Where is chan_capi.so ?
teleweb
29 Jan 2006
I successfully used cfg_asterisk usb_install to install Asterisk on my FritzBox 7140, but where is chan_capi.so?
Can't find it here http://www.spblinux.de/fbox/lzma/new/modules/ neither...
Thank you for your help!
P.S. It's no problem if you answer in German, I can read it.
Asterisk successfully installed?
Hi teleweb,
I am also strongly interested in expanding my 7170 with Asterisk capabilities. Especially the voicemail function aligned to my ISDN MSNs is what I am really looking for.
Could you give me some little advice how you managed to setup your environment successfully, meaning Asterisk installation on the USB stick, setting up the different configuration files (which are? extension, etc.).
Have you also setup up your system in that way that you can access your voicemails by a web-based interface?
Many thanks in advance for your help!
Michael
cmdms
