1. nein - alle adressen sind im gleichen bereich - muß eine feste ip vergeben werden (habe dhcp)
zu 2. nein - über ftp ist bisher nicht auf die box zugegriffen worden - box mit 192.168.178.1 ansprechbar
zu 3. habe eine 2.lan-karte deinstalliert sowie alle switches/hubs/usb abgezogen
zu 4. verwendet wird ubunto 10.4
zu 5. (noch) keine firewall installiert
neuer durchlauf bringt gleiches ergebniss wie beschrieben.
habe jetzt über die weboberfläche die datei fw_C_speedport...image hochgeladen - kommt der hinweis, daß die datei zu groß ist !!
was nun ?
noch ne frage: kann ich von 29.04.76 auf 29.04.80 updaten ?
( zur info - bin kurz vor den siebzigern, lebte bisher mit windoof und probier's jetzt seit einigen wochen mal mit lunix zweck's box als server für h-cs - und dazu brauch ich freetz)
Bleibt noch eine weiter Variante:
Mit dem Skript kann auch ein recover erstellt werden die die Firmware eingepackt hat.
sorry - das verstehe ich inhaltlich leider nicht -
und was erreiche ich damit ? freetz oder zurück zu w900v ?
Borgphone
