Wie builde ich mit GraphicsMagick ??
twipster
15 Nov 2012
versuche gerade Freetz mit GraphicsMagick zu erstellen.
Ich brauche das hierfür:
http://freetz.org/ticket/1885
Habe es von hier:
http://freetz.org/ticket/1918
Soweit läuft alles nur als ich jetzt GraphicsMagick einbinden will gibts folgenden Fehler:
$ make
cmd() { PATH="/home/cipher/Fritz/freetz/trunk/toolchain/build/mips_gcc-4.8.3_uClibc-0.9.33.2-nptl/mips-linux-uclibc/bin:/home/cipher/Fritz/freetz/trunk/toolchain/build/mips_gcc-4.8.3/mips-unknown-linux-gnu/bin:/usr/lib64/qt-3.3/bin:/usr/local/bin:/usr/bin:/bin:/usr/local/sbin:/usr/sbin:/home/cipher/Tools/adt-bundle-linux-x86_64/sdk/platform-tools/:/home/cipher/.local/bin:/home/cipher/bin:/home/cipher/cipher/Tools/adt-bundle-linux-x86_64/sdk/platform-tools:/home/cipher/Tools/adt-bundle-linux-x86_64/sdk/platform-tools/" LD_RUN_PATH="/usr/lib/freetz" make -j2  "$@"  || { printf "\n\\033[33m%s\\033[m\n" "ERROR: Build failed.";  exit 1; } }; 	if [ -e source/.echo_item_start -a ! -e source/.echo_item_build ]; then echo -n "building... "; touch source/.echo_item_build; fi; cmd -C source/target-mips_gcc-4.8.3_uClibc-0.9.33.2-nptl/GraphicsMagick-1.3.16
make[1]: Entering directory `/home/cipher/Fritz/freetz/trunk/source/target-mips_gcc-4.8.3_uClibc-0.9.33.2-nptl/GraphicsMagick-1.3.16'
Makefile:11220: warning: overriding recipe for target `PerlMagick/Magick.pm'
Makefile:5529: warning: ignoring old recipe for target `PerlMagick/Magick.pm'
make  all-am
make[2]: Entering directory `/home/cipher/Fritz/freetz/trunk/source/target-mips_gcc-4.8.3_uClibc-0.9.33.2-nptl/GraphicsMagick-1.3.16'
/bin/sh ./libtool  --tag=CC   --mode=link /home/cipher/Fritz/freetz/trunk/toolchain/build/mips_gcc-4.8.3_uClibc-0.9.33.2-nptl/mips-linux-uclibc/bin/mips-linux-uclibc-gcc -std=gnu99  -march=24kc -Os -pipe -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -Wall -pthread -L/usr/lib -R/usr/lib -L/usr/lib -R/usr/lib -o utilities/gm utilities/gm.o magick/libGraphicsMagick.la
libtool: link: /home/cipher/Fritz/freetz/trunk/toolchain/build/mips_gcc-4.8.3_uClibc-0.9.33.2-nptl/mips-linux-uclibc/bin/mips-linux-uclibc-gcc -std=gnu99 -march=24kc -Os -pipe -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -Wall -pthread -o utilities/gm utilities/gm.o  -L/usr/lib magick/.libs/libGraphicsMagick.a -lX11 -lz -lm -lpthread -pthread -Wl,-rpath -Wl,/usr/lib
/home/cipher/Fritz/freetz/trunk/toolchain/build/mips_gcc-4.8.3_uClibc-0.9.33.2-nptl/mips-linux-uclibc/bin/../lib/gcc/mips-linux-uclibc/4.8.3/../../../../mips-linux-uclibc/bin/ld: skipping incompatible /usr/lib/libX11.so when searching for -lX11
/home/cipher/Fritz/freetz/trunk/toolchain/build/mips_gcc-4.8.3_uClibc-0.9.33.2-nptl/mips-linux-uclibc/bin/../lib/gcc/mips-linux-uclibc/4.8.3/../../../../mips-linux-uclibc/bin/ld: cannot find -lX11
/home/cipher/Fritz/freetz/trunk/toolchain/build/mips_gcc-4.8.3_uClibc-0.9.33.2-nptl/mips-linux-uclibc/bin/../lib/gcc/mips-linux-uclibc/4.8.3/../../../../mips-linux-uclibc/bin/ld: skipping incompatible /usr/lib/libz.so when searching for -lz
/home/cipher/Fritz/freetz/trunk/toolchain/build/mips_gcc-4.8.3_uClibc-0.9.33.2-nptl/mips-linux-uclibc/bin/../lib/gcc/mips-linux-uclibc/4.8.3/../../../../mips-linux-uclibc/bin/ld: skipping incompatible /usr/lib/libm.so when searching for -lm
/home/cipher/Fritz/freetz/trunk/toolchain/build/mips_gcc-4.8.3_uClibc-0.9.33.2-nptl/mips-linux-uclibc/bin/../lib/gcc/mips-linux-uclibc/4.8.3/../../../../mips-linux-uclibc/bin/ld: skipping incompatible /usr/lib/libpthread.so when searching for -lpthread
/home/cipher/Fritz/freetz/trunk/toolchain/build/mips_gcc-4.8.3_uClibc-0.9.33.2-nptl/mips-linux-uclibc/bin/../lib/gcc/mips-linux-uclibc/4.8.3/../../../../mips-linux-uclibc/bin/ld: skipping incompatible /usr/lib/libpthread.so.0 when searching for libpthread.so.0
/home/cipher/Fritz/freetz/trunk/toolchain/build/mips_gcc-4.8.3_uClibc-0.9.33.2-nptl/mips-linux-uclibc/bin/../lib/gcc/mips-linux-uclibc/4.8.3/../../../../mips-linux-uclibc/bin/ld: skipping incompatible /usr/lib/libpthread_nonshared.a when searching for libpthread_nonshared.a
collect2: error: ld returned 1 exit status
make[2]: *** [utilities/gm] Fehler 1
make[2]: Leaving directory `/home/cipher/Fritz/freetz/trunk/source/target-mips_gcc-4.8.3_uClibc-0.9.33.2-nptl/GraphicsMagick-1.3.16'
make[1]: *** [all] Fehler 2
make[1]: Leaving directory `/home/cipher/Fritz/freetz/trunk/source/target-mips_gcc-4.8.3_uClibc-0.9.33.2-nptl/GraphicsMagick-1.3.16'
make: *** [source/target-mips_gcc-4.8.3_uClibc-0.9.33.2-nptl/GraphicsMagick-1.3.16/utilities/gm] Fehler 1
Buildumgebung ist Fedora 20, GraphicsMagick ist installiert, falls es irgendwie relevant ist.
Kann jemand helfen?
twipster
Der verwendet die Host-Bibliotheken. Da muss ein Patch für das Makefile und evtl. das configure-Script her. Beipspiele dafür gibts bestimmt auch schon im SVN.
...-L/usr/lib magick/.libs/libGraphicsMagick.a...
Oliver
Insbesondere ist mir nicht bekannt, dass es eine libX11 in Freetz gibt, und weiß auch nicht, ob es sinnvoll wäre, das zu versuchen.
Ich weiß nicht so recht wie oder was ich tun muss ehrlich gesagt :confused:
Protonator
