Asterisk startet nicht wegen chan_oss
carpe:diem
13 Nov 2005
Ich habe mich nun doch wieder einmal an Asterisk gewagt und scheitere schon beim Start. Ich habe alles nach der Anleitung http://www.das-asterisk-buch.de/2.1/installation-1.6-debian.html installiert. Zu erst mit den Samples, dann ohne. Ohne Samples lauft irgendwie gar nichts, was ja eigentlich normal sein dürfte. Mit Samples, egal ob sofort oder nachträglich installiert, tritt immer folgender Fehler auf:
Asterisk 1.6.0.9, Copyright (C) 1999 - 2008 Digium, Inc. and others.
Created by Mark Spencer <[email protected]>
Asterisk comes with ABSOLUTELY NO WARRANTY; type 'core show warranty' for details.
This is free software, with components licensed under the GNU General Public
License version 2 and other licenses; you are welcome to redistribute it under
certain conditions. Type 'core show license' for details.
[ Booting...
[ Reading Master Configuration ]
[ Initializing Custom Configuration Options ]
[Apr 16 22:38:12] NOTICE[2518]: loader.c:869 load_modules: 1 modules will be loaded.
.[Apr 16 22:38:12] NOTICE[2518]: cdr.c:1430 do_reload: CDR simple logging enabled.
[Apr 16 22:38:12] NOTICE[2518]: loader.c:869 load_modules: 162 modules will be loaded.
.[Apr 16 22:38:13] NOTICE[2518]: res_smdi.c:1272 load_module: No SMDI interfaces are available to listen on, not starting SMDI listener.
..[Apr 16 22:38:13] NOTICE[2518]: config.c:1912 ast_config_engine_register: Registered Config Engine odbc
....[Apr 16 22:38:13] NOTICE[2518]: res_odbc.c:809 load_module: res_odbc loaded.
..[Apr 16 22:38:13] WARNING[2518]: res_config_ldap.c:1401 parse_config: No directory user found, anonymous binding as default.
[Apr 16 22:38:13] ERROR[2518]: res_config_ldap.c:1426 parse_config: No directory URL or host found.
[Apr 16 22:38:13] NOTICE[2518]: res_config_ldap.c:1319 load_module: Cannot load LDAP RealTime driver.
.......................................[Apr 16 22:38:13] WARNING[2518]: translate.c:654 __ast_register_translator: plc_samples 160 format f
....................[Apr 16 22:38:13] NOTICE[2518]: pbx_ael.c:122 pbx_load_module: Starting AEL load process.
[Apr 16 22:38:13] NOTICE[2518]: ael.y:246 ael_yyparse: Note: In asterisk.conf, in the [compat] section, the app_set is set to 1.6 or greater. The Set() function no longer removes double quotes from the value. If this is a surprise to you, you can set app_set to 1.4.
[Apr 16 22:38:13] NOTICE[2518]: pbx_ael.c:135 pbx_load_module: AEL load process: parsed config file name '/etc/asterisk/extensions.ael'.
[Apr 16 22:38:13] NOTICE[2518]: pbx_ael.c:138 pbx_load_module: AEL load process: checked config file name '/etc/asterisk/extensions.ael'.
[Apr 16 22:38:13] NOTICE[2518]: pbx_ael.c:141 pbx_load_module: AEL load process: compiled config file name '/etc/asterisk/extensions.ael'.
[Apr 16 22:38:13] NOTICE[2518]: pbx_ael.c:146 pbx_load_module: AEL load process: merged config file name '/etc/asterisk/extensions.ael'.
[Apr 16 22:38:13] NOTICE[2518]: pbx_ael.c:149 pbx_load_module: AEL load process: verified config file name '/etc/asterisk/extensions.ael'.
.............................SIP channel loading...
...[Apr 16 22:38:13] NOTICE[2518]: config.c:1912 ast_config_engine_register: Registered Config Engine curl
..................[Apr 16 22:38:13] WARNING[2518]: channel.c:560 ast_channel_register: Already have a handler for type 'Console'
[Apr 16 22:38:13] ERROR[2518]: chan_oss.c:1449 load_module: Unable to register channel type 'OSS'
Ich habe das neueste Debian auf einer Virtualbox installiert, Asterisk ist Version 1.6.0.9. Die Pakete welche laut der Anleitung nicht benötigt werden (LibPRI und Dahdi) habe ich weggelassen (LibPRI nur beim zweiten mal).
Kennt jemand diesen Fehler und kann mir weiterhelfen?
Vielen Dank
Manuel
schrieb mal in modules.conf
noload => chan_oss
und/oder kommentiere "load => chan_oss" einfach aus
lg
n8|
