- Mitglied seit
- 6 Sep 2008
- Beiträge
- 34
- Punkte für Reaktionen
- 0
- Punkte
- 0
leider habe ich mal wieder das Problem das ein Paket nicht erstellt werden aknn (irgendwie wirds langsam zur Gewohnheit). Diesmal handelt es sich um xmail im aktuellsten trunk rev5618.
Leider kann ich mir hier kein genauen Reim draus machen. Währe schön falls ihr eine Idee habt.
Vielen Dank
Notausstieg
freetz@freetz:~/freetz-trunk$ make xmail-precompiled
mkdir -p packages/target-mipsel_uClibc-0.9.29/xmail-1.27/root
if test -d make/xmail/files; then tar -c -C make/xmail/files --exclude=.svn . | tar -x -C packages/target-mipsel_uClibc-0.9.29/xmail-1.27 ; fi
---> package/xmail: preparing... tar -C source/target-mipsel_uClibc-0.9.29 -xzf dl/xmail-1.27.tar.gz
set -e; shopt -s nullglob; for i in make/xmail/patches/*.patch; do tools/freetz_patch source/target-mipsel_uClibc-0.9.29/xmail-1.27 $i; done
applying patch file make/xmail/patches/100-compartment.patch
patching file docs/compartment.c
applying patch file make/xmail/patches/200-ipv6_MailSvr.patch
patching file MailSvr.cpp
applying patch file make/xmail/patches/201-ipv6_SysDepCommon.patch
patching file SysDepCommon.cpp
applying patch file make/xmail/patches/300-SysMachine.patch
patching file SysMachine.h
applying patch file make/xmail/patches/301-Makefile_common.patch
patching file Makefile.common
applying patch file make/xmail/patches/302-Makefile_lnx.patch
patching file Makefile.lnx
applying patch file make/xmail/patches/400-CTRLClient.patch
patching file CTRLClient.cpp
applying patch file make/xmail/patches/400-CTRLSvr.patch
patching file CTRLSvr.cpp
applying patch file make/xmail/patches/400-FINGSvr.patch
patching file FINGSvr.cpp
applying patch file make/xmail/patches/400-MailSvr.patch
applying patch file make/xmail/patches/400-MiscUtils.patch
patching file MiscUtils.cpp
applying patch file make/xmail/patches/400-POP3Svr.patch
patching file POP3Svr.cpp
applying patch file make/xmail/patches/400-POP3Utils.patch
patching file POP3Utils.cpp
applying patch file make/xmail/patches/400-SMTPSvr.patch
patching file SMTPSvr.cpp
applying patch file make/xmail/patches/400-SMTPUtils.patch
patching file SMTPUtils.cpp
applying patch file make/xmail/patches/400-SSLBind.patch
patching file SSLBind.cpp
applying patch file make/xmail/patches/400-SSLConfig.patch
patching file SSLConfig.cpp
applying patch file make/xmail/patches/400-SSLMisc.patch
patching file SSLMisc.cpp
applying patch file make/xmail/patches/500-LMAILSrv.patch
patching file LMAILSvr.cpp
applying patch file make/xmail/patches/500-MailRoot.patch
patching file MailRoot/aliases.tab
patching file MailRoot/domains.tab
patching file MailRoot/mailusers.tab
cmd() { PATH="/home/freetz/freetz-trunk/toolchain/target/bin:/home/freetz/freetz-trunk/toolchain/kernel/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games" LD_RUN_PATH="/usr/lib/freetz" make -j1 "$@" || { printf "\n\\033[33m%s\\033[m\n" "ERROR: Build failed."; exit 1; } }; if [ -e source/.echo_item_start -a ! -e source/.echo_item_build ]; then echo -n "building... "; touch source/.echo_item_build; fi; cmd -C source/target-mipsel_uClibc-0.9.29/xmail-1.27 -f Makefile.lnx \
CC="/home/freetz/freetz-trunk/toolchain/target/bin/mipsel-linux-uclibc-g++-uc" \
LD="/home/freetz/freetz-trunk/toolchain/target/bin/mipsel-linux-uclibc-g++-uc" \
CFLAGS="-Os -pipe -march=4kc -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -Isource/target-mipsel_uClibc-0.9.29/xmail-1.27 -D__LINUX__ -DSYS_HAS_SENDFILE -D_REENTRANT=1 -D_THREAD_SAFE=1 -DHAS_SYSMACHINE -D_GNU_SOURCE -D_POSIX_PTHREAD_SEMANTICS" \
LDFLAGS=" -ldl -lpthread" \
STRIP="/home/freetz/freetz-trunk/toolchain/target/bin/mipsel-linux-uclibc-strip --remove-section={.comment,.note,.pdr}"
building... make[1]: Betrete Verzeichnis '/home/freetz/freetz-trunk/source/target-mipsel_uClibc-0.9.29/xmail-1.27'
/home/freetz/freetz-trunk/toolchain/target/bin/mipsel-linux-uclibc-g++-uc -Os -pipe -march=4kc -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -Isource/target-mipsel_uClibc-0.9.29/xmail-1.27 -D__LINUX__ -DSYS_HAS_SENDFILE -D_REENTRANT=1 -D_THREAD_SAFE=1 -DHAS_SYSMACHINE -D_GNU_SOURCE -D_POSIX_PTHREAD_SEMANTICS -o bin/MainLinux.o -c MainLinux.cpp
/home/freetz/freetz-trunk/toolchain/target/bin/mipsel-linux-uclibc-g++-uc -Os -pipe -march=4kc -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -Isource/target-mipsel_uClibc-0.9.29/xmail-1.27 -D__LINUX__ -DSYS_HAS_SENDFILE -D_REENTRANT=1 -D_THREAD_SAFE=1 -DHAS_SYSMACHINE -D_GNU_SOURCE -D_POSIX_PTHREAD_SEMANTICS -o bin/SysDepLinux.o -c SysDepLinux.cpp
/home/freetz/freetz-trunk/toolchain/target/bin/mipsel-linux-uclibc-g++-uc -Os -pipe -march=4kc -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -Isource/target-mipsel_uClibc-0.9.29/xmail-1.27 -D__LINUX__ -DSYS_HAS_SENDFILE -D_REENTRANT=1 -D_THREAD_SAFE=1 -DHAS_SYSMACHINE -D_GNU_SOURCE -D_POSIX_PTHREAD_SEMANTICS -o bin/SysDepUnix.o -c SysDepUnix.cpp
/home/freetz/freetz-trunk/toolchain/target/bin/mipsel-linux-uclibc-g++-uc -Os -pipe -march=4kc -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -Isource/target-mipsel_uClibc-0.9.29/xmail-1.27 -D__LINUX__ -DSYS_HAS_SENDFILE -D_REENTRANT=1 -D_THREAD_SAFE=1 -DHAS_SYSMACHINE -D_GNU_SOURCE -D_POSIX_PTHREAD_SEMANTICS -o bin/SysOsEventfd_pipe.o -c SysOsEventfd_pipe.cpp
/home/freetz/freetz-trunk/toolchain/target/bin/mipsel-linux-uclibc-g++-uc -Os -pipe -march=4kc -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -Isource/target-mipsel_uClibc-0.9.29/xmail-1.27 -D__LINUX__ -DSYS_HAS_SENDFILE -D_REENTRANT=1 -D_THREAD_SAFE=1 -DHAS_SYSMACHINE -D_GNU_SOURCE -D_POSIX_PTHREAD_SEMANTICS -o bin/SysDepCommon.o -c SysDepCommon.cpp
/home/freetz/freetz-trunk/toolchain/target/bin/mipsel-linux-uclibc-g++-uc -Os -pipe -march=4kc -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -Isource/target-mipsel_uClibc-0.9.29/xmail-1.27 -D__LINUX__ -DSYS_HAS_SENDFILE -D_REENTRANT=1 -D_THREAD_SAFE=1 -DHAS_SYSMACHINE -D_GNU_SOURCE -D_POSIX_PTHREAD_SEMANTICS -o bin/BuffSock.o -c BuffSock.cpp
/home/freetz/freetz-trunk/toolchain/target/bin/mipsel-linux-uclibc-g++-uc -Os -pipe -march=4kc -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -Isource/target-mipsel_uClibc-0.9.29/xmail-1.27 -D__LINUX__ -DSYS_HAS_SENDFILE -D_REENTRANT=1 -D_THREAD_SAFE=1 -DHAS_SYSMACHINE -D_GNU_SOURCE -D_POSIX_PTHREAD_SEMANTICS -o bin/CTRLSvr.o -c CTRLSvr.cpp
/home/freetz/freetz-trunk/toolchain/target/bin/mipsel-linux-uclibc-g++-uc -Os -pipe -march=4kc -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -Isource/target-mipsel_uClibc-0.9.29/xmail-1.27 -D__LINUX__ -DSYS_HAS_SENDFILE -D_REENTRANT=1 -D_THREAD_SAFE=1 -DHAS_SYSMACHINE -D_GNU_SOURCE -D_POSIX_PTHREAD_SEMANTICS -o bin/DNS.o -c DNS.cpp
/home/freetz/freetz-trunk/toolchain/target/bin/mipsel-linux-uclibc-g++-uc -Os -pipe -march=4kc -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -Isource/target-mipsel_uClibc-0.9.29/xmail-1.27 -D__LINUX__ -DSYS_HAS_SENDFILE -D_REENTRANT=1 -D_THREAD_SAFE=1 -DHAS_SYSMACHINE -D_GNU_SOURCE -D_POSIX_PTHREAD_SEMANTICS -o bin/DNSCache.o -c DNSCache.cpp
/home/freetz/freetz-trunk/toolchain/target/bin/mipsel-linux-uclibc-g++-uc -Os -pipe -march=4kc -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -Isource/target-mipsel_uClibc-0.9.29/xmail-1.27 -D__LINUX__ -DSYS_HAS_SENDFILE -D_REENTRANT=1 -D_THREAD_SAFE=1 -DHAS_SYSMACHINE -D_GNU_SOURCE -D_POSIX_PTHREAD_SEMANTICS -o bin/Errors.o -c Errors.cpp
/home/freetz/freetz-trunk/toolchain/target/bin/mipsel-linux-uclibc-g++-uc -Os -pipe -march=4kc -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -Isource/target-mipsel_uClibc-0.9.29/xmail-1.27 -D__LINUX__ -DSYS_HAS_SENDFILE -D_REENTRANT=1 -D_THREAD_SAFE=1 -DHAS_SYSMACHINE -D_GNU_SOURCE -D_POSIX_PTHREAD_SEMANTICS -o bin/ExtAliases.o -c ExtAliases.cpp
/home/freetz/freetz-trunk/toolchain/target/bin/mipsel-linux-uclibc-g++-uc -Os -pipe -march=4kc -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -Isource/target-mipsel_uClibc-0.9.29/xmail-1.27 -D__LINUX__ -DSYS_HAS_SENDFILE -D_REENTRANT=1 -D_THREAD_SAFE=1 -DHAS_SYSMACHINE -D_GNU_SOURCE -D_POSIX_PTHREAD_SEMANTICS -o bin/FINGSvr.o -c FINGSvr.cpp
/home/freetz/freetz-trunk/toolchain/target/bin/mipsel-linux-uclibc-g++-uc -Os -pipe -march=4kc -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -Isource/target-mipsel_uClibc-0.9.29/xmail-1.27 -D__LINUX__ -DSYS_HAS_SENDFILE -D_REENTRANT=1 -D_THREAD_SAFE=1 -DHAS_SYSMACHINE -D_GNU_SOURCE -D_POSIX_PTHREAD_SEMANTICS -o bin/MailConfig.o -c MailConfig.cpp
/home/freetz/freetz-trunk/toolchain/target/bin/mipsel-linux-uclibc-g++-uc -Os -pipe -march=4kc -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -Isource/target-mipsel_uClibc-0.9.29/xmail-1.27 -D__LINUX__ -DSYS_HAS_SENDFILE -D_REENTRANT=1 -D_THREAD_SAFE=1 -DHAS_SYSMACHINE -D_GNU_SOURCE -D_POSIX_PTHREAD_SEMANTICS -o bin/MailSvr.o -c MailSvr.cpp
/home/freetz/freetz-trunk/toolchain/target/bin/mipsel-linux-uclibc-g++-uc -Os -pipe -march=4kc -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -Isource/target-mipsel_uClibc-0.9.29/xmail-1.27 -D__LINUX__ -DSYS_HAS_SENDFILE -D_REENTRANT=1 -D_THREAD_SAFE=1 -DHAS_SYSMACHINE -D_GNU_SOURCE -D_POSIX_PTHREAD_SEMANTICS -o bin/Maildir.o -c Maildir.cpp
/home/freetz/freetz-trunk/toolchain/target/bin/mipsel-linux-uclibc-g++-uc -Os -pipe -march=4kc -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -Isource/target-mipsel_uClibc-0.9.29/xmail-1.27 -D__LINUX__ -DSYS_HAS_SENDFILE -D_REENTRANT=1 -D_THREAD_SAFE=1 -DHAS_SYSMACHINE -D_GNU_SOURCE -D_POSIX_PTHREAD_SEMANTICS -o bin/MailDomains.o -c MailDomains.cpp
/home/freetz/freetz-trunk/toolchain/target/bin/mipsel-linux-uclibc-g++-uc -Os -pipe -march=4kc -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -Isource/target-mipsel_uClibc-0.9.29/xmail-1.27 -D__LINUX__ -DSYS_HAS_SENDFILE -D_REENTRANT=1 -D_THREAD_SAFE=1 -DHAS_SYSMACHINE -D_GNU_SOURCE -D_POSIX_PTHREAD_SEMANTICS -o bin/MD5.o -c MD5.cpp
/home/freetz/freetz-trunk/toolchain/target/bin/mipsel-linux-uclibc-g++-uc -Os -pipe -march=4kc -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -Isource/target-mipsel_uClibc-0.9.29/xmail-1.27 -D__LINUX__ -DSYS_HAS_SENDFILE -D_REENTRANT=1 -D_THREAD_SAFE=1 -DHAS_SYSMACHINE -D_GNU_SOURCE -D_POSIX_PTHREAD_SEMANTICS -o bin/MiscUtils.o -c MiscUtils.cpp
/home/freetz/freetz-trunk/toolchain/target/bin/mipsel-linux-uclibc-g++-uc -Os -pipe -march=4kc -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -Isource/target-mipsel_uClibc-0.9.29/xmail-1.27 -D__LINUX__ -DSYS_HAS_SENDFILE -D_REENTRANT=1 -D_THREAD_SAFE=1 -DHAS_SYSMACHINE -D_GNU_SOURCE -D_POSIX_PTHREAD_SEMANTICS -o bin/LMAILSvr.o -c LMAILSvr.cpp
/home/freetz/freetz-trunk/toolchain/target/bin/mipsel-linux-uclibc-g++-uc -Os -pipe -march=4kc -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -Isource/target-mipsel_uClibc-0.9.29/xmail-1.27 -D__LINUX__ -DSYS_HAS_SENDFILE -D_REENTRANT=1 -D_THREAD_SAFE=1 -DHAS_SYSMACHINE -D_GNU_SOURCE -D_POSIX_PTHREAD_SEMANTICS -o bin/AliasDomain.o -c AliasDomain.cpp
/home/freetz/freetz-trunk/toolchain/target/bin/mipsel-linux-uclibc-g++-uc -Os -pipe -march=4kc -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -Isource/target-mipsel_uClibc-0.9.29/xmail-1.27 -D__LINUX__ -DSYS_HAS_SENDFILE -D_REENTRANT=1 -D_THREAD_SAFE=1 -DHAS_SYSMACHINE -D_GNU_SOURCE -D_POSIX_PTHREAD_SEMANTICS -o bin/POP3GwLink.o -c POP3GwLink.cpp
/home/freetz/freetz-trunk/toolchain/target/bin/mipsel-linux-uclibc-g++-uc -Os -pipe -march=4kc -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -Isource/target-mipsel_uClibc-0.9.29/xmail-1.27 -D__LINUX__ -DSYS_HAS_SENDFILE -D_REENTRANT=1 -D_THREAD_SAFE=1 -DHAS_SYSMACHINE -D_GNU_SOURCE -D_POSIX_PTHREAD_SEMANTICS -o bin/POP3Svr.o -c POP3Svr.cpp
/home/freetz/freetz-trunk/toolchain/target/bin/mipsel-linux-uclibc-g++-uc -Os -pipe -march=4kc -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -Isource/target-mipsel_uClibc-0.9.29/xmail-1.27 -D__LINUX__ -DSYS_HAS_SENDFILE -D_REENTRANT=1 -D_THREAD_SAFE=1 -DHAS_SYSMACHINE -D_GNU_SOURCE -D_POSIX_PTHREAD_SEMANTICS -o bin/POP3Utils.o -c POP3Utils.cpp
/home/freetz/freetz-trunk/toolchain/target/bin/mipsel-linux-uclibc-g++-uc -Os -pipe -march=4kc -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -Isource/target-mipsel_uClibc-0.9.29/xmail-1.27 -D__LINUX__ -DSYS_HAS_SENDFILE -D_REENTRANT=1 -D_THREAD_SAFE=1 -DHAS_SYSMACHINE -D_GNU_SOURCE -D_POSIX_PTHREAD_SEMANTICS -o bin/PSYNCSvr.o -c PSYNCSvr.cpp
/home/freetz/freetz-trunk/toolchain/target/bin/mipsel-linux-uclibc-g++-uc -Os -pipe -march=4kc -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -Isource/target-mipsel_uClibc-0.9.29/xmail-1.27 -D__LINUX__ -DSYS_HAS_SENDFILE -D_REENTRANT=1 -D_THREAD_SAFE=1 -DHAS_SYSMACHINE -D_GNU_SOURCE -D_POSIX_PTHREAD_SEMANTICS -o bin/ResLocks.o -c ResLocks.cpp
/home/freetz/freetz-trunk/toolchain/target/bin/mipsel-linux-uclibc-g++-uc -Os -pipe -march=4kc -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -Isource/target-mipsel_uClibc-0.9.29/xmail-1.27 -D__LINUX__ -DSYS_HAS_SENDFILE -D_REENTRANT=1 -D_THREAD_SAFE=1 -DHAS_SYSMACHINE -D_GNU_SOURCE -D_POSIX_PTHREAD_SEMANTICS -o bin/SList.o -c SList.cpp
/home/freetz/freetz-trunk/toolchain/target/bin/mipsel-linux-uclibc-g++-uc -Os -pipe -march=4kc -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -Isource/target-mipsel_uClibc-0.9.29/xmail-1.27 -D__LINUX__ -DSYS_HAS_SENDFILE -D_REENTRANT=1 -D_THREAD_SAFE=1 -DHAS_SYSMACHINE -D_GNU_SOURCE -D_POSIX_PTHREAD_SEMANTICS -o bin/SMAILSvr.o -c SMAILSvr.cpp
/home/freetz/freetz-trunk/toolchain/target/bin/mipsel-linux-uclibc-g++-uc -Os -pipe -march=4kc -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -Isource/target-mipsel_uClibc-0.9.29/xmail-1.27 -D__LINUX__ -DSYS_HAS_SENDFILE -D_REENTRANT=1 -D_THREAD_SAFE=1 -DHAS_SYSMACHINE -D_GNU_SOURCE -D_POSIX_PTHREAD_SEMANTICS -o bin/TabIndex.o -c TabIndex.cpp
/home/freetz/freetz-trunk/toolchain/target/bin/mipsel-linux-uclibc-g++-uc -Os -pipe -march=4kc -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -Isource/target-mipsel_uClibc-0.9.29/xmail-1.27 -D__LINUX__ -DSYS_HAS_SENDFILE -D_REENTRANT=1 -D_THREAD_SAFE=1 -DHAS_SYSMACHINE -D_GNU_SOURCE -D_POSIX_PTHREAD_SEMANTICS -o bin/SMAILUtils.o -c SMAILUtils.cpp
/home/freetz/freetz-trunk/toolchain/target/bin/mipsel-linux-uclibc-g++-uc -Os -pipe -march=4kc -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -Isource/target-mipsel_uClibc-0.9.29/xmail-1.27 -D__LINUX__ -DSYS_HAS_SENDFILE -D_REENTRANT=1 -D_THREAD_SAFE=1 -DHAS_SYSMACHINE -D_GNU_SOURCE -D_POSIX_PTHREAD_SEMANTICS -o bin/SMTPSvr.o -c SMTPSvr.cpp
/home/freetz/freetz-trunk/toolchain/target/bin/mipsel-linux-uclibc-g++-uc -Os -pipe -march=4kc -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -Isource/target-mipsel_uClibc-0.9.29/xmail-1.27 -D__LINUX__ -DSYS_HAS_SENDFILE -D_REENTRANT=1 -D_THREAD_SAFE=1 -DHAS_SYSMACHINE -D_GNU_SOURCE -D_POSIX_PTHREAD_SEMANTICS -o bin/SMTPUtils.o -c SMTPUtils.cpp
/home/freetz/freetz-trunk/toolchain/target/bin/mipsel-linux-uclibc-g++-uc -Os -pipe -march=4kc -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -Isource/target-mipsel_uClibc-0.9.29/xmail-1.27 -D__LINUX__ -DSYS_HAS_SENDFILE -D_REENTRANT=1 -D_THREAD_SAFE=1 -DHAS_SYSMACHINE -D_GNU_SOURCE -D_POSIX_PTHREAD_SEMANTICS -o bin/ShBlocks.o -c ShBlocks.cpp
/home/freetz/freetz-trunk/toolchain/target/bin/mipsel-linux-uclibc-g++-uc -Os -pipe -march=4kc -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -Isource/target-mipsel_uClibc-0.9.29/xmail-1.27 -D__LINUX__ -DSYS_HAS_SENDFILE -D_REENTRANT=1 -D_THREAD_SAFE=1 -DHAS_SYSMACHINE -D_GNU_SOURCE -D_POSIX_PTHREAD_SEMANTICS -o bin/StrUtils.o -c StrUtils.cpp
/home/freetz/freetz-trunk/toolchain/target/bin/mipsel-linux-uclibc-g++-uc -Os -pipe -march=4kc -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -Isource/target-mipsel_uClibc-0.9.29/xmail-1.27 -D__LINUX__ -DSYS_HAS_SENDFILE -D_REENTRANT=1 -D_THREAD_SAFE=1 -DHAS_SYSMACHINE -D_GNU_SOURCE -D_POSIX_PTHREAD_SEMANTICS -o bin/MessQueue.o -c MessQueue.cpp
/home/freetz/freetz-trunk/toolchain/target/bin/mipsel-linux-uclibc-g++-uc -Os -pipe -march=4kc -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -Isource/target-mipsel_uClibc-0.9.29/xmail-1.27 -D__LINUX__ -DSYS_HAS_SENDFILE -D_REENTRANT=1 -D_THREAD_SAFE=1 -DHAS_SYSMACHINE -D_GNU_SOURCE -D_POSIX_PTHREAD_SEMANTICS -o bin/QueueUtils.o -c QueueUtils.cpp
/home/freetz/freetz-trunk/toolchain/target/bin/mipsel-linux-uclibc-g++-uc -Os -pipe -march=4kc -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -Isource/target-mipsel_uClibc-0.9.29/xmail-1.27 -D__LINUX__ -DSYS_HAS_SENDFILE -D_REENTRANT=1 -D_THREAD_SAFE=1 -DHAS_SYSMACHINE -D_GNU_SOURCE -D_POSIX_PTHREAD_SEMANTICS -o bin/SvrUtils.o -c SvrUtils.cpp
/home/freetz/freetz-trunk/toolchain/target/bin/mipsel-linux-uclibc-g++-uc -Os -pipe -march=4kc -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -Isource/target-mipsel_uClibc-0.9.29/xmail-1.27 -D__LINUX__ -DSYS_HAS_SENDFILE -D_REENTRANT=1 -D_THREAD_SAFE=1 -DHAS_SYSMACHINE -D_GNU_SOURCE -D_POSIX_PTHREAD_SEMANTICS -o bin/UsrMailList.o -c UsrMailList.cpp
/home/freetz/freetz-trunk/toolchain/target/bin/mipsel-linux-uclibc-g++-uc -Os -pipe -march=4kc -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -Isource/target-mipsel_uClibc-0.9.29/xmail-1.27 -D__LINUX__ -DSYS_HAS_SENDFILE -D_REENTRANT=1 -D_THREAD_SAFE=1 -DHAS_SYSMACHINE -D_GNU_SOURCE -D_POSIX_PTHREAD_SEMANTICS -o bin/UsrAuth.o -c UsrAuth.cpp
/home/freetz/freetz-trunk/toolchain/target/bin/mipsel-linux-uclibc-g++-uc -Os -pipe -march=4kc -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -Isource/target-mipsel_uClibc-0.9.29/xmail-1.27 -D__LINUX__ -DSYS_HAS_SENDFILE -D_REENTRANT=1 -D_THREAD_SAFE=1 -DHAS_SYSMACHINE -D_GNU_SOURCE -D_POSIX_PTHREAD_SEMANTICS -o bin/UsrUtils.o -c UsrUtils.cpp
/home/freetz/freetz-trunk/toolchain/target/bin/mipsel-linux-uclibc-g++-uc -Os -pipe -march=4kc -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -Isource/target-mipsel_uClibc-0.9.29/xmail-1.27 -D__LINUX__ -DSYS_HAS_SENDFILE -D_REENTRANT=1 -D_THREAD_SAFE=1 -DHAS_SYSMACHINE -D_GNU_SOURCE -D_POSIX_PTHREAD_SEMANTICS -o bin/Base64Enc.o -c Base64Enc.cpp
/home/freetz/freetz-trunk/toolchain/target/bin/mipsel-linux-uclibc-g++-uc -Os -pipe -march=4kc -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -Isource/target-mipsel_uClibc-0.9.29/xmail-1.27 -D__LINUX__ -DSYS_HAS_SENDFILE -D_REENTRANT=1 -D_THREAD_SAFE=1 -DHAS_SYSMACHINE -D_GNU_SOURCE -D_POSIX_PTHREAD_SEMANTICS -o bin/Filter.o -c Filter.cpp
/home/freetz/freetz-trunk/toolchain/target/bin/mipsel-linux-uclibc-g++-uc -Os -pipe -march=4kc -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -Isource/target-mipsel_uClibc-0.9.29/xmail-1.27 -D__LINUX__ -DSYS_HAS_SENDFILE -D_REENTRANT=1 -D_THREAD_SAFE=1 -DHAS_SYSMACHINE -D_GNU_SOURCE -D_POSIX_PTHREAD_SEMANTICS -o bin/SSLBind.o -c SSLBind.cpp
/home/freetz/freetz-trunk/toolchain/target/bin/mipsel-linux-uclibc-g++-uc -Os -pipe -march=4kc -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -Isource/target-mipsel_uClibc-0.9.29/xmail-1.27 -D__LINUX__ -DSYS_HAS_SENDFILE -D_REENTRANT=1 -D_THREAD_SAFE=1 -DHAS_SYSMACHINE -D_GNU_SOURCE -D_POSIX_PTHREAD_SEMANTICS -o bin/SSLConfig.o -c SSLConfig.cpp
/home/freetz/freetz-trunk/toolchain/target/bin/mipsel-linux-uclibc-g++-uc -Os -pipe -march=4kc -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -Isource/target-mipsel_uClibc-0.9.29/xmail-1.27 -D__LINUX__ -DSYS_HAS_SENDFILE -D_REENTRANT=1 -D_THREAD_SAFE=1 -DHAS_SYSMACHINE -D_GNU_SOURCE -D_POSIX_PTHREAD_SEMANTICS -o bin/Hash.o -c Hash.cpp
/home/freetz/freetz-trunk/toolchain/target/bin/mipsel-linux-uclibc-g++-uc -Os -pipe -march=4kc -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -Isource/target-mipsel_uClibc-0.9.29/xmail-1.27 -D__LINUX__ -DSYS_HAS_SENDFILE -D_REENTRANT=1 -D_THREAD_SAFE=1 -DHAS_SYSMACHINE -D_GNU_SOURCE -D_POSIX_PTHREAD_SEMANTICS -o bin/Array.o -c Array.cpp
/home/freetz/freetz-trunk/toolchain/target/bin/mipsel-linux-uclibc-g++-uc -Os -pipe -march=4kc -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -Isource/target-mipsel_uClibc-0.9.29/xmail-1.27 -D__LINUX__ -DSYS_HAS_SENDFILE -D_REENTRANT=1 -D_THREAD_SAFE=1 -DHAS_SYSMACHINE -D_GNU_SOURCE -D_POSIX_PTHREAD_SEMANTICS -o bin/SSLMisc.o -c SSLMisc.cpp
/home/freetz/freetz-trunk/toolchain/target/bin/mipsel-linux-uclibc-g++-uc -o bin/XMail bin/MainLinux.o bin/SysDepLinux.o bin/SysDepUnix.o bin/SysOsEventfd_pipe.o bin/SysDepCommon.o bin/BuffSock.o bin/CTRLSvr.o bin/DNS.o bin/DNSCache.o bin/Errors.o bin/ExtAliases.o bin/FINGSvr.o bin/MailConfig.o bin/MailSvr.o bin/Maildir.o bin/MailDomains.o bin/MD5.o bin/MiscUtils.o bin/LMAILSvr.o bin/AliasDomain.o bin/POP3GwLink.o bin/POP3Svr.o bin/POP3Utils.o bin/PSYNCSvr.o bin/ResLocks.o bin/SList.o bin/SMAILSvr.o bin/TabIndex.o bin/SMAILUtils.o bin/SMTPSvr.o bin/SMTPUtils.o bin/ShBlocks.o bin/StrUtils.o bin/MessQueue.o bin/QueueUtils.o bin/SvrUtils.o bin/UsrMailList.o bin/UsrAuth.o bin/UsrUtils.o bin/Base64Enc.o bin/Filter.o bin/SSLBind.o bin/SSLConfig.o bin/Hash.o bin/Array.o bin/SSLMisc.o -ldl -lpthread
bin/MiscUtils.o: In function `MscSafeGetTmpFile(char*, int)':
MiscUtils.cpp:(.text+0x3ed8): warning: the use of `mktemp' is dangerous, better use `mkstemp'
bin/MainLinux.o:(.eh_frame+0x11): undefined reference to `__gxx_personality_v0'
bin/SysDepLinux.o:(.eh_frame+0x11): undefined reference to `__gxx_personality_v0'
bin/SysDepUnix.o:(.eh_frame+0x11): undefined reference to `__gxx_personality_v0'
bin/SysOsEventfd_pipe.o:(.eh_frame+0x11): undefined reference to `__gxx_personality_v0'
bin/SysDepCommon.o:(.eh_frame+0x11): undefined reference to `__gxx_personality_v0'
bin/BuffSock.o:(.eh_frame+0x11): more undefined references to `__gxx_personality_v0' follow
/home/freetz/freetz-trunk/toolchain/build/gcc-4.2.4-uClibc-0.9.29/mipsel-linux-uclibc/usr/lib//libuClibc++.so: undefined reference to `_Unwind_SjLj_Register@GCC_3.0'
/home/freetz/freetz-trunk/toolchain/build/gcc-4.2.4-uClibc-0.9.29/mipsel-linux-uclibc/usr/lib//libuClibc++.so: undefined reference to `_Unwind_SjLj_Resume_or_Rethrow@GCC_3.3'
/home/freetz/freetz-trunk/toolchain/build/gcc-4.2.4-uClibc-0.9.29/mipsel-linux-uclibc/usr/lib//libuClibc++.so: undefined reference to `_Unwind_SjLj_RaiseException@GCC_3.0'
/home/freetz/freetz-trunk/toolchain/build/gcc-4.2.4-uClibc-0.9.29/mipsel-linux-uclibc/usr/lib//libuClibc++.so: undefined reference to `_Unwind_SjLj_Unregister@GCC_3.0'
/home/freetz/freetz-trunk/toolchain/build/gcc-4.2.4-uClibc-0.9.29/mipsel-linux-uclibc/usr/lib//libuClibc++.so: undefined reference to `_Unwind_SjLj_Resume@GCC_3.0'
collect2: ld returned 1 exit status
make[1]: *** [bin/XMail] Fehler 1
make[1]: Verlasse Verzeichnis '/home/freetz/freetz-trunk/source/target-mipsel_uClibc-0.9.29/xmail-1.27'
make: *** [source/target-mipsel_uClibc-0.9.29/xmail-1.27/bin/compartment] Fehler 1
Vielen Dank
Notausstieg
