what to do now i need external extensions
zlotowinfo
5 Nov 2006
What does "external extensions" mean ? If you mean "externalizing packets" that is with your 5050 not possible because you don't have an USB-Host. This fritzbox also has only 4MB of Flash and 16MB of RAM and 150MHz of CPU Power, so there is not much you could do with it. For gsm gate you need to attach an gsm modem via usb i guess, but this box doesn't have USB-Host so... no.
The latter is true. The latest firmware 12.04.31 for Fritzbox 5050 doesn't even have a SIP registrar included.
hello we speak about freetz not avm firmwares
nobody understand then i gived example what need to do
freetz is not avm, its modifications from users
nobody understand then i gived article as example what need to do
i try again :/
1. new fritzes have posibility to plug by wlan ip phones
but possible on lan & even by external ip
2. i heard the same possible with freetz
in short: need to use fritbox landline as trunk on pbx with freetz help
3. as my landline is pluged gsm gateway rl400
2. What you heard is not true. Freetz will not add the functionality you want. As I wrote earlier, either the AVM firmware supports it, or it doesn't. Freetz will not change anything in this regard.
1. You will need a newer box that supports VoIP server, but you won't need Freetz.
2. In the past you were able to use dtmfbox for this purpose. But, unfortunately, the program is no longer available.
fusionK
