Fritz!Fax send faxed oonly via SIP netz :-(
alexl7
24 Jun 2006
Sehr!
Nach dem Ersatz firmware, (jetzt 14.04.20) fritz!fax schickt die Faxe hartnдckig durch SIP Netzwerk und nicht durch das festNetz, von neuem hat CATI und fritz aufgestellt{eingeführt}! fax schickt die Stiefelwichsen durch SIP das Netz{Netzwerk}, in was das Problem dennoch?
Vielen,
Fritz!Fas send all fax via SIP network forcibly!
Ok. Sorry for my german ;-)
All change firmware just moment 14.04.20 Eng. for 7050 old (14.04.15 Ger.)
also after this problem, I change TAPI german on english version with same too fritz!fax, as a result 7050 send fax's onlu via SIP net don/t send via FXO
DM41 schrieb:
:lach:
Try in english please. This translation is really funny but not comprehensible. :hehe:
Just to confirm what you have done:
- You converted a 7050 from german to international version
- You flashed the new international firmware 14.04.20
- You installed english version of tapi
But which Fritz!Fax did you install? There's no english version as far as I know. Do you have a link?
Ja, Genau!
[Fullquote of DM41 removed. This refers just to the previous article. Why the heck do you quote? --gandalf94305]
I install germany version only:
ftp://ftp.avm.de/fritz.box/tools/fax4box
I don't final any english version :-(
@axel7
it seems to me that AVM has added a new 'SIP-Controller' to the network-CAPI.
My 7050 with a new beta-FW has now 5 Controller instead of 4.
The Fax4Box-programm takes unfortunately the last one if you select "Fritz!Box Amtsanschluß Analog"
Try to select the first "ISDN-Controller" setting and insert "4" into the box.
I change, no work again :-(
stsoft schrieb:
@axel7
log info:
3301/Protokollfehler Ebene 1 (z.B. ISDN-Anschlu?kabel nicht oder falsch gesteckt)
1. The Net-Capi is aktivated (#96*3* via Telefon)?
2. You have an analog line? (For ISDN-Line You have to select Controller 1)
3. Try to add an new registry value "FoundFritzBoxes" at "HKEY_LOCAL_MACHINE\SOFTWARE\AVM\AVMIGDCTRL" and insert there IP-address of your FritzBox
Yes.
Yes.
Yes, I add this.
No any effect :-(
see all this section:
[HKEY_LOCAL_MACHINE\SOFTWARE\AVM]
"InstStartProg"="\"D:\\Program Files\\FRITZ!Box Monitor\\FRITZBoxMonitor.exe\" -1"
[HKEY_LOCAL_MACHINE\SOFTWARE\AVM\AVMIGDCTRL]
"FoundFritzBoxes"="192.168.178.1"
[HKEY_LOCAL_MACHINE\SOFTWARE\AVM\CAPIoTCP]
"Port"=dword:000013a7
[HKEY_LOCAL_MACHINE\SOFTWARE\AVM\FRITZ! 2.0]
@="03.06.03"
[HKEY_LOCAL_MACHINE\SOFTWARE\AVM\FRITZ! 2.0\03.06.03]
[HKEY_LOCAL_MACHINE\SOFTWARE\AVM\FRITZ! 2.0\Fax]
"FritzBox"=dword:00000001
"NeueTreiber2003"=dword:00000001
[HKEY_LOCAL_MACHINE\SOFTWARE\AVM\FRITZ! 2.0\Fax\Msn Liste]
"MSN0"=""
"MSN1"=""
"MSN2"=""
"MSN3"=""
"MSN4"=""
"MSN5"=""
[HKEY_LOCAL_MACHINE\SOFTWARE\AVM\FRITZ! 2.0\FRITZ!]
"SystemDir"="D:\\Program Files\\FRITZ!fax"
"Nebenstelle"=dword:00000000
"Amtsholung"="0"
"Amtziffern"=dword:00000004
"Sprache"="DEU"
"Menu"="FRITZ!fax"
"ChargeUnit"="0.060"
"UseStandort"=dword:00000000
"Components"="0100"
[HKEY_LOCAL_MACHINE\SOFTWARE\AVM\FRITZ! 2.0\Sounds]
"FritzAufbau"="D:\\Program Files\\FRITZ!fax\\gut.wav,Aufbau der Verbindung"
"FritzAbbau"="D:\\Program Files\\FRITZ!fax\\gut.wav,Abbau der Verbindung"
"FritzAbbruch"="D:\\Program Files\\FRITZ!fax\\fehler.wav,Abbruch der Verbindung"
"FritzFehler"="D:\\Program Files\\FRITZ!fax\\fehler.wav,Abbruch der Ьbertragung"
"FritzOk"="D:\\Program Files\\FRITZ!fax\\gut.wav,Dateien erfolgreich ьbertragen"
"FritzNeueFaxe"="D:\\Program Files\\FRITZ!fax\\neufax.wav,Neue Faxe vorhanden"
"SndPlayMode"=dword:00000001
"SndEnabled"=dword:00000001
[HKEY_LOCAL_MACHINE\SOFTWARE\AVM\FRITZ! 2.0\View]
"PicProgramParameter"="%d"
[HKEY_LOCAL_MACHINE\SOFTWARE\AVM\FRITZ! 2.0\Vox]
"Profil"="Standard"
"Aufnahme"="D:\\Program Files\\FRITZ!fax\\aufnahme.wav"
"NeuIcon"=dword:00000001
[HKEY_LOCAL_MACHINE\SOFTWARE\AVM\FRITZ! 2.0\Vox\Profile]
[HKEY_LOCAL_MACHINE\SOFTWARE\AVM\FRITZ! 2.0\Vox\Profile\Standard]
"Ansage"="D:\\Program Files\\FRITZ!fax\\ansage.wav"
"Absage"="D:\\Program Files\\FRITZ!fax\\absage.wav"
"Aufnahmezeit"=dword:00000078
"Verzцgerung"=dword:00000008
[HKEY_LOCAL_MACHINE\SOFTWARE\AVM\TAPI Services for FRITZ!Box]
"SystemDir"="D:\\Program Files\\TAPI Services for FRITZ!Box"
[HKEY_LOCAL_MACHINE\SOFTWARE\AVM\TAPI Services for FRITZ!Box\02.01.01]
[HKEY_LOCAL_MACHINE\SOFTWARE\AVM\TAPI Services for FRITZ!Box\Cntrl1]
"Slot"=dword:00000000
Thanks,
Alex
Is your analog line right connected?
can you dial *10#<an existing number> ?
the *10# select directly the analog line.
Yes.
Yes, I have dial tone
yes, I know, with connection all is normal, I had stable work Fritz! fax before change firmware, I think that a problem in this version firmware, I shall try to return old firmware back and I shall look as will work fritz! fax.
bingoboy
